BAMF behind the grill light bar
Discussion in 'Bay Area Metal Fabrication' started by JLee, May 30, 2012.
  1. Jan 27, 2016 at 6:37 PM
    #581
    Danny1956
    Danny1956 Well-Known Member
    Danny
    2015 Toyota Tacoma 4x4
  2. Jan 28, 2016 at 5:36 AM
    #582
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's shouldn't be a problem there is about 24" between the led mounts at the widest mounting hole.
    PoweredBySoy[QUOTED] likes this.
  3. Feb 18, 2016 at 12:19 PM
    #583
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Missed the GB but got in on the deal o the day today for this bracket, stoked, seems to be the best way. I thought about trying to make my own mounts, this is much cleaner than I could ever make. will be putting a 20" bar in lower opening of stock grill :thumbsup:
    JLee[OP] likes this.
  4. Feb 18, 2016 at 1:11 PM
    #584
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Whoa, sweet.
    Ordered.
  5. Feb 18, 2016 at 1:21 PM
    #585
    Old School
    Old School You are ignoring covfefe by this member.
    I have a 20" bar in mine, you can see there's still plenty of room!
    rogs6266 and JimboAnz like this.
  6. Feb 19, 2016 at 6:59 PM
    #586
    rogs6266
    rogs6266 Well-Known Member
    Alliance, OHIO
    '13 TRD Sport 4X4 DCLB MGM
    SOS weld on sliders, SOS bed rack, SOS front aluminum winch bumper with center and head light hoops, Stealth 6 wheels wrapped in goodyear duratracs, 285-70/17 Beer opener in bed, Thule roof rack on factory rack, Tool box, bed mat, K&N cai, flowmaster side out duals, and tailgate extender, Fog light anytime mod, no mud flaps mod Weathertech full set, Wet okoles front and rears, full OME 886 suspension lift with Dakars in rear, smittybilt X20 comp 10 winch, factor 55 yellow pro link,
    Order placed, payment sent! Thank you!!
    JimboAnz likes this.
  7. Apr 4, 2016 at 9:05 AM
    #587
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    For anybody searching - a 6" KC Prosport will not fit in the center mount. Not even close. The main problem is the wire out of the back of the housing. Even without that though, it would still be too deep to fit. I'm returning the single Prosport and ordering a 6" KC Slimlite, which should have no problem.
    For the driver-side light (another Prosport) I had some interference with the tran cooler. I had to disconnect a couple of the cooler brackets and bend the cooler back about an inch. Seems fine now.
  8. Apr 14, 2016 at 12:19 PM
    #588
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
  9. Apr 14, 2016 at 1:02 PM
    #589
    JLee
    Jerry
    Benicia, CA
    We don't offer group buys any longer these are on sale 4 times a month. We do have a few blems they we sell for 30% off if you want to save some money all cosmetic blems they will function the same way as a non blem.
  10. Apr 14, 2016 at 1:03 PM
    #590
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
  11. Apr 14, 2016 at 1:08 PM
    #591
    JLee
    Jerry
    Benicia, CA
    Sorry no pics on blems they are all different.
  12. Apr 14, 2016 at 1:16 PM
    #592
    G.T.
    G.T.
    CONUS
    I have one of the original Elusive Elements / Black Diamond Fab light bars and it rocks. These things give you so many more options when it comes to mounting accessory lights safely. The added bonus is that they are secured behind the grill so jerks won't be twisting them on their mounts or worse, stealing them.
    I just ordered a pair of the LED light bar brackets that bolt right up to the light bar from @JLee as I plan to make some changes and remove the IPF 900's but I will always keep this light bar bracket on the truck. If you are thinking about putting your lights behind the grill, this is the absolutely best way to do it and it's completely reversible if for some reason you decide you don't like it or want to swap it over to your new Tacoma.
  13. Apr 14, 2016 at 1:18 PM
    #593
    JLee
    Jerry
    Benicia, CA
    Yep the only change done to the brackets when I bought the design was the logo on them they are still the same cut file.
    G.T. likes this.
  14. Apr 14, 2016 at 4:05 PM
    #594
    ThomasMore66
    Dallas/Fort Worth & Durango
    Can't do this without the BAMF bar!
    ChadsPride likes this.
  15. Apr 14, 2016 at 4:11 PM
    #595
    SoCal_Yotas
    SoCal_Yotas Well-Known Member
    Elias
    Santa Clarita
    2015 Toyota Tacoma TRD-Sport 4x4
    Can I get a quote for a blemished one?
    Edit: nevermind I checked the website haha:facepalm:
  16. Apr 14, 2016 at 4:21 PM
    #596
    ThomasMore66
    Just get one. Some of the best money I've spent. And there is a cool sticker...
    SoCal_Yotas[QUOTED] likes this.
  17. Apr 14, 2016 at 4:26 PM
    #597
    SoCal_Yotas
    Elias
    Santa Clarita
    I might be in just for the sticker...if I do anyone got a lights bar that's fits in the grill for sale?:D
  18. Apr 14, 2016 at 5:29 PM
    #598
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Love it. Thanks, Mr. BAMF
    ChadsPride, Pirhett and ThomasMore66 like this.
  19. Apr 14, 2016 at 6:16 PM
    #599
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    @dcsbtaco this!
  20. Apr 14, 2016 at 6:23 PM
    #600
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    What size are the lights as I currently have Hella 500's behind mine.
