BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. Oct 27, 2017 at 2:57 PM
    #41
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yes they will have their own part numbers on the site so you can order them later if you like.
  2. Oct 27, 2017 at 2:58 PM
    #42
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Awesome, thanks
  3. Nov 4, 2017 at 9:37 PM
    #43
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Are these in stock and ready to ship?
  4. Nov 4, 2017 at 10:24 PM
    #44
    JLee
    Jerry
    Grass valley CA
    No these are pre orders nothing is in stock.
    No we don't not until I install one.
    socataco[QUOTED] likes this.
  5. Nov 7, 2017 at 10:18 AM
    #45
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    In for the pre-order!
    ARCHIVE likes this.
  6. Nov 8, 2017 at 6:44 PM
    #46
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Any update on the status of these guys? Thanks
  7. Nov 9, 2017 at 5:39 AM
    #47
    JLee
    Jerry
    Grass valley CA
    All 50 sets of the hangers are just about prepped and ready to weld. With the Thanksgiving sale going on right now it's a little crazy around here. Id say about two weeks the hanger only orders will start shipping out. I'm still working on fine tuning the shackle and cross-member before production starts on those.
  8. Nov 9, 2017 at 7:22 AM
    #48
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    :woot:
  9. Nov 9, 2017 at 7:34 AM
    #49
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    So, why would you choose this option instead of just going to a shackle flip?
  10. Nov 9, 2017 at 7:40 AM
    #50
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Because shackle flips suck.
  11. Nov 9, 2017 at 7:48 AM
    #51
    GDT
    Ok, so why do shackle flips suck? 1st gens, and a lot of other trucks use traditional righside-up shackles and I haven't heard them complaining or converting to our style of upside down shackles. Legitimately curious here.
    DaveInDenver likes this.
  12. Nov 9, 2017 at 7:51 AM
    #52
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i know i'm going back to inverted to get my spring back in proper arch while not lifting the crap out the rear. with the flip, i was running negative arch at ride height. moving the rear of the spring back up will allow me to run a 3" lift spring and only gain a minimal height difference from where i currently am, but my springs will be able to work properly giving me a better overall ride.
    in a lot of situations, the limiting factor on our droop is the shocks and leaf pack chosen. with a proper shock and spring setup, you can obtain similar droop results as many with the shackle flip
    JLee[OP] likes this.
  13. Nov 9, 2017 at 7:53 AM
    #53
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    BassAckwards, akkyle, Jim Bob and 3 others like this.
  14. Nov 9, 2017 at 8:53 AM
    #54
    JLee
    Jerry
    Grass valley CA
    And the frames and suspension systems were designed to use them. To properly make a 2nd or 3rd gen Tacoma use a standard shackle would be cutting off and fabricating new front leaf mounts and having a custom leaf pack made cycled to bump with the proper shackle length. Just flipping them and tossing them on the truck provides more negative results then positive.
  15. Nov 9, 2017 at 9:40 AM
    #55
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    straight to the point!
    12TRDTacoma likes this.
  16. Nov 9, 2017 at 10:03 AM
    #56
    Adventurous
    Colorado
    15 DCLB SR5
    Think about the shackle angle of an inverted setup throughout the range of motion. At ride height, the shackle is vertical (or darn close), meaning that as the springs compress, the shackle remains in tension and almost all of the force takes place in the vertical plane. When a wheel droops, the shackle rotates forward, but any upward force encountered will always try to move it back into the vertical position before the springs really start to compress.
    When flipped, the shackle is always at an angle. During spring compression, as the shackle moves closer to parallel to the frame, more and more force is directed in the horizontal plane, diminishing the vertical component of the force imparted.
    On a vehicle designed for it, traditional shackles perform fine. On a vehicle designed for inverted shackles, flipping them turns into a very complicated game of dynamics to ensure ride quality doesn't suffer.
  17. Nov 13, 2017 at 11:51 AM
    #57
    ragincajun35
    Spencer
    Louisiana
    See Builds....
  18. Nov 14, 2017 at 1:52 PM
    #58
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Any update on the crossmember?
  19. Nov 14, 2017 at 1:55 PM
    #59
    JLee
    Jerry
    Grass valley CA
    No it's just going to be a tube crossing between the two I won't have anything built until I get a truck in the shop to fit it on.
  20. Nov 14, 2017 at 2:07 PM
    #60
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    Is it going to be straight? Or bent to make it high clearance? Just trying to picture how it’s going to work/look.
