BAMF 2nd Gen and 3rd gen rear shock relocation kit.
Discussion in 'Bay Area Metal Fabrication' started by JLee, Aug 6, 2012.
  1. Aug 30, 2021 at 6:59 PM
    #1081
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    You can always depressurize and repressurize the shock
  2. Aug 30, 2021 at 7:09 PM
    #1082
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Floor jack
    crashngiggles likes this.
  3. Aug 30, 2021 at 10:47 PM
    #1083
    JHEAL77
    JHEAL77 "I love mom"
    Cincinnati, OH
    2015 Black Tacoma TRD Off Road
    Ended up using the Tacoma stock bottle jack. Worked perfect!
  4. Aug 31, 2021 at 9:47 AM
    #1084
    JHEAL77
    Cincinnati, OH
    Now I need to figure out the length of spacer necessary to center up the tops of the Fox shocks.
    Had to put everything together quickly because I was nursing a wound during the install. Had a cutting wheel explode and nearly cut my finger off.
  5. Sep 5, 2021 at 9:40 AM
    #1085
    Tacomasprime05
    Tacomasprime05 Well-Known Member
    Evan
    Charlotte
    Blue trd sport 05
    Led light conversion Kn air filter Total chaos uca King coilovers Cab mount chop Headlight hydrodip housing Grill craft/ Bay Area metal fab grill Light bar in hood scoop Weld on spindle gusset SOS concepts sliders Soft topper Bluetooth radio conversion
    Hey on install w/ 12” shocks, what length brake lines you guys running?
    limit straps?
  6. Sep 5, 2021 at 9:43 AM
    #1086
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  7. Sep 5, 2021 at 2:12 PM
    #1087
    Chadr7858
    Chad
    Colorado
    I'm running +4 lines and straps on my short body 14s
    Tacomasprime05 likes this.
  8. Nov 25, 2021 at 9:22 PM
    #1088
    Maxx
    Maxx Well-Known Member
    @Chadr7858 How have you liked the 360/80 valving your 7100’s? @T1089 went with 255/70 and @socalexpeditions did 275/78.
    Anyone else have any feedback on their valving in their 7100’s since some people seem to have gotten some miles on them now?
  9. Nov 25, 2021 at 9:48 PM
    #1089
    Chadr7858
    Chad
    Colorado
    Mine are great I can absolutely mob with a load and it really helps control the heavy duty leaf pack. With no load its a bit much but it only takes a hundred pounds in the bed to make it perfect
  10. Nov 25, 2021 at 10:55 PM
    #1090
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Unfortunately no idea I bought a different truck
  11. Nov 26, 2021 at 10:14 AM
    #1091
    T1089
    T1089 Well-Known Member
    Tristan
    B.C. Canada
    2017 Tacoma TRD Sport 6MT
    -Bilstein 5100's EXT + 886 OME coils -Bilstein 7100 14"SB shocks -Camburg Uni ball UCA's -BAMF leaf hanger & shackle -BAMF shock relocation kit -Dakar HD leafs -U-bolt flip kit/super bumps -TRD PRO SEMA rims + 255/80/17 Ridge Grapplers -Cali Raised Led 32" hidden light bar & switch panel - Backflip tonneau -Demello tube sliders -Mobtown skid -TRD Pro grill -Custom bed rack -OVT 2.0 SFOB Tune -2WD Low mod -Kicker CS Speakers
    I don't really have any comparison, but with the 14" SB's the truck feels way more planted and controlled as well as droop for days. the 255/70 are great unloaded and with camp gear. if your "overlanding" with lots of weight regularly id probably go with higher valving rates.
  12. Dec 4, 2021 at 9:05 AM
    #1092
    Beninono
    Beninono Member
    2017 inferno taco
    Sooo as I read through the comments I see most you guys are runnin the 7100 instead of the kings and fox , and talking about valving them appropriately, how do I figure out what I need ? And get it done ? Do y’all do it by ur self ? Or have get it from somewhere with the appropriate valve ?
    I’m 1700 over stock in the rear and getting an Alcan leaf
  13. Dec 4, 2021 at 9:51 AM
    #1093
    T1089
    Tristan
    B.C. Canada
    7100 SB’s are able to be ordered in different compression/rebound values IE “Valving” they are also rebuildable I believe. I picked the valving from a valving chart for our trucks, but that was recommended for mid-light trucks. I run 255/70 but don’t usually have a lot of weight and they are great. The higher valving helps to control the stiffer rear leaf springs and added weight. I’d probably go with 275/78 minimum. Cant really say much else in terms of personal experience.
    Beninono likes this.
  14. Dec 4, 2021 at 10:13 AM
    #1094
    Beninono
    Beninono Member
    2017 inferno taco
    Gooood to know !
    and I see most of you guys going with the 14 short body ? Mia there a part number I can look for it or something?
  15. Dec 4, 2021 at 10:53 AM
    #1095
    Chadr7858
    Chad
    Colorado
    I'd do the 360/80 being that heavy without a doubt. I run 360/80 with no weight to keep the leaf pack under control
  16. Dec 4, 2021 at 12:06 PM
    #1096
    T1089
    Tristan
    B.C. Canada
  17. Dec 4, 2021 at 1:07 PM
    #1097
    Beninono
    Beninono Member
    2017 inferno taco
    Worddddd
    Y’all ever went with locked off road ?
    Thanks for the help y’all !
  18. Dec 5, 2021 at 8:55 AM
    #1098
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I'm running the 14" 7100 SBs with 255/70 and have a bit of weight and I like the ride.
    Even loaded up for a week of camping I like the ride.
  19. Dec 5, 2021 at 9:33 PM
    #1099
    PainterVern
    PainterVern GoatRoper
    Vernon
    Reno Nv
    19’OR
    A few things….
    So I really don’t want to brake down the leaf pack if I don’t have to for measuring the up travel. I have the 7100 14”. Why can’t I just hang the truck from a lift (full droop) with shock mounted at the top only, then lift shock 1” and weld bottom mounts?
    TacoEspecial likes this.
  20. Dec 6, 2021 at 3:45 AM
    #1100
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You can do it however you want. I broke mine down and compressed so I know exactly where they need to be to give maximum compression and droop. When my leafs are fully compressed, I have a 1/4" of shock shaft showing.
