BAMF no drill bolt on sliders
Discussion in 'Bay Area Metal Fabrication' started by JLee, Mar 9, 2015.
  1. Jul 9, 2015 at 6:41 PM
    #261
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Thats crazy! Good for you, steady business and all! I want weld on, but looking for a kick out (ideally), need something to step on getting things off my prinsu rack. But how far out from the cab do the non-kick outs stick? I do Like how clean the non-kick out's are. Hmmmm decisions. PM me a price for the in stock?
  2. Jul 9, 2015 at 6:44 PM
    #262
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    They stick out about 13" from the frame.
  3. Jul 9, 2015 at 10:50 PM
    #263
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Well if you have them by next year, I will definitely pick up a set.
  4. Jul 10, 2015 at 2:36 PM
    #264
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    On the 80" DCSB Bolt On Sliders with kickout (in case that matters) what is the standard Degree on them without special requesting anything different?
  5. Jul 10, 2015 at 6:41 PM
    #265
    JLee
    Jerry
    Benicia, CA
  6. Jul 10, 2015 at 7:58 PM
    #266
    Enjoihavok
    Erik
    Chandler, AZ
    2021 Tundra Pro
    Perfect I thought I had read that somewhere but wanted to make sure. It's going to be a long 3 months waiting for these bad boys.
  7. Jul 11, 2015 at 1:22 AM
    #267
    AZJEFFRO
    AZJEFFRO Well-Known Member
    Jeff
    Tucson, AZ. USA
    PreRunner TRD Offroad.
    80" fits Access cab reg. bed correct ??
  8. Jul 11, 2015 at 8:29 AM
    #268
    JLee
    Jerry
    Benicia, CA
  9. Jul 14, 2015 at 10:28 AM
    #269
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
  10. Jul 17, 2015 at 6:59 AM
    #270
    boris7
    boris7 Member
    SL,UT
    Black 2015 Taco TRD Sport
    Shell, Debadged, OME 885 and Dakars, Camburg UCAs, SCS Stealth 6, 265/75 17 Cooper ST Maxx
    Can I get a shipping quote to a business at 84116?
  11. Jul 20, 2015 at 7:58 AM
    #271
    JLee
    Jerry
    Benicia, CA
    $135.00 for bare metal and $145.00 for powder coated.
  12. Aug 6, 2015 at 6:06 PM
    #272
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    what if i live close by and can pick them up, can i save on the wait time ??? :anonymous:
  13. Aug 9, 2015 at 9:32 PM
    #273
    JLee
    Jerry
    Benicia, CA
    Sure you can get them one day sonner.
  14. Aug 20, 2015 at 8:34 AM
    #274
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I don't know but I think they'll work.
    ChadsPride and JLee[OP] like this.
  15. Aug 20, 2015 at 9:41 AM
    #275
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    :spy: Stalking the BAMF website daily waiting for the 80" sliders to be the deal of the day, the wife wants some on her truck woot! @JLee any idea what shipping to zip code 77657? Also what freight company do you use?
  16. Aug 20, 2015 at 11:35 AM
    #276
    JLee
    Jerry
    Benicia, CA
    150 to a business or will call we use quite a few different companies Conway freight would be taking yours.
  17. Aug 20, 2015 at 11:52 AM
    #277
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    hey..you look busy. you deer hunting this year? i'm throwing a hailmary and running up to the Klamath forest tomorrow to see if i can fill my archery only tag. if i see a bunch..i'll let you know. seems like the only area that isnt on fire. :)
  18. Aug 20, 2015 at 12:03 PM
    #278
    JLee
    Jerry
    Benicia, CA
    Nope it will never happen there is just not enough interest.
  19. Aug 20, 2015 at 12:34 PM
    #279
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    How much would it be
    To ship sliders to 92308?
  20. Aug 20, 2015 at 12:56 PM
    #280
    JLee
    Jerry
    Benicia, CA
    what options there is a big difference between weld on bare metal and powder coated bolt on sliders.
