BAMF Rock sliders "most" Trucks
Discussion in 'Bay Area Metal Fabrication' started by JLee, Oct 4, 2011.
  1. Oct 27, 2014 at 5:03 PM
    #1881
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    I bought my DIY sliders from Jerry Saturday I can't wait to get started
  2. Oct 27, 2014 at 6:24 PM
    #1882
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Not sure that would be economical given the different locations.
  3. Oct 29, 2014 at 1:54 PM
    #1883
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah unless my wife buys a 5th Gen I would need one here to mock it up.
  4. Nov 6, 2014 at 12:38 AM
    #1884
    AJE
    AJE Active Member
    Andrew
    04 SR5 4-Door
    Jerry, have you ever made a kick out AND kick up slider? If so, what would it look like? Thanks
  5. Nov 6, 2014 at 7:32 AM
    #1885
    JLee
    Jerry
    Grass valley CA
    Yes i have only on my truck it's WIDE with both so unless your rear axle is 6" over stock it's going to look odd.
    TacoEspecial likes this.
  6. Nov 6, 2014 at 7:25 PM
    #1886
    OC 714Taco
    OC 714Taco Well-Known Member
    Richard
    SoCal CA
    14 DCSB TRD OR
    Hi Jerry, I ordered a set of sliders a couple of days ago via your website for a 2014 DCSB. I'm getting ready to order full set of All Pro skids. The sliders I ordered are bolt on. My question is will there be any issues with installation of the skids with the bolt on sliders?
  7. Nov 9, 2014 at 8:05 PM
    #1887
    JLee
    Jerry
    Grass valley CA
    I personally have not tried to fit all pro skids with bolt on sliders so I couldn't tell you.
  8. Nov 16, 2014 at 12:55 AM
    #1888
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Any idea on when the next sale will take place ? :D
  9. Nov 16, 2014 at 5:12 AM
    #1889
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Like twice a month lol
  10. Nov 16, 2014 at 7:28 AM
    #1890
    JLee
    Jerry
    Grass valley CA
    Right now :confused: everything it on sale until the 29th.
  11. Nov 20, 2014 at 9:48 AM
    #1891
    4x4Taco09
    Dane
    Louisiana
    Now deciding on kick out or up. DOM upgrade for sure. Also going to grab a set of Raptor letters finally
  12. Nov 24, 2014 at 8:10 AM
    #1892
    MtnDesertTaco
    MtnDesertTaco Well-Known Member
    Utah
    2014 Spruce Mica, TRD Offroad, access cab,
    Hey Jerry-
    Looking to get some sliders for my access cab. Specs: 2nd Gen (80"), Kickout, Weld on, DOM, with fill plates. Couple questions.
    - Wanted to get the 10 degree instead of the standard 20. Is this possible if so how would i specify on the order.
    - Also, little worried about the holes in the fill plates for my dog loading up. How big are the holes? Could i get the fill plate that lines up with the access cab area without the hole? Any negatives you can think for doing this? Thanks.
  13. Nov 24, 2014 at 8:15 AM
    #1893
    JLee
    Jerry
    Grass valley CA
    You can put all of that in the notes when you order all fill plates are cut to order so it's not a problem leaving the holes out.
  14. Nov 24, 2014 at 8:22 AM
    #1894
    MtnDesertTaco
    Utah
    Thanks. Ordering ASAP.
  15. Nov 26, 2014 at 1:56 PM
    #1895
    Rames
    Rames Well-Known Member
    James
    Oakland, CA
    OME 3" lift, BAMF sliders, Demello front bumper
    How are those add on steps going for the sliders? I saw there was a prototype on your ig
  16. Nov 26, 2014 at 3:47 PM
    #1896
    JLee
    Jerry
    Grass valley CA
    Still running them on my truck It's going to be a few more weeks before they are on the site.
  17. Nov 26, 2014 at 4:00 PM
    #1897
    ThomasMore66
    Dallas/Fort Worth & Durango
    My wife would be happy.
  18. Nov 26, 2014 at 8:45 PM
    #1898
    Rames
    James
    Oakland, CA
    Thanks for the update, I'll be on the lookout for them
  19. Nov 26, 2014 at 9:40 PM
    #1899
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Woo about to order some sliders finally!
  20. Nov 26, 2014 at 9:43 PM
    #1900
    JLee
    Jerry
    Grass valley CA
    It's the best time of the year to do so!
