BAMF no drill bolt on sliders
Discussion in 'Bay Area Metal Fabrication' started by JLee, Mar 9, 2015.
  1. Apr 17, 2017 at 4:39 PM
    #801
    ChadsPride
    Sponsored by TacomaWorld.com
    :D:D:D:D:D:D
    riz_atx[QUOTED] likes this.
  2. May 10, 2017 at 5:57 PM
    #802
    famous187
    famous187 Active Member
    placed my order dec 30th, received last week and installed today. installation only took about 2 hours, fit great. broke one of the white plastic brake line brackets, should i replace this or let it rock with out one?
    thanks for the awesome sliders!!
    slamson00 and ChadsPride like this.
  3. May 10, 2017 at 8:58 PM
    #803
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    As long as the brakeline isnt rubbing or sticking out to catch on anything you'll be fine.
    ChadsPride likes this.
  4. May 10, 2017 at 11:02 PM
    #804
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I replaced the one I broke. It was under $2, IIRC. The P/N's are in this thread somewhere.
  5. May 14, 2017 at 1:12 AM
    #805
    bsp_taco
    bsp_taco Well-Known Member
    Nick
    Oregon
    ACLB 2008 2.7L M/T SR5 4x4
    Dirt King 3.5" LT, King 2.5 RRs, Duratrac 35s, 4.88s, arb air locker front & trutrac rear
    Fill plates, kickout, powder coat. Love em :cheers: now I'm just waiting on raptor letters :thumbsup:IMG_4862.jpg IMG_4859.jpg
  6. May 14, 2017 at 6:26 PM
    #806
    ChadsPride
    Loving everything about these!
    Thank you so much BAMF!!
    slamson00, riz_atx, Naumoff42 and 5 others like this.
  7. May 14, 2017 at 6:31 PM
    #807
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Sweet!
    ChadsPride[QUOTED] likes this.
  8. May 14, 2017 at 6:36 PM
    #808
    ChadsPride
    :headbang::headbang::headbang:
    Exactly what I wanted, beyond pumped right now.
    :benchpress::benchpress::benchpress:
    TACOVRD[QUOTED] likes this.
  9. May 14, 2017 at 6:55 PM
    #809
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    They're great looking sliders for sure! The wait is brutal, but they're fantastic.
    Congrats !
  10. May 14, 2017 at 6:56 PM
    #810
    ChadsPride
    Totally worth the wait!!! Fit and finish are perfect!
    Naumoff42 and kakwvu[QUOTED] like this.
  11. May 14, 2017 at 7:06 PM
    #811
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Did you get them without the 20° angle?
  12. May 14, 2017 at 7:07 PM
    #812
    ChadsPride
    Yes I did, good eye! :thumbsup:
    I got them coming flat off the frame. These things are solid as could be.
    Naumoff42[QUOTED] and kakwvu like this.
  13. May 14, 2017 at 7:10 PM
    #813
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    They're easily my most commented about piece on my truck! Can't go wrong.
  14. May 14, 2017 at 7:10 PM
    #814
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Any pros/cons to having them come flat out like @ChadsPride versus the 20* angle? Ease of stepping/standing, protection from doors/shopping carts?
    Trying to gather info before I place my order. And can slider adapters work if you have fill plates? Any input is most welcome :)
  15. May 14, 2017 at 7:11 PM
    #815
    ChadsPride
    I wanted the ultimate mall crawling protection honesty, flat off the frame made more sense for my application.
  16. May 14, 2017 at 7:14 PM
    #816
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    :rofl:Seconded. I assume if I got flat like yours but with fill plates it would provide a nice surface for stepping up/standing on as compared to the 20* which you'd mostly be standing on the outer bar?
  17. May 14, 2017 at 7:15 PM
    #817
    ChadsPride
    The fill plates would be awesome!
    I just opted out for whatever reasons, totally would look sweet.
  18. Jul 10, 2017 at 1:00 PM
    #818
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    This is a bit of a stretch I know, but you guys wouldn't be willing to send over the plans/dimensions you use for the frame flange portion of the slider are you? I'd be willing to pay a bit for it, but I work at a fab shop and want to make my own sliders to bolt on.
  19. Jul 11, 2017 at 8:27 AM
    #819
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    There is a thread on TW where you can get frame plate files.
  20. Jul 11, 2017 at 8:30 AM
    #820
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Thank you!
