BAMF no drill bolt on sliders
Discussion in 'Bay Area Metal Fabrication' started by JLee, Mar 9, 2015.
  1. May 28, 2015 at 9:30 AM
    #201
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah shipping is a lot on these as they ship LTL freigh. @taco211 tax is not included in the price on the site.
  2. Jun 2, 2015 at 8:31 AM
    #202
    TheSurvivalist
    TheSurvivalist Well-Known Member
    Lou
    Tampa Bay, FL
    '16 TRD OR Wheels, Cooper AT3's 265/75/16
    Nice pics. I've gotta get me a set soon.
  3. Jun 9, 2015 at 5:34 PM
    #203
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Any updates on the DCLB versions?
  4. Jun 12, 2015 at 5:22 AM
    #204
    JLee
    Jerry
    Grass valley CA
    Yes we should have them ready by next week.
  5. Jun 12, 2015 at 5:29 AM
    #205
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    06 A-Cab TRD Off-Road 4x4
    Sub'd till suspension is bought/installed
    Would shipping Fastenal (I think that's how SOS does it...) be cheaper?
  6. Jun 12, 2015 at 8:48 AM
    #206
    oldmangarth
    oldmangarth Well-Known Member
    Garth
    Georgia
    So I've seen some discussion about late 2014 and 2015 tacos and the passenger side frame. Is this the box everyone is talking about and am I out of luck for a dcsb bolt on slider?
  7. Jun 12, 2015 at 9:21 AM
    #207
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
  8. Jun 12, 2015 at 11:07 AM
    #208
    ricantaco
    ricantaco Well-Known Member
    Thanh
    Bay Area, CA
    2015 DBC TRD OR
    Interesting, I was just about to place an order for these. Is there anyway to make them work without removing that box? What's that box for?
  9. Jun 12, 2015 at 11:18 AM
    #209
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    So I'm supposed to pick up my bolt on sliders from Jerry tomorrow. after seeing the last post, I went to check my truck and I found the box installed. After some searching, someone on here already opened the box
    https://www.tacomaworld.com/threads/sliders-install-frame-issue.324250/page-2#post-8495548
    that should be easy enough to relocate or just remount after installing the sliders. I'll keep you posted after I get it installed sometime next week/weekend.
    As for what it is, quoted from the thread linked above
  10. Jun 12, 2015 at 12:15 PM
    #210
    oldmangarth
    Garth
    Georgia
    So do you have the 2015? Definitely let us know as I've seen reference to the box as an issue and possibly the 2015 in general but no confirmation that these sliders can be installed regarding either reference.
  11. Jun 12, 2015 at 12:29 PM
    #211
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    aha... finally figured it out! as mentioned, the harness runs to the bed outlet. it splits in that location, one way to the outlet, one way to the engine wiring harness for power, and one way up into the cab and to the on/off switch.
    so, if your truck has no bed outlet, don't worry about it. if you have a bed outlet here are the different scenarios -
    a: most 2014's and earlier have the metal bracket to hold it in place, no box
    late 2014 and up:
    b: if it is a US made unit with outlet - you have the box
    c: if it is Mexico made unit with outlet - you have the old style bracket
    mystery solved - tho I have no idea why the change was made, probably some liability issue or something, gets too hot, too exposed or whatever. but since it is essentially the same harness I don't see why it could not be relocated for slider install
    ta-da!
    :humble:
    @JLee
  12. Jun 12, 2015 at 12:35 PM
    #212
    JLee
    Jerry
    Grass valley CA
    I do not ship with Fastenal they are a horrible shipping outlet with too many problems. My customers are welcome to have Fastenal or whoever they like come grab their sliders but I personally don't use them.
    1truckdriver likes this.
  13. Jun 12, 2015 at 12:36 PM
    #213
    JLee
    Jerry
    Grass valley CA
    We will be sure to mount your passenger side slider tomorrow I want to check fitment as well.
    T4RFTMFW likes this.
  14. Jun 12, 2015 at 12:47 PM
    #214
    rob1208
    Rob
    SF Bay Area
    Sounds good to me! thanks Jerry!
  15. Jun 12, 2015 at 2:16 PM
    #215
    oldmangarth
    Garth
    Georgia
    I feel a plan coming together. Hope somebody grabs some pics. :bowdown:
  16. Jun 12, 2015 at 2:46 PM
    #216
    JLee
    Jerry
    Grass valley CA
    Interesting I'll have some answers on that one tomorrow!
  17. Jun 12, 2015 at 3:18 PM
    #217
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Easy enough to just drill some holes in the plate and run some slightly longer bolts. I might have a 2015 I can swing by with soon :)
  18. Jun 12, 2015 at 3:24 PM
    #218
    JLee
    Jerry
    Grass valley CA
    After looking at the pictures and my sliders that box might have to be moved forward a few inches I'll report back tomorrow after i test fit one.
  19. Jun 13, 2015 at 12:33 PM
    #219
    JLee
    Jerry
    Grass valley CA
    We have a confirmed fit on the little black box! all that needs to be done is move it forward and tilt it a little Pics to come.
  20. Jun 13, 2015 at 7:09 PM
    #220
    oldmangarth
    Garth
    Georgia
    Woo Hoo!
