BAMF 2nd Gen and 3rd gen rear shock relocation kit.
Discussion in 'Bay Area Metal Fabrication' started by JLee, Aug 6, 2012.
  1. Apr 13, 2017 at 2:32 PM
    #541
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's in the OP
    KING shocks tested KING Part# PR2012-SS12.0" stroke 31.585" Extended Length 19.585" Collapsed Length 7/8" Shaft Dia
    ChadsPride and MotoEd like this.
  2. Apr 13, 2017 at 4:48 PM
    #542
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    Thanks jerry. I didn't see it
    ChadsPride likes this.
  3. Apr 17, 2017 at 9:35 AM
    #543
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
  4. Apr 17, 2017 at 9:36 AM
    #544
    Lakeside, Ca. 92040
    we stock them
  5. Apr 24, 2017 at 11:58 AM
    #545
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I believe I am about to go this route...the OEM king replacement shocks limit my Dakars and I want the full droop!
    sytfu510 and BulletToothTony like this.
  6. Apr 26, 2017 at 3:47 PM
    #546
    Zandroid
    Zandroid Well-Known Member
    Zander
    SoCal
    '16 TRD-OR DCSB 44
    King Ext Coilovers LR-UCAs BAMF Relocation w/ 12" 2.5 King Pelfreybilt Armor: Bumper, Skids, Sliders Prinsu Roofrack ARB Snorkel & Twin Compressor sPod
    Still in stock? I'm almost ready to put in an order.
  7. Apr 26, 2017 at 4:26 PM
    #547
    xterra9171
    xterra9171 Well-Known Member
    Logan
    2011 super white tx pro
    Stock for. Ow
    How far off base would I be If wanted to run the king 2.0s and this kit on stock height truck?
    I'd like to gain some extra flex but I'm not really ready to do a full blown lift yet. Still learning on these trucks
    (I'm coming from an xterra that I run revolver shackles and extended bisteins for a 3 inch lift at stock height)
    Appreciate the help
  8. Apr 26, 2017 at 4:28 PM
    #548
    Zandroid
    Zander
    SoCal
    '16 TRD-OR DCSB 44
    I assume you would be keeping the stock leafs then? If that's the case the shock swap would be canceled out by the factory leafs. You wouldn't be able to get any more flex or travel out of them without breaking.
    xterra9171[QUOTED] likes this.
  9. Apr 26, 2017 at 4:40 PM
    #549
    xterra9171
    Logan
    Stock for. Ow
    Appreciate the info, I guess I'll add this to the list and do it all once. I was looking for something to stay on the stock leafs for now. Mine are still in good shape and not sagging at the moment
    Out of curiosity what I run the risk of damaging? The leaves themselves or the shocks?
  10. Apr 26, 2017 at 7:31 PM
    #550
    JLee
    Jerry
    Grass valley CA
    Yes good in stock.
    Zandroid[QUOTED] likes this.
  11. May 4, 2017 at 6:47 PM
    #551
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
  12. May 5, 2017 at 9:21 AM
    #552
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    MotoEd likes this.
  13. May 5, 2017 at 2:43 PM
    #553
    dustin19d
    Dustin
    Washington
    It's actually in pretty good shape considering it's age. I only have 72k miles on it. The pic is a little missleading as we painted and undercoated everythign back there when we finished.
  14. May 20, 2017 at 7:29 AM
    #554
    widowmaker_13
    widowmaker_13 Well-Known Member
    2011 TX Pro
    I'm looking for some suspension advice.. I plan on running King 2.5 mid-travel coilovers in the fronts. I had been planning on running just a 1.5" AAL in the rear. So two questions:
    -Would a 12" shock be of any value with just a 1.5" AAL?
    -Would Dakars be a better option?
    The only reason I was going with 1.5 is because I really don't carry much weight with me, and I don't like having a truck where the rear sits higher than the front. I'm worried that the Dakars will make the rear sit too high for my liking. I'm still pretty new to this stuff. Ask me any question on the corvetteforum and I've got you covered But Tacomas/off-road suspension is still new to me..
  15. May 20, 2017 at 6:46 PM
    #555
    JLee
    Jerry
    Grass valley CA
    Really the only way to tell would be cycle your suspension measure then pull the shock and cycle it again. If you get more travel then with the shock in the 12's will benefit your suspension.
    MotoEd likes this.
  16. May 25, 2017 at 10:07 AM
    #556
    Yager78
    Yager78 Well-Known Member
    Las Vegas
    15 Tacoma TRD Off Road
    King Coilovers, Total Chaos UCA, Dakars, Pelfrey Front and Rear with Swingout, AP Sliders, Budbuilt Skids, OBA, OBW.
    Would the added length be canceled out if I ran some expedition leafs? I'm building a heavy truck, but I still like to play in the rocks.
  17. May 25, 2017 at 9:19 PM
    #557
    JLee
    Jerry
    Grass valley CA
    The post above is exactly what you want to follow.
    Yager78[QUOTED] likes this.
  18. May 30, 2017 at 12:12 AM
    #558
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Jerry, would King PR2512-SS 2.5x12" Smoothies work on this kit? I realize you designed it initially for 2.0 shocks...
  19. May 30, 2017 at 6:09 AM
    #559
    JLee
    Jerry
    Grass valley CA
    It's 3" wide I've seen people do it but I have not tested it myself.
  20. May 30, 2017 at 1:37 PM
    #560
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Thanks...
