BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. May 6, 2020 at 2:47 PM
    #1221
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I wish I had pneumatic when I did mine... I have access to them now, and wouldn't mine giving them ago.
    Nopro and Mully[QUOTED] like this.
  2. May 6, 2020 at 2:51 PM
    #1222
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    No matter how you get them out, it's all just a big pain in the ass.
  3. May 6, 2020 at 2:54 PM
    #1223
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's really not that bad with a plasma both sides in 10min or less.
  4. May 6, 2020 at 3:10 PM
    #1224
    Mully
    CA
    Nice, I soooooo wish I had one when I did this mod.
    17SandTaco and Nopro like this.
  5. May 6, 2020 at 3:16 PM
    #1225
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    ...because everyone has plasma cutter in the garage..... except me. :annoyed:
    Anderson and Mully like this.
  6. May 6, 2020 at 3:21 PM
    #1226
    Mully
    CA
    It's one of those tools that you think you'll never need it until you do, and then you wish you had bought it when you saw it on sale. Now your willing to spend twice as much to get it.
    Anderson and zippsub9 like this.
  7. May 6, 2020 at 6:29 PM
    #1227
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    ...so i see you have broken leaf..uh what brand was that?..surely not allpoo?
    Deaver stage 3 are next?
    you'll get to redo all those bolts, sort of like re-doing this mod, but no grind, no hammer...no need for plasma..
    i was just thinking those new leafs i placed with this mod are sagging..and need a re-do, I so don't want to re-do
  8. May 6, 2020 at 6:38 PM
    #1228
    Mully
    CA
    Such Allpoo Expedition springs. Just look how awesome they are, I just gotta get another set.
    • A higher number of thinner leafs provides a smoother, progressive spring rate compared to fewer, thicker leaves
    • Double “military” wrap provides extra strength for the main leaf
    • “Torque Leaf”, an extra half-leaf at the top of the spring pack, increases anti-wrap properties without hindering travel or ride quality
    • Diamond-cut leaf ends to eliminate stress points which may weaken leafs and lead to premature failure
    • Teflon anti-friction pads between leafs provide smoother flex, lessen spring wear and reduce noise
    • Leafs are shot-peened after forming to relieve stress
    • Every completed spring pack is pre-cycled to their travel extremity for quality control and to reduce the likelihood of initial sag
    • Comprehensive 12-month warranty for non-racing applications when properly installed
    • Sold in Pairs
    sawbladeduller[QUOTED] and Nopro like this.
  9. May 15, 2020 at 7:23 PM
    #1229
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    the lower shackle bolt is not threading into the bolt that is inside the hanger on my bamf hangers. I haven't stripped anything as I have only tried hand tightening and I can not get it to thread. I am scared to use a wrench and strip it. anyone else have this issue? I tried oiling the threads and still no dice. (I am assuming I am using the shorter two bolts that came in the package for this ? Kind of at a stand still until I get figure this out. I hope I didn't get the wrong hardware as I live in Canada and can't afford to wait another 3 weeks. I have lightly tried all 4 bolts into both hangers and no luck so I know it isn't just a problem with one hanger.
  10. May 15, 2020 at 8:01 PM
    #1230
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    here is the write up on it
  11. May 15, 2020 at 8:03 PM
    #1231
    Dye22
    Squamish
    '15 TRDOR ACLB
    That doesn't help me
  12. May 15, 2020 at 8:21 PM
    #1232
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    :facepalm::facepalm:
    I thought you were asking another question. My bad
  13. May 15, 2020 at 8:25 PM
    #1233
    Dye22
    Squamish
    '15 TRDOR ACLB
    all good man! Yea i know what has to be done but the hardware isn't working.
    Red18Taco707[QUOTED] likes this.
  14. May 15, 2020 at 8:27 PM
    #1234
    Mully
    CA
    Clean the threads with a thread chaser. Good luck with your truck.
  15. May 15, 2020 at 8:29 PM
    #1235
    Dye22
    Squamish
    '15 TRDOR ACLB
    I did :(, brush wheeled the bolts, cleaned and oiled inside the bolt and still no luck. thanks though!
  16. May 15, 2020 at 8:31 PM
    #1236
    Mully
    CA
    Tap the bolt lightly with a hammer as you thread it in.
  17. May 15, 2020 at 8:42 PM
    #1237
    Dye22
    Squamish
    '15 TRDOR ACLB
    Ill try it in the morning, I have never had to do that with anything before though, especially not brand new clean hardware.
    It just might be i need to just use a wrench but I also feel like it shouldn't be binding it like it is. The bolt barely wants to go into the nut at all. leaning towards the threading is mismatched.
  18. May 15, 2020 at 8:44 PM
    #1238
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Something doesn’t look right in the picture. Why not just use stock hardware to get it back together until you can get clarification? Did you put a tap into the threaded hole? If it is hard by hand like pictured, then it is sure to screw up those fine thread when trying to thread it through a leaf eyelet.
  19. May 15, 2020 at 8:51 PM
    #1239
    Dye22
    Squamish
    '15 TRDOR ACLB
    I don't have a tap/dye set so it isn't that easy. I also can't use stock hardware because the stock hanger is gone and the bamf hanger uses a different design for the lower shackle bolt.
  20. May 15, 2020 at 9:01 PM
    #1240
    zippsub9
    Halfmoon, NY
    14 DCLB
    sorry, I still have mine boxed up. Anyway it could possibly be a different bolt instead of the one you are trying to use?
