BAMF behind the grill light bar
Discussion in 'Bay Area Metal Fabrication' started by JLee, May 30, 2012.
  1. Apr 14, 2016 at 6:30 PM
    #601
    ThomasMore66
    Dallas/Fort Worth & Durango
    Led's FTW!
  2. Apr 14, 2016 at 6:44 PM
    #602
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    From what I understand, not for distance, which is what I was going for. Some day I'll get a LED bar on the roof for trails.
    The ambers are KC Pro-sport HID and the center lights are KC Slimlite spots (HID's wouldn't fit).
  3. Apr 14, 2016 at 6:48 PM
    #603
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    If I have one complaint about the BAMF bar, it would be that I wish it would adjust to a higher position. I currently have it maxed out to the highest setting, and I still think the rounds sit a tad too low in the grill.
  4. Apr 14, 2016 at 6:49 PM
    #604
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Agreed and you didn't tell me what size the lights are Brother.
  5. Apr 14, 2016 at 6:49 PM
    #605
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Yesh!
    Unchained 5150 likes this.
  6. Apr 14, 2016 at 6:50 PM
    #606
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    We have done one inverted for that with the 2012+ grilles but you will have to really cut up your grille to get it any higher.
  7. Apr 14, 2016 at 6:51 PM
    #607
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    They're 6" lights...... roughly. The HID's are a bit bigger than the Slimlites, but KC still classifies them as 6".
  8. Apr 14, 2016 at 6:52 PM
    #608
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Yeah, I considered inverting it, but..... yeah... :sawzall:
    It looks 90% alright with 6" lights though. I'm not really complaining. Good product.
  9. Apr 14, 2016 at 6:55 PM
    #609
    JLee
    Jerry
    Grass valley CA
    If you ever get the itch to do it let me know we can make one with the top tabs on the bottom so you can center the round lights.
  10. Apr 14, 2016 at 6:59 PM
    #610
    ThomasMore66
    I think it's perfect.
  11. Apr 14, 2016 at 7:02 PM
    #611
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Appreciated, but I'm perfectly fine as it is. I would imagine 7-8" lights would be even more off-center though.
  12. Apr 14, 2016 at 7:03 PM
    #612
    JLee
    Jerry
    Grass valley CA
    Yes they would be.
  13. Apr 14, 2016 at 7:03 PM
    #613
    Pirhett
    Rhett
    San Diego
    Stock...
    Not like you hit bumped
  14. Apr 14, 2016 at 7:07 PM
    #614
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I think my lights look more centered than Unchained's - which probably has to do with the manufacturers mounting hardware. Don't get me wrong, Unchained's truck looks f'in awesome, but those lights look seated too low in the grill.
  15. Apr 14, 2016 at 7:15 PM
    #615
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Your lights look more like they are pointing straight forward as well. Mine aim towards the road, I can actually see the two yellow circles out over the hood on the road while driving. So maybe if I straightened them out it wouldn't look as deep in the grill
  16. Apr 14, 2016 at 8:23 PM
    #616
    ThomasMore66
    You guys need to forget all those old-school round lights.
  17. Apr 15, 2016 at 4:16 AM
    #617
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
  18. Apr 15, 2016 at 4:55 AM
    #618
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have my Hella's wired into an OEM switch, is there a way to add more Hella's onto the same switch so I can have 4 lights?
  19. Apr 15, 2016 at 5:22 AM
    #619
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I would certainly think so, but can't say for sure. My friend (who's an electrician) wired them up for me - fuse block and all. They're all on one rocker switch. He threw about 90% of the included wiring harness away - saying it was junk - and wired up his own stuff.
  20. Jun 10, 2016 at 7:53 PM
    #620
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Most of the harnesses that come with them are junk. You use a relay so the amperage isn't going through you switch... it stops at the relay. So you could have 100 lights on a single switch as long as they don't exceed the rating of the relay. You can run multiple relays from a single switch yada yada.
    What's the ETA on these? I've been watching and seeing they are backorder... then I found this thread. Sorry if it's been stated already I didn't look that much for my answer lol :p
