Banging Passenger Side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1sttoywv, Sep 23, 2013.
  1. Sep 23, 2013 at 12:18 PM
    1sttoywv
    1sttoywv [OP] Well-Known Member
    morgantown wv
    13' TRD Offroad (Pyrite Mica)
    I have a stock 2013 TRD Offroad with only 1200 miles on her. Recently when I ride over uneven or patched rodes theres a banging in the passenger suspension. Almost sounds like the strut is loose but visual inspection shows nothing looks loose or broke. Any ideas? Also my truck hasn't seen a dirt road yet and gets bathed twice a week. I plan on making her last.
    Thanks
  2. Sep 23, 2013 at 12:25 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Even though is prematurely, but I have seen on dodge dakotas before where the upper and lower ball joints fail when almost new. you could have gotten a bad batch. just in case, check torque specs on all the bolts and nuts on the suspension to make sure nothing came loose.
  3. Sep 23, 2013 at 8:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Take it to a Toyota Dealer and let them honor the warranty. That is why it is there!
  4. Sep 23, 2013 at 11:45 PM
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    The issue here is that you bought a TRD off-road and well... You haven't taken it off-road yet. I suggest skipping one of your bath times this week and visiting a dirt road!
  5. Sep 24, 2013 at 1:01 AM
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    I have a similar problem in my 09. Its more of a rattle sound than a banging. It only happens on small bumps.
    I dont know if it is the ball joints... Hopefully not... Or the common steering column issue. I may try the "zip tie mod" to see if that cures it. It has been tough to diagnose...
    Suspension is tight, tourqued properly and intact.
    It isnt bad, just a bit annoying.
    Any imput?
  6. Sep 24, 2013 at 1:16 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I was going to say um if you like your truck that way cool... But on a serious note take it to Toyota and let them fix it
  7. Sep 24, 2013 at 5:55 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    This, why is it even a question if you have a 13?
  8. Sep 24, 2013 at 8:46 AM
    Tacorriendo
    Fred
    Texas
    My 09 started to do the same thing you are describing on the passenger side, but only after I lifted the suspension. At the time, I did not know how to remove the sway bar so I was spinning the ball joint from the link. I figured I messed them up and that is why is doing the rattling. Although it could be that since now the upper ball joint are riding on a steeper angle, that they might have worn out fast; like a week fast!:eek:
    I'm going to start by replacing the sway bar link (cheapest) and see if it goes away. If not, then upper ball joints are next.
