Ball Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by JohnnyCash57, Feb 27, 2021.
  1. Mar 2, 2021 at 8:56 AM
    #41
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Can you tell me where you get your OEM air from? I bought a new toyota air filter and I'm concerned that "regular air" might ruin it.
    :devil:
  2. Mar 2, 2021 at 9:05 AM
    #42
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just like any other true Toyota purist; directly from Toyota Japan in a hermetically sealed bag :burp:
  3. Mar 2, 2021 at 9:12 AM
    #43
    jbrandt
    Justin
    oh right, those inflated pillows in shipping boxes aren't packing material, that's the OEM air. :thumbsup:
  4. Mar 2, 2021 at 9:32 AM
    #44
    Madjik_Man
    Colorado Front Range
    Prerunner or 4x4 in the item description is what you want.
    Also if you click on the “info” button it will give you OEM part numbers to cross reference.
  5. Mar 2, 2021 at 11:38 PM
    #45
    Taco!
    Taco! Well-Known Member
    98Xcab4WD
    To put this is perspective, Timmah's video says Toyota specs are 0.5mm movement (the crow bar video method). In decimals, that's .0197 inches. The crow bar video guy says his show 1/16" of play, and that's .0625 inches, which means 1/16" movement is 3 times larger than spec. End result is that if you see any type of movement with the crow bar method, then you're driving on borrowed time and new lbj's should be on your shopping list.
    I'm currently shopping for my driver's side lbj. I was thinking of going to 555's, $65 at Low Range, but their website says they are on backorder. Just priced oem at camelback... $126.
  6. Mar 3, 2021 at 12:08 AM
    #46
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Don't forget new bolts (x8) 90119-10933 and a tube of Blue with those new Toyota LBJs
    JohnnyCash57[OP] likes this.
  7. Mar 3, 2021 at 8:48 AM
    #47
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
  8. Mar 3, 2021 at 9:04 AM
    #48
    JKO1998
    JKO1998 Well-Known Member
    Utah
  9. Mar 3, 2021 at 4:26 PM
    #49
    Taco Phil
    Taco Phil Taco Phil
    Galveston, Texas
    04 2.7 3RZFE Reg Cab 4X4
    Beautifully stock
    Are LBJ’s changed more that uppers?
    Do you normally just change the lowers?
  10. Mar 3, 2021 at 4:27 PM
    #50
    JKO1998
    Utah
    Both need replacing eventually and neither one are difficult to change.
    I did both at the same time.
    Taco Phil[QUOTED] likes this.
  11. Mar 3, 2021 at 5:54 PM
    #51
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    @cobascis
  12. Mar 3, 2021 at 6:11 PM
    #52
    cobascis
    cobascis Active Member
    2004 Tacoma SR5 4x4 3.4L
    ARE Camper Shell
    Thank you!
    Sicyota04[QUOTED] likes this.
  13. Mar 3, 2021 at 6:24 PM
    #53
    Sicyota04
    Morgan
    California
    04 DC 4x4
    For sure. No prob
  14. Mar 3, 2021 at 6:42 PM
    #54
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    I just bought some from RockAuto. The Moog Problem Solver brand comes as 555's. It says Moog on the box but the actual part is 555 brand. Ball joint and casting. I bought them last year and they have held up great, they definitely still had life in them when I removed them. As insurance I replace them yearly.
  15. Mar 3, 2021 at 6:57 PM
    #55
    Taco Phil
    Taco Phil Taco Phil
    Galveston, Texas
    Beautifully stock
    Est Shop cost for both upper and lowers?
  16. Mar 4, 2021 at 10:23 AM
    #56
    HighPlainsTaco
    HighPlainsTaco I am haunted by waters…
    Ethan
    Comancheria
    2002 3.4L 4WD TRD
    I just replaced my LBJs, outer tie rods, and sway bar links and had my truck aligned. I hadn't heard about the LBJ failure issues until reading these threads. I installed the O'Reilly MasterPro brand w/new bolts and torqued to spec. Did I just waste my money??? (I'm in a v6 PreRunner, mostly daily commuting).
  17. Mar 4, 2021 at 10:25 AM
    #57
    Madjik_Man
    I just replaced mine within the past few months.
    McGeorge had the best deal on LBJs
  18. Mar 4, 2021 at 10:45 AM
    #58
    jbrandt
    Justin
    He is.
    I had moogs on my daily driver/weekend warrier off roader for over 6 years, and my truck didn't explode.
    Main thing is to just not install and ignore them for the next decade. OEM or otherwise: an ignored balljoint is a failed balljoint.
    Abeyancer likes this.
  19. Mar 4, 2021 at 10:47 AM
    #59
    Kwikvette
    Fresno County
    4 run, 2 don't
    I swear you took that from something else :rofl:
  20. Mar 4, 2021 at 11:23 AM
    #60
    jbrandt
    Justin
    paraphrased from my build thread soapbox, or maybe some speech by General Eisenhower. :confused:
