Ball Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by jf321, Aug 3, 2018.
  1. Aug 3, 2018 at 1:43 PM
    jf321
    jf321 [OP] Member
    Joe
    1997 Tacoma ext cab, 3.4L 4x4
    Best replacement lower ball joints for 1997 3.4l manual 4x4?
    Thanks
  2. Aug 3, 2018 at 1:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  3. Aug 3, 2018 at 1:50 PM
    eon_blue
    Azusa, CA
    OEM and many members here go through Camelback Toyota and get them shipped, they give good prices on OEM parts for TW members.
    QuikSilver02 likes this.
  4. Aug 3, 2018 at 1:52 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  5. Aug 3, 2018 at 1:57 PM
    eon_blue
    Azusa, CA
  6. Aug 3, 2018 at 1:57 PM
    QuikSilver02
    QuikSilver02 Well-Known Member
    A.D
    02 DC 3.4L PreRunner. 1STGENN
    881 + 5100s + 10mm spacer plate 265s with TKOS Roof Rack Pioneer stereo Tailgate brake light Spyder tail lights Custom grille with toyota letters JBA UCA's Nerf Bars
  7. Aug 3, 2018 at 1:59 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Out before the :locked:
  8. Aug 3, 2018 at 2:20 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Please search.... this has been discussed many times and I think we are all tired of having the same argument over and over again.
  9. Aug 3, 2018 at 2:27 PM
    QuikSilver02
    A.D
    lmao
  10. Aug 3, 2018 at 2:39 PM
    QuikSilver02
    A.D
    someone is going to take you serious :rofl:
  11. Aug 3, 2018 at 4:15 PM
    codosa
    codosa Rambler
    Collon
    Maui, Hawaii
    2015 Black Access Cab 4x4
    2001 Black Ext.Cab SR5 4x4 -RIP
    I'm almost afraid to admit i have moog problem solvers for upper and lower but there's some amazing discussions on this if you use the search function. Basically TL;dr OEM lasted you this long so if you have the money replace with oem
    QMEDJoe likes this.
  12. Aug 3, 2018 at 6:16 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Oh, God. Here we go!!!
  13. Aug 3, 2018 at 6:49 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    *They're*
  14. Aug 3, 2018 at 10:02 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Oem is overrated
  15. Aug 4, 2018 at 4:21 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Mine are 15 years old and they’ve lasted this long. They’re the next thing to be replaced!
  16. Aug 4, 2018 at 6:55 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Going to run moog stamp with 555 made in japan are this good ??
    Running Board Man likes this.
  17. Aug 4, 2018 at 10:26 AM
    License2Ill
    Ian
    When I pulled my moogs off for inspection after 1 year 8k miles. The grease within the boots looked as if had been glitter bombed, and the balls flopped around in the socket.
    I promptly threw them away.
    This happened on two separate vehicles, mind you. $400 of one year old parts in the garbage can. I'd run anything but moogs.
