BAMF 2nd Gen Light Bar w/URD TCAI fitment
Discussion in 'Bay Area Metal Fabrication' started by armyoffoo, Nov 27, 2012.
  1. Nov 27, 2012 at 7:44 AM
    armyoffoo
    armyoffoo [OP] Scrotie McBoogerballs
    Houston, TX
    Silver 2012 DCSB 4x4 V6
    TRD SC, URD 2.8" pulley, NST Pulleys, Cometic Headgaskets, ARP Head studs, rod bolts, flex plate bolts, header studs, CP Pistons, Molnar Rods, Clevite Bearings, APR Exhaust cam gears, 170* thermostat, URD TCAI, DTLT Headers, URD Y Pipe, URD MK2 Catback exhaust, URD Fuel Pump upgrade, Fuelab Fuel filter, AEM Adjustable FPR, AEM Datalogger with AFR, Boost, Fuel Press, Oil Press, Oil Temp, Trans Press, Trans Temp, Coolant Temp Sensors, TR Drop Kit, StopTech BBK, TR Disc Conv, Stainless braided brake lines, -6AN Stainless braided Fuel lines from rail to tank, -6AN Stainless braided transmission cooler lines w/Earls Cooler, Stainless braided Powersteering lines w/Custom reservoir
    Does anyone know if the behind the grill light bar for the 2nd Gen will work with the URD true cold air intake? I was thinking about getting the light bar, but wanted to be sure it would work since I already have the intake.
  2. Nov 27, 2012 at 7:47 AM
    acdronin
    acdronin Well-Known Member
    The bar should clear it because the mounts for the bar are above the area where the CAI come through
  3. Nov 27, 2012 at 7:50 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I think the bar itself will fit but putting lights back there might be a problem.
  4. Nov 27, 2012 at 7:52 AM
    armyoffoo
    Houston, TX
    Do you know how far forward from the radiator do the mounting bars sit? Just want to make sure there is room for the tube and filter element behind the light bar. Also, the intake uses the same mount as the light bar, but that might not make a difference.
  5. Nov 27, 2012 at 7:53 AM
    armyoffoo
    Houston, TX
    Cool, I was just going to do one LED bar at the bottom if it will fit.
  6. Nov 27, 2012 at 7:54 AM
    acdronin
    You can kind of get an idea with mine
  7. Nov 27, 2012 at 1:25 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    might only have the driver side half of the bar as usable mounting space
  8. Nov 28, 2012 at 12:47 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Yea only about 2/3rds of it wouldn't be useable. My dad had the TCAI and he had to trim his stock grill to make it fit.
  9. Nov 28, 2012 at 10:14 PM
    armyoffoo
    Houston, TX
    He had to trim the grill to fit the light bar, or the lights? I am only looking to get an LED bar that I would place towards the bottom of the grill, so it would hopefully fit under the intake.
  10. Nov 28, 2012 at 10:17 PM
    armyoffoo
    Houston, TX
    Yeah, I guess it won't fit. Looks like the triangle brace in the middle would interfere with the filter element. Guess I'll have to come up with something else.:(
  11. Nov 28, 2012 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No he had to trim the girl to fit the intake.
    It sit low so maybe above. But I kinda doubt it..
