BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. Feb 4, 2019 at 4:04 PM
    #541
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Nice. The install really isnt too bad. I used 3 or 4 different size bits and was able to get through each side in about 45 minutes. Punching the rivet right in the center is key
  2. Feb 4, 2019 at 5:29 PM
    #542
    TWTaco
    TWTaco Well-Known Member
    Dave
    Thanks , that is my plan of attack. Is this a one man job?
    upTOPOverland_Drew likes this.
  3. Feb 4, 2019 at 6:13 PM
    #543
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Sure is! Obviously it would be easier/faster with someone else doing one side while you're doing the other, but there isn't any time when 4 hands are needed. :cheers:
    TWTaco[QUOTED] likes this.
  4. Feb 4, 2019 at 10:49 PM
    #544
    heffer
    Jeff
    Los Angeles
    Definitely doable with 1 person. I did 1 side each night by myself after work. If you're local to Los Angeles, I'm down to help you out if needed
  5. Feb 5, 2019 at 9:00 AM
    #545
    TWTaco
    Dave
    Thanks i will let you know! I appreciate the offer!
  6. Feb 5, 2019 at 9:16 AM
    #546
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    One of my favorite mods on my truck.
  7. Feb 8, 2019 at 9:00 PM
    #547
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I would say 2 people would be needed if your not in good shape. It kicked my ass by myself. My arms are killing me. I'm not in shape like I used to be. I fully removed leafs though. Needed new bushings . Expos are heavy. If your only doing the hangers probably not that big a deal. But if your bushing are a few yrs old replace them while your there. My front ones were tore up more then I would of thought.
    TWTaco likes this.
  8. Feb 9, 2019 at 10:59 AM
    #548
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    I've removed my expos so many times alone that I have a nice easy process flow now. They are heavy as fuk thoigh! Haha. I bought bushings to replace mine as well (6 years old), but surprisingly they were damn near perfect so I just cleaned them up and put them back in.
  9. Feb 9, 2019 at 7:38 PM
    #549
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Wow, the front on mine both sides the spring Doug into the bushing. It was full of mud as well.
    The space had at least 1/8 in of play. Rears looked good.
  10. Feb 10, 2019 at 6:50 AM
    #550
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It never same about we had so little orders of it I refunded the people that ordered one. I'll have one designed later but making one not is not a high priority as not many were interested.
  11. Feb 10, 2019 at 7:01 AM
    #551
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Easy enough to make one. If you dont have the skill too any local shop could make one easy.
    whatstcp likes this.
  12. Feb 15, 2019 at 12:35 PM
    #552
    TWTaco
    Dave
    Has anyone installed the Icon RXT leaf packs with the BAMF shackles. Will they work Shackles and hangers? Maybe switching to the RXT's
    BroID likes this.
  13. Feb 15, 2019 at 1:34 PM
    #553
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Got these in the mail last week, going to install tomorrow, I have Dakars, anybody have a recommended cut line for that 2nd leaf?
  14. Feb 16, 2019 at 3:06 PM
    #554
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Question for the group. I have Dakars, I got the hangers and shackles. Trimmed the leafs honestly did all the ‘hard’ stuff.
    My question though, I was unable to use the supplied grade 8 bolt that is meant to connect the shackle to the leaf. I reinstalled the stock bolt so I could get rolling again but there is a little play between the eyes of the shackle and the bolt? Do I need to take that bolt out, and drill the sleeve in the bushing to 9/16”? Do you have another suggestion?
  15. Feb 16, 2019 at 3:27 PM
    #555
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I’m using BAMF shackles. Do I need to drill the bushing in the Dakars out too? Like I said the play is between the stock shackle bolt and the BAMF shackle
  16. Feb 16, 2019 at 5:00 PM
    #556
    upTOPOverland_Drew
    Drew
    Littleton, CO
    yeah i know, not about to bother Jlee and Jberry and their godly existence. so much respect for those two.
    Isaiah92 likes this.
  17. Feb 16, 2019 at 5:22 PM
    #557
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Go to McMaster Carr and order the right sized hardware. It will be fine for a short period of time driving the streets, but will wallow out the hole if left in.
  18. Feb 16, 2019 at 6:00 PM
    #558
    upTOPOverland_Drew
    Drew
    Littleton, CO
    How do I find measurements to do something like that? Pardon my ignorance.
  19. Feb 17, 2019 at 7:17 AM
    #559
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    mine came with all new hardware in the rear only reused front spring bolt. If your using the shackle only without the HD hangers then you might have to get different bushing sleeves/spacers. Pics would help.
  20. Feb 17, 2019 at 7:11 PM
    #560
    upTOPOverland_Drew
    Drew
    Littleton, CO
    thanks, i got it figured out, bought a 9/16" drill bit and drilled out the sleeve. It was a bit of a PIA but I got it and my truck is sitting pretty now
