BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. Aug 28, 2019 at 9:11 PM
    #801
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Forgive me but did I install my shackles in the wrong orientation?
    Is this correct?
    I installed mine with the zero fittings pointed towards the rear of the rig. The thought was that when flexed out, the zero fitting could come in contact with the bottom of the "craddle" of the brackets.
    @JLee
    EDIT: My installation
  2. Aug 28, 2019 at 9:13 PM
    #802
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Those are installed incorrectly. that gusset goes towards the back of the hanger.
  3. Aug 28, 2019 at 9:14 PM
    #803
    geekhouse23
    Zerk downward?
  4. Aug 28, 2019 at 9:15 PM
    #804
    JLee
    Jerry
    Grass valley CA
    the second picture didn't show up at first those are wrong!
  5. Aug 29, 2019 at 4:06 AM
    #805
    geekhouse23
    Thanks Jerry. On my list for this weekend to swap them 180 degrees
    JHEAL77 likes this.
  6. Aug 30, 2019 at 1:42 PM
    #806
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Hey Jerry,
    As you know (I've been hassling you lately) I picked up a set of these hangers. I'm now mentally preparing for the install...
    I know your instructions say that the best tool for removing the rivets is a plasma cutter, but I have no idea how to use one, nor would I trust myself not to blast a hole in my frame.
    As an alternative, I was wondering if you think this method would have any merit... Grind off the rivet heads with an angle grinder, down to the existing hangers. Use a pry bar/chisel to remove the hanger. Then use an induction current (just picked up a Mini-Ductor II from a TW member) to heat up the remaining rivet shaft to cherry red and knock it out with a BFH.
    https://www.youtube.com/watch?v=uimEZKrVNO0&t=605s
    Do you see this working or having any ill affects that I'm not thinking of?
    Mully likes this.
  7. Aug 30, 2019 at 1:50 PM
    #807
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    That thing is bitchen. Anything to make the job easier is a big plus. The rivets are no joke. I kept them as a trophy. Good luck.
    CharlieCafe and Bertw192[QUOTED] like this.
  8. Aug 30, 2019 at 1:59 PM
    #808
    JLee
    Jerry
    Grass valley CA
    I don't see why not as long as you can fit it on them without over heating everything else. It might put a lot of unneeded heat to the frame as I'm sure the heat will spread onto the frame as well. So that BFH could do some frame damage if that too is glowing red hot and you hit it. Just something to watch out for.
    Anderson, Mully and Bertw192[QUOTED] like this.
  9. Aug 30, 2019 at 6:49 PM
    #809
    17SandTaco
    17SandTaco Well-Known Member
    Conifer, CO
    2016 Tacoma OR
    Do the shackles work with Icon RXT springs?
  10. Aug 31, 2019 at 6:02 AM
    #810
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Icons are similar to OME on the rear wrap style.
  11. Sep 1, 2019 at 4:01 PM
    #811
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    This is what I received for hardware. Anyone know if this is correct? I’ll make it work, whichever the case.
    My only concern are the two longest bolts which thread the schackle into the hanger, they just seem too long.
  12. Sep 1, 2019 at 4:31 PM
    #812
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    The shorter two of the four longest bolts are the incorrect hardware if yours are like his pic. The longer bolts go through the shackle and leaf eye and the "correct" shorter bolt goes through the shackle into the hanger.
    The left bolt is this pic is the correct one. If you have the bolts that look like the one on the right contact Jerry and he will send you two replacements.
    Mully likes this.
  13. Sep 1, 2019 at 4:46 PM
    #813
    Grossomotto
    2017 4WDV6LB6MT
    Thx, this is what I got. Also, I’ve got extra hardware from other shackles that I can use, I’ll see if I need anything else.
    CharlieCafe[QUOTED] likes this.
  14. Sep 2, 2019 at 9:12 AM
    #814
    Grossomotto
    2017 4WDV6LB6MT
    Just got the easy part done with all the hardware, but not sure the zerk will be assesible. I’ve put enough joint grease to last awhile.
  15. Sep 2, 2019 at 9:23 AM
    #815
    Grossomotto
    2017 4WDV6LB6MT
    They’re 20% off today with everything else, if you do.
  16. Sep 2, 2019 at 9:28 AM
    #816
    geekhouse23
    Flip those shackles around. Those are backwards. I confirmed with Jerry last week.
    Mully and Bertw192 like this.
  17. Sep 2, 2019 at 9:30 AM
    #817
    Grossomotto
    2017 4WDV6LB6MT
    I had them the other way, then flipped them this way.
  18. Sep 2, 2019 at 9:30 AM
    #818
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm not certain, but I think those shackles are installed backwards. Gusset of the shackle towards the rear... right @JLee ?
    Mully likes this.
  19. Sep 2, 2019 at 9:31 AM
    #819
    geekhouse23
    https://www.tacomaworld.com/threads/bamf-hd-shackle-hangers.496200/page-41#post-21431072
    Bertw192[QUOTED] likes this.
  20. Sep 2, 2019 at 9:32 AM
    #820
    TWTaco
    TWTaco Well-Known Member
    Dave
    [​IMG]It should look like this.
    Toynado, Mully, jeff b and 2 others like this.
