Ball joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rice Field, Jul 16, 2020.
  1. Jul 16, 2020 at 5:08 PM
    Rice Field
    Rice Field [OP] Member
    Josh
    11 TRD Sport
    Anybody have suggestions for ball joints and control arms? Looking to run bigger wheels and tires and don't want the added stress on these components. Don’t have any desire to go off road so I don’t need top of the line but I don’t want shit parts either. Any feedback is appreciated!
  2. Jul 16, 2020 at 8:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are the ball joints bad now?
    OEM are actually pretty good.
    I’d run them, until you need to replace them.
  3. Jul 17, 2020 at 4:18 PM
    Rice Field
    Josh
    11 TRD Sport
    No, the ones that are on currently aren’t bad. But I would rather get ones that will be able to support the extra weight.
  4. Jul 17, 2020 at 5:46 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    The OEM ball joints can endure larger tires. A lot of people run their stocks when upsizing
    TnShooter likes this.
  5. Jul 17, 2020 at 5:54 PM
    TnShooter
    Deogee
    STOCK
    I’m still recommending OEM.
    MOOG was really great at one time, but lately they are hit or miss, if going by others here.
    MevoTech seems to be OK, but no better than OEM.
    90% of time, unless you are running Aftermarket CA, OEM is suggested.
    They just seem to last.
  6. Jul 17, 2020 at 6:32 PM
    Rice Field
    Josh
    11 TRD Sport
    I appreciate the suggestion! I can’t get a concrete answer on it I’m gonna need to do UCA’s or not. But I also don’t want to slack on maintenance with the added stress yunno?
  7. Jul 17, 2020 at 6:37 PM
    TnShooter
    Deogee
    STOCK
    Are you lifted? And how high?
  8. Jul 17, 2020 at 6:46 PM
    Rice Field
    Josh
    11 TRD Sport
    I will be on Wednesday, 3”
  9. Jul 17, 2020 at 6:50 PM
    TnShooter
    Deogee
    STOCK
    Just about every thing I’ve seen say YOU WILL NEED UCA.
    There are a lot of guys on here that run them.
    They may even be able to help you out on alignment numbers for after the liftt.
    Once lifted, you might want to recalibrate your VSC.
  10. Jul 17, 2020 at 6:55 PM
    Rice Field
    Josh
    11 TRD Sport
    Why would I need to do that?
  11. Jul 17, 2020 at 7:06 PM
    TnShooter
    Deogee
    STOCK
  12. Jul 17, 2020 at 7:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    These trucks aren't known for having weak front suspensions, actually quite the opposite. But if you want to spend some money anyway you've come to the right place :D
    UCAs are recommended for proper alignment once you get close to 3 inches of lift.
    Rice Field[OP] and TnShooter like this.
  13. Jul 20, 2020 at 6:45 AM
    fastprostreet
    fastprostreet Well-Known Member
    Pete
    Lancaster SC
    I did 3" lift and the truck did not drive good until aftermarket control arms to take care of the caster issue
    Rice Field[OP] likes this.
