Ball joint thread size?(making custom spacer)
Discussion in 'New Members' started by Huckshot, Apr 8, 2018.
  1. Apr 8, 2018 at 2:21 PM
    Huckshot
    Huckshot [OP] Well-Known Member
    Jared
    2000 tacoma 3.4v6 auto 4x4
    3" coil lift spacer in front. 2" block spacers in rear. 6lug to 5 lug adapters. 20" tundra rims with 33" mt tires
    Hi all,new here and have a few questions.thanks in advanced.
    I installed my front coil spacer lift and i am getting terrible tire rub on the uca. The po put 6 to 5kug adapters with tundra rims and 33s.the rims bolt up almost at the face of them (no offset)which is one big problem. I am considering making a ball joint spacer /spindle spacer to bring the uca back above the tire after the lift and to stop the rubbing issue. I need to know what the thread size is for the upper ball joint to make this spacer.im basically going to use a bolt extender to do this.
  2. Nov 6, 2021 at 8:46 AM
    tgibello
    tgibello Member
    Tyler
    1998 Tacoma 4WD
    Did you ever figure it out? Currently trying to find the same information
