BAMF behind the grill light bar
Discussion in 'Bay Area Metal Fabrication' started by JLee, May 30, 2012.
  1. Nov 29, 2015 at 6:51 PM
    #561
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Pretty sure it spans 20". Anything larger is wasted being behind the grill
  2. Nov 29, 2015 at 7:09 PM
    #562
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The main bracket is only 25" wide so you can't get a 30" on the dropdowns. You can however mount a 30 in there if you have a light with sliding mounts on the bottom of the light.
  3. Nov 29, 2015 at 7:17 PM
    #563
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
    Sadly, mine will be on the side..
  4. Nov 29, 2015 at 7:18 PM
    #564
    JLee
    Jerry
    Grass valley CA
    24.5" would be max on the side.
  5. Dec 7, 2015 at 10:03 AM
    #565
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    got my 1st gen mount Saturday, was gone so didnt open it till this morning but couldnt be happier! looks killer and some nice beads laid down on it! gonna take the front of the truck apart tonight ill post up some pics, thanks!
    ChadsPride likes this.
  6. Dec 7, 2015 at 10:06 AM
    #566
    JLee
    Jerry
    Grass valley CA
    Glad you like it please do post pics we don't get many orders for the 1st gens so I'd like to know what lights work.
  7. Dec 7, 2015 at 10:06 AM
    #567
    FlapJack935
    Jack
    Abq New Mexico
  8. Dec 31, 2015 at 6:52 PM
    #568
    Danny1956
    Danny1956 Well-Known Member
    Danny
    2015 Toyota Tacoma 4x4
    I ordered my BAMF Bracket this week can't wait to get it .im waiting to get my bracket before I get my light so I can measure what size I could get. I would like to get the Opt7 22 inch but not sure if it will fit. Also about how long before its gets shipped to me? Thanks
  9. Jan 5, 2016 at 4:51 PM
    #569
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Has there ever been any issues with ~7" lights and the trans cooler??? That's my only worry.
  10. Jan 5, 2016 at 5:25 PM
    #570
    G.T.
    G.T.
    CONUS
    IPF 900's
  11. Jan 5, 2016 at 7:01 PM
    #571
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Is there any depth restriction for the center mount? I'm leaning towards 6" KC Pro-Sport's... which are 4.5" deep.
    edit: looks like I'd need at most 2.5" behind the mounting stud/hole. Doable for the center?
  12. Jan 22, 2016 at 12:57 PM
    #572
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Sorry, was wondering if anybody could give me an answer on this. Looking for the depth between the center mounting hole of the BAMF bar and the radiator brace.
  13. Jan 22, 2016 at 1:23 PM
    #573
    Danny1956
    Danny
    I thought that the brackets went under the bar I just got one but the weather has been cold and nasty so I haven't got mine in yet? Is the way you have it the right way or is under the way?
  14. Jan 22, 2016 at 2:18 PM
    #574
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    That's not my picture - it's from the OP. I just drew a couple lines on it.
    I don't plan on using those LED brackets, but I would imagine it wouldn't matter if they're over or under - as long as they're tight.
  15. Jan 23, 2016 at 12:18 PM
    #575
    JLee
    Jerry
    Grass valley CA
    It does go under the bar the design has been changed I just need to update the pictures.
  16. Jan 23, 2016 at 12:23 PM
    #576
    ThomasMore66
    Dallas/Fort Worth & Durango
    You can fit lots of things on this set-up.
  17. Jan 23, 2016 at 12:28 PM
    #577
    JLee
    Jerry
    Grass valley CA
    I know there has been a few guys to install the 7" HID's so I'm sure you would have enough room for those as long as your grille will allow it.
  18. Jan 27, 2016 at 5:32 PM
    #578
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I know it has been stated that 20" is about the maximum size for a light bar, but has anyone successfully put in a 21.5" bar? It seems to be a fairly common size.
  19. Jan 27, 2016 at 5:55 PM
    #579
    Danny1956
    Danny
    I'll be putting that size bar in mine this weekend and it has been told that it does fit
  20. Jan 27, 2016 at 6:17 PM
    #580
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Cool. Let me know how it goes. Thanks.
