BAMF 2nd Gen and 3rd gen rear shock relocation kit.
Discussion in 'Bay Area Metal Fabrication' started by JLee, Aug 6, 2012.
  1. Dec 6, 2021 at 9:27 AM
    #1101
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I think so.
    And what about not doing a full weld at first but weld more than a quick tack, like say a couple 1/4 welds on each.
    Then flex it and..
  2. Dec 8, 2021 at 8:14 AM
    #1102
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Anyone know the axle tube thickness for the 2nd gens rear axle? I figure I'll need this to dial in the welding parameter to glue the bottom mounts. I read 3/16" stamped steel on another site but wasn't clear if that was the older Toyota mini axles or these.
  3. Dec 8, 2021 at 9:26 AM
    #1103
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Are you wanting tube diameter or tube wall thickness?
  4. Dec 8, 2021 at 9:37 AM
    #1104
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Thickness. the plates are 1/4" so wondering if I should dial the settings towards that or something less?
  5. Dec 8, 2021 at 10:58 AM
    #1105
    01 dhrracer
    Still Shopping
    I would find some scrape tube with the same wall thickness and scrape plate and cut to match tube and practice with technique and settings. But you will need to direct more heat into the thicker material. Another option is to do the set up yourself tac perches into place then have an experienced welder come over and finish welding them.
  6. Dec 9, 2021 at 3:33 AM
    #1106
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Thanks -- that is pretty much the plan. I have some old tube that I've already cut into smaller slices pieces and have been practicing cutting and attaching along the curve and sitting flat on the plate and working my way around. This is likely happening in February or March for me. I will be doing all the prep and the guy that did my sliders a few years back is will likely do the final welds if I'm not there yet. I did build my bumper from the Coastal Offroad kit a few weeks back which gave me plenty of practice along with all the scrap I'm messing around with, but I also understand this endeavor is much more critical -- Thanks
    01 dhrracer[QUOTED] likes this.
  7. Dec 9, 2021 at 3:42 AM
    #1107
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    When you're welding the lower shock mounts, wrap a wet rag around the end of the axle so you don't melt the seal. Youll also want to change your diff fluid when everything is complete because you're gonna burn the fluid in the tube when you weld.
    dk_crew[QUOTED] likes this.
  8. Jan 15, 2022 at 5:34 PM
    #1108
    AlHago
    AlHago Well-Known Member
    Alan
    Huntsville, AL
    12 DCLB MGM
    Stock as all get out.
    @JLee / So in the title it says leave about an inch of shaft showing at full bump, does that measurement include the black grommet dust wiper thing or do you need to measure above that if its seated at the bottom?
  9. Jan 17, 2022 at 4:52 PM
    #1109
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just 1" of shaft showing so it would be just above that bump. I would keep it at one inch from metal on metal contact at full bump.
    TacoEspecial, dk_crew and Vegasstunts like this.
  10. Feb 7, 2022 at 4:27 AM
    #1110
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x3
    Hey guys, I'm one of the schmucks that missed out on the epic group buy a couple years ago. Still kicking myself for that, but I did at least buy a set of the relocation brackets on sale thanks to that troll a while back. Well, I think I can finally afford the shocks now, and I also just ordered the BAMF hangers and shackles to complete the project.
    I'm seeking your help with a measurement, to figure out if I'll need wheel spacers. It seems like the most important factor is the effective wheel BS, but I don't know much about my wheels except that they are round and made from some kind of metal. I bet I could pull one off the truck and figure out how to measure the BS, but I was hoping to approach this differently, with a more direct measurement:
    Would anyone who's successfully done this upgrade mind grabbing a tape measure to report the dimension above, when you get a chance? I'm requesting the distance between the inboard tire sidewall and the frame, measured on a level surface.
    In my feeble mind, this seems like a useful measurement for determining clearance, as it takes into account the BS, spacer if present, and tire width. I suppose that your specific spring setup, shock diameter, and bumpstop configuration will also affect clearance at the limits of articulation, so it would be nice if you could also report details of your suspension setup, as well as your perceived clearance margin. For example, do your tires rub slightly against the shocks/brackets, or do you have room to spare at full stuff?
    Example measurement: My truck currently has about 6-3/8" clearance between the tire and the frame on a level surface.
    I apologize for asking for this measurement when the range of acceptable BS values has already been discussed on the thread. I am too lazy and stupid to deal with BS. I'm hoping a few of you could report this measurement, so I could get an idea of what the minimum value needs to be. It would make my life a little bit easier, and perhaps it might also help others in the future. Thank you.
    Follow-up question: How do you break down the leafs to cycle the suspension? For what it's worth I'm currently running the AP Expos. All I remember from installing them that I urgently needed to go to a chiropractor afterwards. I assume I can unbolt it at the center pin?
    Wait just one more question: Does anyone know of a spring that will carry a bunch of bed weight (800+ lbs?) while still allowing for a bit of uptravel? The expos carry the weight fine, but they're so thick, I'm barely off the bumps at rest. Switching to piston-style bumps smoothed out the ride, but I am probably wearing out the springs pretty quickly this way, and also it seems kind of stupid to be using the bumps to carry so much of the dynamic load. It rides well enough that I don't really want to change the spring geometry, but if there's a better leaf pack available for my truck, I'd like to swap it in before welding on the new shocks.
    RichardC.ranium likes this.
  11. Feb 18, 2022 at 11:41 PM
    #1111
    mk5
    SoCal
    '05 access cab 4x3
    Assistance with the above questions would be appreciated. Parts are in now, so time is critical -- I'm easily within 1-2 years of actually starting work!
    TacoEspecial likes this.
  12. Feb 19, 2022 at 5:22 AM
    #1112
    Tacomasprime05
    Tacomasprime05 Well-Known Member
    Evan
    Charlotte
    Blue trd sport 05
    Led light conversion Kn air filter Total chaos uca King coilovers Cab mount chop Headlight hydrodip housing Grill craft/ Bay Area metal fab grill Light bar in hood scoop Weld on spindle gusset SOS concepts sliders Soft topper Bluetooth radio conversion
    Your initial question is too dependent on tire/ wheel size as well as shocks that you decide to use. If the suspension only went up and down linear then it would be easy to answer that. That’s why it’s recommended install is as listed. Yes, pull leaf springs off, yank center pin, reinstall the main leaf. ( I added a temporary spacer w/ pin reinstalled to allow axle to track properly and space shock properly) Then bolt in upper eye of shock and cycle from there to match up lower shock mount for tacking in.
    If doing leaf springs made you need the chiropractor, go ahead and schedule a couple visits that week… you’re going to be getting up and down and under 6 ways from Sunday unless you have a lift.
    I also found it necessary for tire to shock body clearance to do a shackle flip… just couldn’t get enough room otherwise.
    TacoEspecial and mk5 like this.
  13. Feb 19, 2022 at 5:43 AM
    #1113
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Only way to know if you'll need spacers or not is to fit the wheels on and flex em. My 35" tires on 16x8 wheels w/ 4.5" BS needed wheel spacers. I put on 1" wheel spacers and I've got about 1/4" clearance between tire and shock. This doesn't apply to everyone because shocks are different, weld location is different, wheels, leaf springs, tires. Alot of factors, so there is no real hard answer, you just gotta do it.
    Ricardo13x and mk5[QUOTED] like this.
  14. Feb 19, 2022 at 7:20 AM
    #1114
    mk5
    SoCal
    '05 access cab 4x3
    Thanks guys! I'm still clinging to the idea that this measurement is somehow relevant and useful. It doesn't matter what tire size, shock, wheel, etc. is used. It's just a distance that I'm asking folks to measure with a tape measure.
    I understand that I'll just have to do the project to know for sure. Sometimes being stubborn and niave is how I learn things. I do appreciate your responses.
    I'll schedule some chiropractor sessions and have the wambulance on speed dial though. Sadly no lift down here.
  15. Feb 19, 2022 at 9:34 AM
    #1115
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    7 5/8" :thumbsup:
    mk5[QUOTED] likes this.
  16. Feb 19, 2022 at 5:05 PM
    #1116
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Pretty nice little kit! Did the Bamf relocation, 14" Bilsteins, and Chevy 63s on a buddys truck. Can't beat the price for this setup.
  17. Feb 19, 2022 at 5:22 PM
    #1117
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Perty
    Buttskevin21[QUOTED] likes this.
  18. Feb 22, 2022 at 8:27 AM
    #1118
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Is that the DMZ frame box kit? Or ...?
  19. Feb 27, 2022 at 1:45 PM
    #1119
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Has anyone ran this setup with 12" ADS shocks? I have coilovers up front and would like to run ADS in the rear as well to keep things the same.
  20. Feb 27, 2022 at 3:10 PM
    #1120
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    2.0 shocks would fit fine, don't think 2.5s would fit/clear all the way throught articulation
