BAMF Presidents Day/Tax time sale 30% OFF!!!
Discussion in 'Bay Area Metal Fabrication' started by JLee, Feb 14, 2013.
  1. Jul 10, 2013 at 5:09 PM
    #241
    looneytunemagoun
    looneytunemagoun Well-Known Member
    james
    Leicester,mass
    SR5
    Got sliders today Jerry look sweat can't wait to get them on thank u
  2. Jul 12, 2013 at 2:08 PM
    #242
    4x4fishin
    4x4fishin Active Member
    Baton Rouge
    Shopping
    Got mine, just gotta paint em and get em mounted. They look good. Does anyone have a step by step instalation guide. These are a little different from the ones on my FJ as the frame on the FJ was already tapped.
  3. Jul 12, 2013 at 2:15 PM
    #243
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Mine have been at the powder coater since last wednesday and havent even started on them. I'm pissed.
    Anyhow, I figured once you hold them up to the frame the holes in the frame and the lack of holes in the frame should help with understanding. I havent opened the bag of hardware to know what is in it, or know what size drill bits are needed to drill the remaining holes, so ya I may need some 411 as well.
  4. Jul 12, 2013 at 2:47 PM
    #244
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just bolt them up with the side holes and then drill the lowers. It's pretty straight forward. The long brackets are for the front plates you will see it's a pain to get your arm in there.
  5. Jul 12, 2013 at 5:02 PM
    #245
    Agro
    San Diego
    I'm starting the install. Powder coater got mine done.
    Not sure about the front bracket. Pardon my ignorance :)
    I can see the extra arm on the bracket helps u hold it. The 4 steel pieces I'm not positive about. Do they go between the bolt and the slider? Example pic .
    I think so since I have 14 washers and 7 bolts extra. Please confirmImageUploadedByTapatalk1373673667.183901.jpg
  6. Jul 12, 2013 at 5:09 PM
    #246
    JLee
    Jerry
    Grass valley CA
    Those go on the back side of the frame you will see when you try and bolt them up and the nut will not hold without the big washer on it.
  7. Jul 12, 2013 at 5:23 PM
    #247
    Agro
    San Diego
    I see more now that I tried bolting up. You tried calling me. Can you try again? One more question and I think I got this
  8. Jul 12, 2013 at 8:54 PM
    #248
    Agro
    San Diego
    Got them installed. Chewed up 2 bits and burned my arm :)
    ImageUploadedByTapatalk1373687499.340806.jpgImageUploadedByTapatalk1373687532.784562.jpgImageUploadedByTapatalk1373687545.534125.jpgImageUploadedByTapatalk1373687559.400787.jpgImageUploadedByTapatalk1373687588.984292.jpg
  9. Jul 13, 2013 at 10:36 AM
    #249
    4x4fishin
    Baton Rouge
    Shopping
    Thanks for the pics. Last coat of textured rattle can just went on mine. Will hopefully mount this evening or tomorrow. Did you step through different drill bit sizes or just go for it? Did you drill the bottom holes with the sliders already mounted?
  10. Jul 13, 2013 at 11:39 AM
    #250
    Agro
    San Diego
    Bolt the sides. If you have a second set of hands that Helps but i laid on my back and lifted the sliders with my knees as such. So do the sides make sure that the bottoms are flush. You may have to get all sides secured but not crazy tight then use a rubber mallet and hammer the bottoms so it lifts up and stays flush. Then I drilled the bottoms and I used 3-4 different sizes to make life easy on myself. Ultimately u use 1/2". Then I bolted the bottoms up secured tight. I then rechecked the sides and then done.
    The drivers side can be a pita. The brake lines (I think?) run down that side and where you bolt. So it took more finesse to do it. The front drivers 2 side and front 1 lower I used my girlfriends 11 yr old son as his arms/hands are tiny and he was able to get in there no issues. My hands hit the lines and it pissed me off so I gave up.
    I went through 2 bits of each size. I didn't buy expensive stuff so I don't care.
  11. Jul 16, 2013 at 8:19 AM
    #251
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Weekly check-in.
    Any updates?
  12. Jul 16, 2013 at 8:49 AM
    #252
    JLee
    Jerry
    Grass valley CA
    Yep just working out details with Conway your pallet getting wrapped today. PM me the shipping address again so i can get the quote and get you guys the invoices.
  13. Jul 16, 2013 at 8:53 AM
    #253
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
  14. Jul 27, 2013 at 11:19 AM
    #254
    lurx
    lurx Active Member
    Central NJ
    '13 TRD Sport SW DCSB
    Picked up my sliders from Conway yesterday. Have not done a test fit yet, but is the bend on the left normal (front - drivers side slider) ?
  15. Jul 29, 2013 at 11:27 PM
    #255
    JLee
    Jerry
    Grass valley CA
    No that bend is not normal they damaged them they are bent the same for both sides. Pm sent!
  16. Feb 16, 2014 at 3:06 PM
    #256
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    So...is this happening again? :D
  17. Feb 17, 2014 at 9:02 AM
    #257
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    :pout:
  18. Feb 17, 2014 at 10:43 AM
    #258
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I was all excited and then I saw the date. Fail 2013 :(
  19. Feb 17, 2014 at 10:49 AM
    #259
    BamaToy1997
    Bill
    Navarre, FL
    Dang! You and me both!
  20. Feb 17, 2014 at 1:40 PM
    #260
    JLee
    Jerry
    Grass valley CA
