Bandido's 5lug Race Truck "Taquito"
Discussion in '1st Gen. Builds (1995-2004)' started by Bandido, Sep 8, 2022.
  1. Apr 23, 2025 at 11:08 AM
    Bandido
    Bandido [OP] Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Not when I can do the swap for $2-2.5k and get replacement motors for <1k with <100k miles on them haha
    For endurance racing, keeping mods limited to longevity stuff as much as possible is the preferred route.
    Maybe you should swap in a 2GR in your truck! People are making 400+wheel NA with mods and 700+ wheel with boost on stock motors (I don't think they last all that long at that power level tho)
    Brice[QUOTED] likes this.
  2. Apr 23, 2025 at 1:16 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    While I do appreciate the 2gr, I wanna see how capable the 5vz is. It won't be making 400 NA, but maybe 250? In the end I'll be happy with a reliable 500 wheel, turbocharged of course (bottom end etc.).
    Bandido[QUOTED][OP] likes this.
  3. Apr 23, 2025 at 1:22 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    400 wheel NA on a 4wd truck out of a 2gr?? What kind of mods you gotta do to get there?
    you have my attention
  4. Apr 24, 2025 at 5:45 AM
    Bandido
    Alex
    Lexington, KY
    2003 Tacoma DC
    I'm making ~280 wheel on my 2GR Double cab with headers, Maf pipe and an FMW tuned ECU.
    400+ WHP builds are becoming "common" in the MR2 community, which is leading the charge on 2GR performance development via Frankenstein Motorworks
    They generally consist of Headers, Cams, valve springs, and an intake manifold+injector upgrade, along with (of course) an ECU tune.
    With boost, there are "dozens" of 2GR MR2's north of 500 whp on pump and getting well above that with E85.
  5. Apr 24, 2025 at 10:06 AM
    betterbuckleup
    Ian
    Concord, CA
    Didn't know that MR2's came with 2GR's in them.
    What kind of mpg are you getting on yours? I can achieve the same HP on my 3rz with a turbo, but the probably better MPG and being able to do without 91 is attractive.
  6. Apr 24, 2025 at 12:47 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    2GR swapped MR2's I believe
  7. Apr 24, 2025 at 12:59 PM
    Bandido
    Alex
    Lexington, KY
    2003 Tacoma DC
    I usually get 16-17 mpg for my daily commute with mixed city/highway, in the winter I can get as low as 12 depending on amount of slideways. Highway is usually 20mpg if kept at 70mph, it goes down as speed goes up.
    Driving 55 it will get 24mpg lol.
    I also have the .69 5th gear.
  8. Apr 24, 2025 at 2:00 PM
    betterbuckleup
    Ian
    Concord, CA
    Ya 16-20mpg would be sweet. Best I've been able to get is 14 these days. More like 11-12 when throttle heavy.
    Did you swap over the whole 2g drivetrain with trans and t-case, or adapt it to the R150?
  9. Apr 24, 2025 at 5:31 PM
    Bandido
    Alex
    Lexington, KY
    2003 Tacoma DC
    Man i know i suck at sharing details but you might needa scope my double cab build again lol.
    Ill try to do more of a write up for the low body swap. Its definitely more straightforward without the front diff.
  10. Apr 25, 2025 at 9:01 AM
    betterbuckleup
    Ian
    Concord, CA
    Ah ya I'll go refresh my memory with your build thread lol
  11. Apr 28, 2025 at 9:46 AM
    Bandido
    Alex
    Lexington, KY
    2003 Tacoma DC
    I modified the trophy with a pikes peak tacoma matchbox car.
    Absolutely the inspiration for the build.
    Dalandser, Speedytech7 and jubei like this.
