Ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by lightning896, Apr 3, 2025.
  1. Apr 3, 2025 at 8:42 AM
    lightning896
    lightning896 [OP] Member
    1998 Black Tacoma 2.7l PreRunner
    Hello! I’m looking to get new ball joints for my Tacoma. I know everyone is saying get OEM ball joints, but I wanted to ask if anyone has had experience with Sankei 555 LBJ’s. I read that they’re the same manufacture that makes Toyota LBJ’s, and without the name brand they’re significantly cheaper. Can someone confirm this and or share their experience using these LBJ’s? Thank you!
  2. Apr 3, 2025 at 9:28 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    You already know what the answer is.
    Some people will say they're great, most others will say they're not worth it.
    555 is probably the best of the non-oem options, but these are a 70-100k mile interval part, is it really worth saving the $80 over the next 5-10 years of driving?
    They are not the same as OEM, and its easy to verify they are not the same because they have a grease port while OEM do not.
    The OEM TSB kit LBJ pair is only $180, $200 including bolts you'll need.
    https://toyotaparts.ourismantoyotao...Aw0sJtKJQF_mTwUVVKwmRnLprBXp1FhsCFEwm1UBWA-sh
    https://toyotaparts.ourismantoyotao...7Pfyz0xcDl3H6thR64e95_KB0LnWqF7-SugXEhSnkTQHJ
  3. Apr 3, 2025 at 9:38 AM
    lightning896
    Thank you! That’s very helpful. What’s the second link you sent? Does the first link(the LBJ pair) not come with the castle nut , just the cotter pins?
  4. Apr 3, 2025 at 9:40 AM
    lightning896
    Nevermind I just saw in the description it doesn’t come with the hardware haha. Where can I find the right bolts and nuts and cotter pins for these LBJ’s?
  5. Apr 3, 2025 at 9:49 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    The first link shows the pair of LBJs with 4 cotter pins. The second link shows the bolts with washers. Neither has the castle nut, but I imagine those are available if yours are too far gone.
  6. Apr 3, 2025 at 9:53 AM
    time623
    James
    AZ
    It says it comes with no nuts or pins, but I'm pretty sure my kit came with both last time. No guarantees there though.
    The 2nd link is bolts, those are the 'black' bolts (important note these are 37 ft-lb spec vs the 59 ft-lb spec on other LBJ bolts)
    Heres the castle nut, you can probably re-use your old ones though
    90171-16050
    and cotter pin, 95381-03230, personally I'd just run into harbor freight and pickup and an assortment kit of like 200 pins for $10 so you never have to worry about cotter pins again. Its nice to be able to throw a new one on whenever you take any off
    I'd add it all up, compare the price to buying the regular L/R LBJs 43340-39436 and 43330-39556 vs the TSB Kit pair + hardware, and then compare back against your 555 to see what you want to do
  7. Apr 3, 2025 at 10:03 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Senkei isn't the manufacturer of balljoints for Toyota, Somic Ishikawa is. That's what you buy from Toyota and what you should get if it's branded as Toyota. Not 555.
  8. Apr 3, 2025 at 10:20 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I'm not sure why the link above says "no fitment available even with VIN." When I bought mine they came with castle nut and bolts. Do your shopping and shoot Ourisman an email to confirm, they're pretty responsive (and don't want to deal with returns.) I'd mis-ordered something and they wouldn't ship until it matched my VIN.
  9. Apr 3, 2025 at 10:43 AM
    lightning896
    Thanks everyone so much! This is very helpful
    time623 likes this.
  10. Apr 3, 2025 at 11:30 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Just go with OEM
  11. Apr 3, 2025 at 11:39 AM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    OEM should last ya much longer than 70k to 100k... most likely twice as long at the least
    I don't quite know where that figure came from?
    Perhaps lifted taco and not stock height?
  12. Apr 3, 2025 at 11:41 AM
    lightning896
    I think he was saying that the 555 brand lasts only that long, and OEM lasts much longer
    Black97v6MT[QUOTED] likes this.
  13. Apr 3, 2025 at 11:42 AM
    Black97v6MT
    iMA0
    tacoLand USA
    Oh ok then
    I wasn't quite sure!
  14. Apr 3, 2025 at 11:45 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Depends entirely on how you use your truck. When I was wheeling my 04 regularly I went through 2 sets of OEM ball joints in less than 60k miles because they started showing signs of visible play. Just inspect them at regular intervals especially if you beat on them.
  15. Apr 3, 2025 at 2:33 PM
    Running Board Man
    Running Board Man Well-Known Member
    I've actually purchased 555s that do and don't have a grease port
    The ones that were sealed were from trail gear and were in colorful boxes with the 555 brand logo on it
    The ones that did have a grease port were in generic white boxes from oreillys
    time623[QUOTED] likes this.
  16. Apr 3, 2025 at 2:54 PM
    time623
    James
    AZ
    My 100k interval suggestion was for OEM, based on primarily paved-road driving. Is that sooner than is absolutely necessary for someone who barely offroads? Probably, but the alternative is too late. That mileage seems to be the general consensus on a reasonable interval that is safe and not expensive to maintain.
    Its the same as the timing belt, do many people take an OEM timing belt to 200k? Yes absolutely. Should you? No you really shouldn't
    What the interval should be with other brands? No clue
    My truck these days is basically dedicated to getting to trails, and being on trails, so that interval is probably going to get cut way down (but my overall miles have cut way down too so its still years between replacement), like @eon_blue has experienced.
    I have no intentions of having another lbj failure and dealing with all the body damage and other parts breaking that go along with it. Not to mention safety, most people, including myself, seem to get lucky and have them go out at slow speeds in and around parking lots, not on the highway going 75. Maybe that's just the good old survivorship bias coming out to play
  17. Apr 3, 2025 at 3:07 PM
    Black97v6MT
    iMA0
    tacoLand USA
    I am definitely concerned! about it breaking at highway speed of 75 on some rotten-to-heck bridge deck
  18. Apr 3, 2025 at 4:00 PM
    eon_blue
    Azusa, CA
    most LBJ failures happen at low speed tight turns when there's more stress on the joint..which is why you usually see people posting about it happening in a parking lot or turning into their driveway, etc.
    or maybe that's just because all the people that had them fail on the highway at 80mph are dead, who knows
    PathFinder1776 and time623 like this.
  19. Apr 3, 2025 at 4:29 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    What's your location, maybe someone local can help you with a discount from the dealership. I get oem stuff at cost+ tax.
  20. Apr 3, 2025 at 5:41 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    How come every other crappy part company can come off the pin, the bolts and the nut yet our mothership is all skin flint with that stuff. Kinda erks me
    Running Board Man likes this.
