BamBeds Tacoma Solo Platform Available Now
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by BamBeds, Mar 18, 2022.
  1. Mar 18, 2022 at 11:18 AM
    BamBeds
    BamBeds [OP] Founder/Designer Vendor
    Ben
    Central Coast, CA
    '09 Access Cab TRD OR
    Bilstien 8100, 8112, Snugtop w/ windoors
    BamBed is a 3 piece sleeping/utility platform designed for the Toyota Tacoma. It provides enough area to slide in up to a full-size trifold mattress, allowing the bed to remain made while storing gear underneath. It is a modular design that can be reconfigured to accommodate taller items such as mountain bikes, coolers, and camp furniture while you're on the road. Unlike permanently installed systems, this platform can be removed in under a minute with no tools - allowing full use of your truck bed when you need it. Each board handle has a 2" x 5" opening that may assist with user-friendly setup and removal of the platform as well as provide tie-down locations for securing cargo.
    Each Board is made from high-quality Bamboo or Birch with a smooth finish. All edges are rounded which gives the boards an ergonomic feel and makes the wood resistant to damage and splintering.
    Compatible with all 2nd and 3rd gen Tacomas (2005-present)
    Long Bed Version Link
    Short Bed Version Link
    Tailgate Extension Option available as an add on
    Shipping is Free!
    Orders ship next business day
    Shipping transit times are typically 3-5 business days.
    el_turks, hr206, bhova and 23 others like this.
  2. Mar 19, 2022 at 5:24 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Very cool!
    BamBeds[OP] likes this.
  3. Mar 21, 2022 at 5:03 AM
    BamBeds
    Ben
    Central Coast, CA
  4. Mar 23, 2022 at 8:56 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Do these have "cut outs" that allow them to go around bed stiffeners (front & rear)?
  5. Mar 23, 2022 at 9:01 AM
    BamBeds
    Ben
    Central Coast, CA
  6. Mar 23, 2022 at 9:04 AM
    TartanEagle
    '17 ACLB 4x4 MT
    Cheers for the VERY quick response.
    It did look that way in all of your photos, but had to ask. The next question will be about warranty (once modified around the stiffeners)?
  7. Mar 23, 2022 at 9:14 AM
    BamBeds
    Ben
    Central Coast, CA
    These are pretty bulletproof, A small notch for the bed stiffeners isn't in a high-stress location of the product and wouldn't have any significant effect on the strength of the boards. I've never seen a broken board, but there's a first for everything... If a board breaks on you I'll send you a free replacement.
  8. Mar 23, 2022 at 9:15 AM
    TartanEagle
    '17 ACLB 4x4 MT
    Outstanding! Way to stand behind your product.
  9. Mar 23, 2022 at 10:27 AM
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    Any idea if molle bed panels would interfere?
  10. Mar 23, 2022 at 10:33 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    No doubt most would. I have both side and front CaliRaised molles and they stand out nearly an inch from the composite and run right down to the fenderwell. Most others I have seen do exactly the same. You could probably modify the molle attachment to make it work but it'll take some significant effort.
  11. Mar 24, 2022 at 7:27 AM
    BamBeds
    Ben
    Central Coast, CA
    Yes it looks like most molle panels cover the bed ridge
  12. Mar 24, 2022 at 10:26 PM
    armoured
    armoured Well-Known Member
    2020 OR DCSB
    Was this $550 yesterday and now is $450? I could have sworn I saw 550. Just curious.
  13. Mar 25, 2022 at 5:11 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    When I looked the other day the add on for the extension must have been messed up because it wasn’t that cheap. Nice looking product.
  14. Mar 25, 2022 at 9:17 PM
    BamBeds
    Ben
    Central Coast, CA
    You're not crazy. I just made another batch of inventory at a higher volume and was able to cut costs by doing so - so I'm passing on some savings!
  15. Mar 27, 2022 at 3:25 PM
    armoured
    2020 OR DCSB
    Any plans or possible for making a version without the middle 4 holes so dogs won't have their paws go through easily?
  16. Mar 27, 2022 at 9:04 PM
    BamBeds
    Ben
    Central Coast, CA
    I can certainly do that! Just sent you a PM to discuss more
  17. Mar 30, 2022 at 11:13 AM
    BamBeds
    Ben
    Central Coast, CA
    Putting the finishing touches on a set that's headed to my first Canadian customer who lives north of Anchorage AK.
  18. Apr 7, 2022 at 1:01 AM
    jruiz555
    jruiz555 Well-Known Member
    Might be a dumb question when they are layed out in the bed do they rattle when driving?
    tacodemontana likes this.
  19. Apr 7, 2022 at 6:24 AM
    joncure
    joncure Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    Another dumb question;
    I made a crude bed platform that uses 1x6’s that lay across the bed in those molded slots for added support.
    Q: Do you recommend using these for your BamBed platforms?
  20. Apr 7, 2022 at 8:06 AM
    tacodemontana
    tacodemontana Well-Known Knuckle Dragger
    MGM 2019 Tacoma Mystery Trim
    A little bit of this, and a little bit of that.
    I had the same thought, but I'll update on here once mine show up on monday. Im super excited for it, because they look awesome, but i had the same question about the rattling. im guessing even if there is some, its super easy to remedy with some foam padding and whatnot.
