BAMF High Clearance rear bumper "Modular DUAL swing out"
Discussion in 'Bay Area Metal Fabrication' started by JLee, Nov 20, 2019.
  1. Jun 6, 2020 at 10:46 AM
    #441
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Oh yeah
    madsand and Jcmartin11b[QUOTED] like this.
  2. Jun 6, 2020 at 10:46 AM
    #442
    Jcmartin11b
    Jcmartin11b Well-Known Member
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Thank you!
  3. Jun 6, 2020 at 10:47 AM
    #443
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    :sawzall:
  4. Jun 6, 2020 at 5:09 PM
    #444
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    i should have them back Tuesday the 16th. Install that night and Wednesday and then we leave for wyoming/montana for ten days on friday!
  5. Jun 6, 2020 at 10:11 PM
    #445
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Their has to be an easier way to install these shackle hangers than cutting the bed sides off
  6. Jun 7, 2020 at 7:32 AM
    #446
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    @foxrcing07 thanks for the tip. :rofl:
    Those are on my list of mods to come.
  7. Jun 7, 2020 at 7:36 AM
    #447
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Anyone with a 2nd gen have pics of where or along what line you cut?
    Thx
    :spy:
  8. Jun 7, 2020 at 8:15 AM
    #448
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I went with a 1/4 inch below the tail light
    We’ll see how it fits this afternoon
  9. Jun 7, 2020 at 10:12 AM
    #449
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Kool.
    What does the line follow?
    Is it so many inches from the top of the fender or along a line that follows the shaped of the fender.
    I'm trying to describe I see where you start the cut but how is the line you cut along determined.
    I wouldn't think its a line level to the ground.
  10. Jun 7, 2020 at 10:16 AM
    #450
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    I think the line would be parallel to the top of the bed.
    notlefty and upTOPoverland like this.
  11. Jun 7, 2020 at 10:25 AM
    #451
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl::rofl::rofl:
    That's the perfect gif Brother!
    madsand and Beef Nachos[QUOTED] like this.
  12. Jun 7, 2020 at 10:48 AM
    #452
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    @foxrcing07 Can you post an after shot so I can see cut fender along the bumper.
    Thx again
    upTOPoverland likes this.
  13. Jun 7, 2020 at 1:37 PM
    #453
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Yea I’ll get that
    it will be later tonight tho I’m helping the neighbor put up his shop right now
  14. Jun 7, 2020 at 6:53 PM
    #454
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    More pictures and instructions later but here’s a few
    A401DBF9-F04A-4034-9598-29172A39E97F.jpg 0F64DEE4-38DC-4A0B-80B4-95683EADE260.jpg 15A801AE-2E3E-4011-AD33-3205EE638AE3.jpg
  15. Jun 7, 2020 at 7:22 PM
    #455
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    looks good man!
    Rome604 likes this.
  16. Jun 7, 2020 at 9:51 PM
    #456
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    My input towards install/parts breakdown
    If I did something wrong @JLee can you let me know so I can correct this post
    And sorry for the big post
    1st I wish I had installed the post for the latch before I installed the bumper, it would have been way easier to get the nut on the backside
    3/4” or a 19mm wrench and socket
    these washers were for the bolts to the frame
    17mm
    Wear plate for the swing outs/locking pin
    5/32” Allen wrench
    Swing position latch
    Install this before installing the swing outs onto the bumper
    this piece slides in from the opening and takes a little maneuvering to get into place
    I installed he swing arms and had to remove to install the hardware
    the externally threaded sleeve goes in and tightened
    Then the pin and spring from he bottom and they thread into the top piece
    Latches also use 5/32” allen
    now that the latches are installed
    Install swing outs the bolt slides down into hex slot
    I used a 27mm, it’s probably standard, but the 27mm fit perfectly for me
    Accessory hardware (tire carrier, etc....)
    Swing arm to modular plate hardware
  17. Jun 7, 2020 at 10:00 PM
    #457
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Correct I did parallel to the top of the bed
  18. Jun 8, 2020 at 7:18 AM
    #458
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    JKU3000 and upTOPoverland like this.
  19. Jun 8, 2020 at 7:26 AM
    #459
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Looks really good man! What are the bottom to bolts attached to on the mounting plate to the frame? Is it that little OEM long L shaped bracket? Because i need to get those if that is the case
  20. Jun 8, 2020 at 7:31 AM
    #460
    JLee
    Jerry
    Grass valley CA
    Correct the bottom holes are the L bracket on the bottom of the frame.
