BAMF High Clearance rear bumper "Modular DUAL swing out"
Discussion in 'Bay Area Metal Fabrication' started by JLee, Nov 20, 2019.
  1. Sep 13, 2021 at 10:51 AM
    #1121
    BRUPE
    BRUPE Well-Known Member
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    King 2.5s front / rear Icon AAL, Icon UCAs, Icon Rebound wheels Nitto Ridge Grapplers 285/75/17 OVTune
    No… I bought all new sensors, and still getting the alarm.
    When I open up the swing arms, the sensors work fine; the swing arm is being detected.
    I’m ok with that though… as long as everything “works”.
    I just don’t like having faulty equipment.
  2. Sep 13, 2021 at 10:58 AM
    #1122
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    Copy thank you.
  3. Sep 13, 2021 at 12:53 PM
    #1123
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Sensors aren’t even on my radar. Haha. That was punny. Seriously tho, we chopped that stuff off, ain’t even going to re-install or worry bout it.
    The real want is that camera relocation. Any update on that @JLee ? Will I have to by an aftermarket harness extension? Or is that a part of it? I’m “driving blind” back there lol.
    TIA
  4. Sep 13, 2021 at 2:31 PM
    #1124
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    I took out the factory camera and bracket, and placed it under the flip-up plate.
    it’s temporary, but works.
    If I go off roading, I’ll take it off BF815591-9A2A-4A7B-A9FB-336FBC7369E4.jpg
    Syner1 likes this.
  5. Sep 14, 2021 at 4:10 PM
    #1125
    Syner1
    Syner1 Active Member
    Anthony
    Bay Area, South Bay
    2015 MGM TRD Sport 4x4
    Yakima BedRock System, Yakima FrontLoader, Foglight Anytime Mod, FJ TRD Caps, Derped Emblems and Sport Wheels, Matte Black TRD Sports Bed Decal, TRD Skid Plate, OEM Bed Mat, LED Interior Lights, WeatherTechs, Spidertrax 1.25", Avid Front Bumper Guard, Avid Slider Style Steps, BHLM, Black Depo Rear Tail Lights.
    I did the same thing, but put it in the trailer hitch power location temporarily.
    tacotongue and RangerComa like this.
  6. Sep 14, 2021 at 4:33 PM
    #1126
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    If there’s a BAMF camera relocation bracket that doesn’t get in the way of a flip-up license plate; I’m interested.
    Also… a BAMF bottle opener that can be mounted to the swing outs….
    RangerComa likes this.
  7. Sep 15, 2021 at 6:01 PM
    #1127
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
  8. Sep 15, 2021 at 6:11 PM
    #1128
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Looks great, thats what I was thinking about doing also but with a 35in spare, I'm trying to decide if I want to mount the jack, rotopax, and/or propane tank....i wish i could fit all 3!!
    BOMBS and BRUPE[QUOTED] like this.
  9. Sep 15, 2021 at 6:17 PM
    #1129
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    Im getting my spare mounted on Saturday.
    This bumper, for the first time, will allow me to have a full size spare.
    I feel like I’ve been rolling the dice every time I go out, without a spare.
    thebaker[QUOTED] likes this.
  10. Sep 15, 2021 at 7:15 PM
    #1130
    Gat_
    Bay Area, CA
    Looks good.
    Did you have to drill new holes into the Jack mount? I tried to line mine up but the bolt heads on the swing arm protrude and hit the Jack mount. I was thinking of using washers to space out the mount from the swing arm…
    thebaker and BRUPE[QUOTED] like this.
  11. Sep 15, 2021 at 7:34 PM
    #1131
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    I have the 2 ton jack, so I don’t know if that makes a difference, but my bolts don’t touch the jack.
    Right now, I only have 2 bolts in. The pre-drilled holes on the mount do not line up with our swing outs.
    thebaker likes this.
  12. Sep 15, 2021 at 7:37 PM
    #1132
    Gat_
    Bay Area, CA
    Ahhh I see what you did there. Those silver bold heads at the bottom of the swing arm don’t hit the Jack mount?
    I tried that and it semi works….I’m thinking of drilling new holes in the mount so I can get all 4 bolts. Thank you!
  13. Sep 15, 2021 at 7:42 PM
    #1133
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    Ohh, those bolts.
    Yea, I’m sure they’re touching. I didn’t even notice that when I saw installed the mount.
  14. Sep 16, 2021 at 11:24 AM
    #1134
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    I have thought about mounting the PE back there but I’m just a skeptic and I don’t trust it. Just make sure you guys are using grade 8 bolts :thumbsup:
    BRUPE likes this.
  15. Sep 16, 2021 at 6:33 PM
    #1135
    BRUPE
    Brandon
    Corpus Christi, Tx
    2019 Tacoma TRD OR
    Can anyone tell me what size bolt this is?
  16. Sep 16, 2021 at 6:44 PM
    #1136
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    1/2-13
    BRUPE likes this.
  17. Sep 19, 2021 at 7:33 PM
    #1137
    CadCamMan
    TRD SC, suspension
    This is my solution for the camera bracket, doesn't interfere with the Bully Flip. I made a two piece bracket with a spacer that bolts the two together, and I use the left side mounting screw for the plate. The Bracket that mounts to the bumper is a section of 1/8" angle, the camera mount is 1/8" x 1" 304 SS, and the spacer came with my front Kings (sway bar spacers). I machined the same window and holes that are on the OEM camera mount. FYI, the pins and screw holes on the camera are not symmetrical to each other nor the centerline of the camera. Weird.
    View from beneath the bumper.
    No modification to the harness, just zip tie to the bumper.
    Unobtrusive, protected and clears the tailgate.
    I also fixed a couple issues with the bumper that were bugging me.
    1. There is a sizable gap between the top of the swingout and the upper mount. When you tighten the bolt the upper mount bends downwards. I turned a couple Delrin spacers for both sides and bent the mount back up. Don't remember exactly how thick they were, but it was something like .130"
    2. When you pull the locking pins up and rotate the handle to lock in the "up position" to open the swing outs, it doesn't lift the pins high enough and the pins catch the wear plate every single time.
    To fix this I removed the pins and chucked them in my lathe, turned .060" off the threads and turned back the taper .060" where the threads terminate to the body. Now when I pull up and rotate the handle to disengage the pins the swingout opens like it should, and the pins still fully engage the full depth of the bottom mount. Forgot to take pictures of this.
    Jabib, Midship909, Relyk711 and 5 others like this.
  18. Sep 28, 2021 at 5:54 PM
    #1138
    Gat_
    Bay Area, CA
    Sir, how did you mount those rotopaxs?
  19. Sep 28, 2021 at 8:04 PM
    #1139
    Relyk711
    Relyk711 Well-Known Member
    Kyler
    Santa Cruz
    2018 TRD Pro Black - 1999 Pre-Runner Black
    Alucab Canopy Camper BAMF HC Dual Swingout Rear bumper BAMF Sliders Westcott 1.5" TRD pro lift Icon RXT option3 leaf pack Rago HD Shackles & Hangars BFG KO2 285/75/16 CBI T3 Aluminum front bumper Warn EVO 10S Total Chaos Bed stiffeners Home built Aluminum HDPE bed platform.
    The rotopax brand mount bolts right up to the spacing of the holes in the swingarm uprights. I added some fender washers on the back side to spread the load a little more too.
    tacotongue likes this.
  20. Oct 2, 2021 at 8:32 PM
    #1140
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    i want that camera mount!!! make me one plzz
    Blucuss likes this.
