Ball Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tuhlrig88, Mar 6, 2013.
  1. Jul 21, 2014 at 10:54 PM
    #141
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I recently changed inner and out TREs and lower balljoints. I chose to use OEM for the LBJs and went with the 555 brand of TREs. I got the TREs from LowRange Offroad for ~$30 each IIRC
    http://www.lowrangeoffroad.com/1995-2004-toyota-tacoma-inner-tie-rod-end-left-or-right.html
    http://www.lowrangeoffroad.com/1995-5-2004-toyota-tacoma-outer-tie-rod-ends-made-in-japan.html
    cruiserguy likes this.
  2. Jul 22, 2014 at 6:21 AM
    #142
    r45d
    r45d Well-Known Member
    Georgia
    01 DC 4WD
    Honestly I didn't even look for outer tie rod pricing after I saw the difference between moog and oem for inners; thanks for the heads up.
  3. Mar 14, 2016 at 2:37 PM
    #143
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  4. Apr 16, 2017 at 9:52 PM
    #144
    zodc
    zodc Well-Known Member
    Saw this old thread. I have a 2002 Tacoma Pre Runner I picked up a few months ago. Figured why not and checked online at Toyota Owners with my VIN and it indicated my truck was part of the recall. I took it to my local Toyota Dealer and they changed the LBJ under the recall. At 170k it was probably time for a change anyway. Thank you. Would have never known...
    Dalandser likes this.
  5. Feb 8, 2018 at 12:23 PM
    #145
    Ocstormtrooper
    Ocstormtrooper Active Member
    Oliver
    1995 white tacoma 4x4
    1" Lift, 265/75 r16, side exhaust exit, 1" Spacers
    This info is GOLD for any 1st gen owner!
    BUMP:hattip:
  6. Feb 8, 2018 at 2:07 PM
    #146
    04Burk
    04Burk Well-Known Member
    Glen
    Hinesville, GA
    04 4x4 V6 Xcab 217k miles
    Im in the same boat. Ran my 04 at the dealer and they said no recalls for my truck. This was 2 years ago, so maybe time to go back and see if anythings changed.
    AVOID AUTOZONE UBJ at all costs!!! If you're pressed for cash, sure. Replaced mine a few years ago after about 170k miles on original. Had one of them fail while in the woods and had to call a tow truck to the woods. Not fun
  7. Feb 11, 2018 at 6:17 AM
    #147
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Just received my L/R OEM lower ball joints yesterday and believe it or not, they came with bolt flanges. Ordered 8 bolt flanges that I don't need now
    04Burk likes this.
  8. Feb 17, 2018 at 4:34 AM
    #148
    vettehigh
    Jon
    Upstate, NY
    Installed my OEM LBJ's last night and they looked to be original (206k). No tears in the boots though, but the play in the joint was very easy to move on the old LBJ's
  9. Feb 17, 2018 at 10:43 AM
    #149
    Digiratus
    Roaming the PNW
    The RedHead
    I can't tell which model year your truck is, but I'm pretty sure it depends on the Toyota part number for the ball joints as to whether they come with bolts or not. I think the '01-'04 LBJs do not come with bolts so you have to order them separate if you want new ones. The ones for my '02 did not come with bolts.
  10. Feb 17, 2018 at 11:59 AM
    #150
    vettehigh
    Jon
    Upstate, NY
    1995
  11. May 17, 2018 at 6:33 AM
    #151
    Tacolex
    Tacolex Member
    Shelby, NC
    2004 TRD xtra cab
    Well, I just joined the ranks of ball joint failure victims. My left LBJ failed recently...fortunately at low speed. But UNfortunately, my vehicle is slightly outside of the VIN range for the recall (see PDF of recall in post #42 of this thread) (My VIN is 5TE WN72N 04Z371680 and the recall ends at 5TE WN72N 04Z357097).
    The failure occurred close to the Toyota dealership, so I had the vehicle towed there for the repairs, which cost over $3K! There are 175,000 miles on the vehicle, and the original ball joints were still installed. According to Dirty Pool (see post #41, paragraph 5), a ball joint will be far out of spec before it separates. Inspection of the ball joints is part of the service at every recommended service interval. The dealer who performed this service is the same dealer where I have had all of my periodic maintenance performed at regular intervals. Also, at 165,000 miles (10,000 miles before the failure), I had this dealer perform a front end alignment as part of the service, so they were working right there at the ball joints.
    I have a couple of questions about this:
    -should the dealer have detected the ball joint being out of spec?
    -even though I am slightly outside of the recall VIN range, is there a chance that my ball joints could’ve been defective originally, and should have been replaced by Toyota?
    Thanks for your time… Sorry my post is so long-winded!
  12. May 17, 2018 at 7:30 AM
    #152
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    my 04 didnt have recall for lbj's
    Tacolex likes this.
  13. May 17, 2018 at 11:10 AM
    #153
    Digiratus
    Roaming the PNW
    The RedHead
    Lower ball joints on 1st gens are a wear item and should fall into the normal maintenance routine. Waiting for failure, however it is defined, is an expensive mistake to make. Would you do the same with your tires?
    If you're a v6, install new ball joints when you replace your timing belt and water pump.
  14. May 17, 2018 at 11:18 AM
    #154
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I would call up toyota, they would probably wanna see your truck. Similar to that million mile tundra this is not the norm.
    Here in arizona, boots wont even last a few years just sitting.
  15. May 18, 2018 at 4:41 AM
    #155
    Tacolex
    Tacolex Member
    Shelby, NC
    2004 TRD xtra cab
    Thanks for the replies. Yes, now I definitely know that this is a normal maintenance item. I have had all of the periodic maintenance performed at the Toyota dealership, pretty much following the recommended maintenance schedule. Since ball joint inspection is part of every maintenance interval, I assumed that they would let me know if there was a need to replace them... especially since a front end alignment was part of a previous service 10k miles ago (you know what happens when you assume!).
    Thank you
    Running Board Man likes this.
  16. May 20, 2018 at 3:18 PM
    #156
    Suggs12
    Suggs12 Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    I got really lucky this evening. As I was changing my oil, I decided to check my Lower Ball Joints out that I changed roughly a year ago. The driver side was holding up fine but as I looked at the passenger side I noticed that one of the bolts was missing and the other 3 was rather loose. Now I am going to go back and replace all the bolts and make sure to put lots of loctite on them. Can anyone tell me the proper Torque rate for LBJ's? Could of easily lost all the bolts within the next few weeks if I hadn't checked this.
    Note To All: Check your Ball Joints!!
    Running Board Man and Tacolex like this.
  17. May 20, 2018 at 6:16 PM
    #157
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Glad to hear you caught that before something bad happened. I’m so paranoid I look to make sure my bolts are there every weekend. Lol. Mine only have like 8k roughly on them and I’ve only lightly wheeled it twice since then but damn it keeps me on my toes. Lol
  18. May 20, 2018 at 6:27 PM
    #158
    Suggs12
    Logan
    2004 PreRunner
    Makes me nervous too, when I replaced them last summer I didn't use OEM so I'm paranoid as well lol. Will probably do OEM's here soon.
  19. May 20, 2018 at 6:45 PM
    #159
    01GreenTacoma
    01GreenTacoma Well-Known Member
    59 ft/lbs and a small amount of blue loctite will do it fine.
    Digiratus likes this.
  20. May 21, 2018 at 4:52 AM
    #160
    Suggs12
    Logan
    2004 PreRunner
    Any clue what size bolts it takes?
