Ball joints?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hifikenny, Aug 22, 2016.
  1. Aug 22, 2016 at 7:32 AM
    Hifikenny
    Hifikenny [OP] New Member
    2001 tacoma v6 5 speed
    I recently purchased a 2001 Tacoma. When I took it to the alignment shop due to a pull to the left they told me the ball joints were all sticky except for one which is loose and they should all be replaced. Any suggestions for how to replace them? I would like to do them myself, as the shop wanted $ 1000 to do them. Does it matter bottom ones first, top ones first, all at one time?
  2. Aug 22, 2016 at 7:40 AM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
  3. Aug 22, 2016 at 7:57 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    There is a recall on them also. So check & see if the truck has been brought in for the recall or not.
    DustStorm4x4 and lonzorizo like this.
  4. Aug 22, 2016 at 5:18 PM
    NateGB
    NateGB Well-Known Member
    Nate
    Los Angeles, CA
    04 Tacoma
    Icons, uniball upper arms, ome leafs, bilstein 5100
    I'd recommend doing them all at once. The uppers can be a pain in the ass because you have to press the old one out of the spindle.
    Bottom ones are pretty straight forward. 4 bolts then the ball joint through the lower control arm.
    Here is a solid write up. http://www.bajataco.com/tech/control_arms_01.html
    If you do them all at once you can have one alignment afterwards and be done with it. In that write up he also replaces the lower control arms so obviously you won't be doing that.
    I think $1000 is a pretty hefty price for that work though. If you don't think you can tackle it yourself I'd shop around for a better price.
  5. Aug 23, 2016 at 7:24 AM
    Hifikenny
    Thanks guys
  6. Aug 24, 2016 at 12:54 PM
    MCObray
    MCObray Well-Known Member
    Oregon
    2002 Toyota Tacoma DC TRD
    I bought my OEM Toyota LBJS from @CBT_Brian for a great price, including a TW discount. As mentioned above, there are a lot of great resources on how to change them out on your own but unfortunately for me I had little-to-no time before a big trip so I let my local Toyota dealership to the installation. Hope that helps!
    CBT_Brian likes this.
