ball joints, it kicked my ass.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greensystemsgo, Aug 21, 2011.
  1. Aug 21, 2011 at 1:26 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Rented a fork, and clamp set from the local autozone, as well as purchasing two upper ball joints after putting in my new suspension last week. And its kicking my ass. Can't get em to go in straight. No matter what I do. Started at 8 and its now 1.30 and hot as balls.
    So we said f it, and took out the spindle. Well my lowers are shot as well, and my cv boots. Its hot as bawls, need a larger wrench for the axle nut, and its hot as bawls.
    Any tips? Anyone free tomorrow am early?
  2. Aug 21, 2011 at 1:29 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Have a shop press them in for you. Midas did my uppers for $40.
  3. Aug 21, 2011 at 1:31 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Yeah, I was quoted 500 for the uppers and an alignment. F that. I just wish I could save the hassle and do em myself. Iwanna clean everything up real good.
  4. Aug 21, 2011 at 1:59 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Damn! I paid $40 because I only brought in the a arms and had them press in the bj's. Then, I came home and installed everything myself.
  5. Aug 21, 2011 at 2:08 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    cv inner/outer boots, lower ball joints, and im lookn for steering boots now. 130ish and counting. uppers were 25 so 155 total, plus alignment, to save a grand :D
  6. Aug 21, 2011 at 4:02 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Forks are worthless for removing the taper from the knuckle. Hit the knuckle hard on the side and the joint will vibrate enough to pull out the taper. Make sure you loosen the nut, but leave it flush with the top of the bolt.
    Take your time lining up the ball joint press and it should go in straight.
  7. Aug 21, 2011 at 4:43 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    For the uppers, put the bj's in the freezer for about an hour. then use a "4X4 Ball Joint Press" tool kit (got mine at harbor freight for $74, but sure you could rent one) and press em in. You wont believe the difference that cold metal makes. Good luck!
  8. Aug 21, 2011 at 10:37 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Lowers are a complete assembly. Ill have to try the freezer idea.
    Don't think I can get just the boot for the tierod balljoints, so those are next.
    Their wasn't any steering play, but braking and bumps were sloppy, so hopefully it'll guide like butter.
  9. Aug 22, 2011 at 1:02 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    A cheap shop press will do you wonders, you can find hand pump ones on cl for like $50.
    My buddy has one and it comes in use for SO MUCH stuff. I'm gonna buy one soon as a matter of fact.
    If not, pay someone..$40 is about right to press in bjs onto control arms.
    It's very difficult to unpress stuff out..but not as hard to press them in..long as it's straight. that's the key.
    Goodluck..lol
  10. Aug 22, 2011 at 8:35 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Yeah, few months back I was checkin cl, ten ton handpress for like a buck twenty which is great. And I got those boogers out easy as shit, its going back in that's kicking my ass. Tie rods were thirty a piece :(
  11. Aug 22, 2011 at 9:10 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    here's a really good right up from bajataco.com...
    http://www.bajataco.com/tech/control_arms_01.html
    I had to use a flat pry-bar to help keep the ball joint lined up (straight) as I was pressing it into the knuckle.
    good luck.
  12. Aug 22, 2011 at 9:14 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    did you end up getting them in? i did my passenger side balljoint and we couldnt get it to go in straight with the BJ press, so we used a air hammer:)
  13. Aug 22, 2011 at 9:23 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have the from Harbor Freight and it's a life saver for ball joints I did mine in a snap.
  14. Aug 22, 2011 at 9:33 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I've never done a Tacoma but the Haynes manual says to use a press and two sockets of the proper size. It also says a large vise could be used.
  15. Aug 22, 2011 at 9:35 AM
    jbrandt
    Justin
    I used a modified pitman arm puller ($15 tool - from the link in my previous post) and a flay pry-bar. Just put a little pressure on the pry-bar to keep it straight as you press it in. Went like butter.
  16. Aug 22, 2011 at 11:45 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    The bottom of the ball joint, the rounded part, is rounded, and sits a tad below the bevel where the socket sits. Therfore if you used a wonderbar, id imagine it would crush the pivoting socket :(
    got cv's apart from knuckle, wheel bearings feel firm (thank god), boots are still on, im assuming its a pin or something, i need to go clean all the grease before i take the boots off.
  17. Aug 22, 2011 at 12:20 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    cv bearings are NOT sealed, you will drop all needles IF you lift up on the cusp. FML.
  18. Aug 22, 2011 at 12:50 PM
    jbrandt
    Justin
    huh? The bottom of the BJ should be pretty flat, perhaps with a removable zerk fitting.
    If the BJ you got is rounded on the bottom instead of flat, you could use a large socket in between the BJ and the flat prybar, but your puller (if you use a similar setup as below) might not be tall enough. Maybe get a piece of steel tubing (the same diameter as the outer portion of the BJ ) and cut a 1/4" piece and use that as a spacer instead of a socket...
    Mine looked like this:
    (images from a 1998 4x4, from Bajataco.com) This looks just like my 2004 Taco.
  19. Aug 22, 2011 at 12:53 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  20. Aug 22, 2011 at 12:58 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    socket would work yeah, i now have up to a 36mm socket set so im sure i have something :D currently cleanin cv axles, hot as bawls out. 108 f on the thermometer right now :(
