BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. Oct 21, 2020 at 9:51 PM
    #1361
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    rj_taco[QUOTED] likes this.
  2. Nov 3, 2020 at 11:21 AM
    #1362
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    I'm starting to think I can do this myself.
    So, no drilling or air hammering?
    Just grind down then press out?
    Thx, Mark
  3. Nov 3, 2020 at 11:32 AM
    #1363
    Taco-Obsessed
    I grinded, drilled, and pressed.
    TacoEspecial[QUOTED] likes this.
  4. Nov 3, 2020 at 11:36 AM
    #1364
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    Agree, you can do this yourself. various methods may be needed.
  5. Dec 3, 2020 at 3:45 PM
    #1365
    SLCGUY
    SLCGUY Well-Known Member
    Kyle
    Salt Lake City
    2015 Silver Sky Tacoma TRD Off-Road
    Anybody have any shoulda-coulda-woulda on their installs?? Going under the knife hopefully in the next week.
    Nopro likes this.
  6. Dec 3, 2020 at 4:59 PM
    #1366
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I forgot to fill my beer fridge before hand. Didnt realize until halfway through. :( Total fuckup on my part!
  7. Dec 3, 2020 at 5:28 PM
    #1367
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    I had adequate cans of Revision DIPA on hand. My bullshit problem turned out to be wearing a Fleece garment that was showered with steel shavings from excess use of the grinder, and that garment was thrown out. serves me right for not dressing for success. I annoyed my neighbors because I have a foul mouth and i worked on this project in the street for more than two days. If your cool you'll get this done in a few hours.
    TacoEspecial, SLCGUY and Nopro like this.
  8. Dec 3, 2020 at 6:04 PM
    #1368
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    2014 dcsb Trd Offroad
    Icon stage 5 and 295’s
    Plasma cutter makes everything so much easier and faster. It’s not terribly difficult, it’s just monotonous grinding and drilling. Earplugs are a good idea too.
  9. Dec 3, 2020 at 6:27 PM
    #1369
    SLCGUY
    Kyle
    Salt Lake City
    AMPLE Beer--- Check!
    Makes sense, wear shitty clothes, & I luckily have a garage i can fit in, its cold AF in Utah rn so i'll be pumping the heater no doubt. Thanks!
    Did a hard ponder on a plasma rental, have a local Sunbelt Rentals that'll rent them out for $65 a day.. but i think im going with the grind and grade 8 bolt/press technique because that shits sitting in the toolbox. Also have some step drill bits on standby. & earplugs is solid advice thanks!
    Nopro[QUOTED] likes this.
  10. Dec 3, 2020 at 6:51 PM
    #1370
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    You're good. Drill/grind the heads off and punch them through. A lot of folks in this thread make it out to be way more difficult then it really is. Certain rivets are easier with the grinder, others easier with drill bits/step drill. Dealer's choice! :cheers:
  11. Dec 3, 2020 at 7:37 PM
    #1371
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    I ground down the rivets then hit the stock hangers with a bfh. Ground them down again then plasma and an air hammer. Still have to drill the holes for the new hardware.
    Grossomotto and SLCGUY like this.
  12. Dec 6, 2020 at 6:02 PM
    #1372
    StokeTRD
    StokeTRD Well-Known Member
    2019 TRD OFFROAD
    Which Grease Pins are these ? can dm me a link or brand and size please. Thank you
    geekhouse23 likes this.
  13. Dec 7, 2020 at 5:09 AM
    #1373
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  14. Dec 8, 2020 at 6:54 AM
    #1374
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Do these hangers provide any lift?
    Nopro likes this.
  15. Dec 8, 2020 at 6:55 AM
    #1375
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    Nope, just beefy as hell!
  16. Dec 8, 2020 at 6:55 AM
    #1376
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Thanks
  17. Dec 8, 2020 at 9:16 AM
    #1377
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Grossomotto[QUOTED] likes this.
  18. Dec 8, 2020 at 9:19 AM
    #1378
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Go to Autzone and rent a balljoint press kit.
    Drink a beer
    Grind the rivets flat
    Drink a beer
    Use a short 1/2" bolt to press the body of the rivet out
    Drink a beer
    Bolt up you new shackle hangers
    Yell at your "helper" who emptied the beer fridge while you were working.
  19. Dec 8, 2020 at 9:23 AM
    #1379
    geekhouse23
    The install isn't THAT bad to the point where you need a plasma/liquid wrench. Would it make it easier? Sure. Taking your time and many hands make light work.
  20. Dec 8, 2020 at 9:25 AM
    #1380
    Arcticelf
    Gladiator
    Having use a plasma and a ball joint press to take those rivets out: the press is easier and more pleasant.
    Cutting blind holts with a plasma in a confined space sucks.
