BAMF Rock sliders "most" Trucks
Discussion in 'Bay Area Metal Fabrication' started by JLee, Oct 4, 2011.
  1. Apr 16, 2014 at 5:07 PM
    #1781
    provofan
    provofan Well-Known Member
    Utah
    13 Black Double Cab TRD Offroad
    My order was packaged well, easy to assemble, and everything was included and they were just as ordered. I made a special order to have top plates attached and powder coated and have it stand at a 0 degree angle so the kiddos could use them as steps. I would highly recommend BAMF to anyone. Jerry was also very good to work with.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/325222-dont-kick-bucket.html
  2. Apr 16, 2014 at 5:08 PM
    #1782
    provofan
    Utah
    Any good tips on drilling through the frame?
  3. Apr 16, 2014 at 5:23 PM
    #1783
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Use good bits, lots of oil, low rpm. May want to start small and work your way up, not positive how much that will help though.
  4. Apr 16, 2014 at 6:08 PM
    #1784
    1776
    1776 Member
    Josh
    Las Vegas
    10 TRD Off Road Dbl Cab
    Icon front coilovers w/res, Icon rear shocks w/res, TC UCA, OME Dakar leaf pack, Method Standard wheels, 285/75/16 BFG AT KO, BAMF bolt on sliders, VIAIR 400C OBA, AP front plate bumper, Cobra 75wxst CB
    Eat your Wheaties and workout your shoulders/arms for a few weeks prior :D, its a pain in the A$$, even with good bits (I had Dewalt Cobalt) and oil. I used motor oil dispensed out of an oil can vs WD40, I find bits cut better plus helps contain the metal shavings. What helped me "some" was to jack the truck up on the side I was working on so I could get a bit more leverage. Have a nice cold 6-pack ready when done!
  5. Apr 16, 2014 at 6:13 PM
    #1785
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Id say get a step bit too because they are a little shorter than standard drill bits and fit in tighter spots plus they make it a lot easier to notch holes/make holes bigger.
    Wear safety glasses!!! Getting metal in your eyes sucks balls.
    I personally needed a special right angle drill (I only have one cause I used to be a plumber...) because some of the holes were in such tight spots. But mine is a 97 and the frame is a bit different so probably won't need a special drill.
  6. Apr 16, 2014 at 6:14 PM
    #1786
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    I have heard of people putting a floor jack under their drill as well, just go slow or the bit will go kaboom! :D
  7. Apr 17, 2014 at 10:03 AM
    #1787
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Lots of oil and slow is the key I like to start with 3/16th or 1/4" and work my up to 1/2" that works the best.
  8. Apr 17, 2014 at 9:34 PM
    #1788
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Hammer drill and a few cobalt bits. I did bolt on sliders on my DCLB and had to drill quite a few. get one side on jackstands, get your shoulder under it and sweat alot.
  9. Apr 17, 2014 at 10:13 PM
    #1789
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    What part of the hammer drill helped? The "hammer" part is for concrete.
  10. Apr 17, 2014 at 10:14 PM
    #1790
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Step bit and oil. Big slow drill with a cord. Better control, usually. That's going to provide the fastest cleanest hole.
  11. Apr 17, 2014 at 10:22 PM
    #1791
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    I think Jerry has the most efficient plan from my experience. 1/16" bit moving up through the sizes with oil. Step bits are good for thinner stock but frame steel is a bit much.
  12. Apr 17, 2014 at 10:24 PM
    #1792
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mag drill
  13. Apr 17, 2014 at 10:27 PM
    #1793
    HiFire
    HiFire Well-Known Member
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Weathertech mats, BAMF sliders, US Offroad front winch bumper, RCI Alum. Skid plates, ICON suspension, Pelfreybilt rear bumper, JBA uca's, Allpro u-bolt flip,
    Just got mine mounted. 1/8" bit for a guide hole than follow with a step bit. Maybe I just had good bits, it only took me @ 10 minutes per side.
  14. Apr 17, 2014 at 10:40 PM
    #1794
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    :rofl:
    Of course, cause everyone has a mag drill.
  15. Apr 17, 2014 at 10:54 PM
    #1795
    OZ-T
    Peter North
    British Columbia
    :) amateurs
  16. Apr 17, 2014 at 11:02 PM
    #1796
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Me too :p I had new bits and turned them slowly so they just cut the metal and didn't get too hot. No oil used either. I'm really happy with the quality of these sliders.
  17. Apr 17, 2014 at 11:13 PM
    #1797
    presto
    Topher
    san francisco
    2000 T4R 4x4
    My step bit from HF goes through up to about 1/8" pretty easily. Haven't tried 3/16" yet.
  18. Apr 18, 2014 at 4:54 AM
    #1798
    JLee
    Jerry
    Grass valley CA
    Every time I am installing at set i wish I had a mag drill.
  19. Apr 18, 2014 at 5:29 AM
    #1799
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Getting a good step bit is the best way to go. I used an1/8" cobalt bit for a pilot hole, then followed with a cobalt step bit. The actual drilling was not bad. I spent probably more time mocking them up and making sure everything was right. I used the irwin cobalt step bit from Lowe's(~$48). The cheaper step bits are made for thin sheet metal. Get the good one, use a lot of oil and go slow and it's pretty easy.
  20. Apr 18, 2014 at 9:30 AM
    #1800
    provofan
    Utah
    You are all scaring me away from doing it myself. I dont think my 20v Dewalt cordless will cut it and proper bits are $50+.
    What should I expect to pay a shop to drill the last 3 holes one each side? The sliders are already mounted on the truck.
