Banjo Fitting Seal- Tundra Brake Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dusty T., Jun 24, 2014.
  1. Aug 12, 2014 at 11:51 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    With bigger tires, yes, its worth it. Not much time and not much money. Only costed me ~$400 and 2hrs :notsure:.
  2. Aug 12, 2014 at 12:06 PM
    Dusty T.
    Dusty T. [OP] Well-Known Member
    Portland, OR
    2002 Tacoma 4x4 TRD; 2003 Honda Element
    Got the brakes installed this week. I did not have that issue with the caliper bolts, as mine were threaded all the way and fit perfectly to the tundra caliper without needing a washer They were the perfect length, too...
    It was a bolt-on procedure with the exception of very, very minimal trimming and bending of the dust shield. I went with the 13WL (231mm) calipers and rotors for an '05 Tundra. I did NOT use the banjo fitting and instead used hard lines with the double-flare fittings and the spindle attachment from an '02 4-Runner. From there, it connects to a 17-1/2" long braided female/female flex line custom ordered from Paragon. I ordered Crown lines too, but the paragon fittings have a nice oval backing plate that fits the stock line tabs. Everything fit together perfectly, and is basically what you would find on a 3rd gen 4-runner.
    Bled the system last night, and am waiting on new lower ball joints before trying them out. I did notice that there is a little extra travel in the brake pedal. Maybe that will go away after some use and the pads seat, however, I have read this can be a result of the larger fluid capacity of the calipers. No sponginess though. Bleeding the system was straightforward and no leaks so far (fingers crossed). Would love to hear some input from others who have installed the 231's.
    I'll try to post photos in the coming weeks when things settle down a bit.
    JDeRose, foxrcing07 and alphabravo like this.
  3. Aug 12, 2014 at 2:53 PM
    Len04Taco
    Len04Taco Well-Known Member
    Len
    Stow, MA
    04 SR5 Red
    Thank you Dusty.
    This is a big help. So I look for a 02 4-runner bits at the dealer. Doubt if its too expensive and my requirement is to have the correct fittings for the caliper.
    Len
  4. Aug 12, 2014 at 9:27 PM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    I run 33x12.50 so pretty good sized tires and does it matter what kind of back spacing you have? I have 15x10s and need some more stopping power? What would I need to do the swap?
  5. Aug 13, 2014 at 9:55 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Len, the pics as you requested. 04 taco with the tundra 13WG 231mm calipers. Wheeler's banjo bolts and steel braided brake hoses. Everything mounted up easily but as mentioned here i did have to install a lock washer on the caliper mounting bolts, the tacoma bolts are a tad too long. The 231's fit perfectly behind the stock 16" TRD wheels.
  6. Aug 13, 2014 at 12:23 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    You need 16" wheels.
  7. Aug 13, 2014 at 12:29 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Or very big wheel spacers.
  8. Aug 13, 2014 at 12:35 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Does anyone have the TGP part numbers for the calipers?
    I've attempted to find them at various online dealership parts departments but for the calipers themselves, the part numbers are oddly missing from the associated diagram.
  9. Aug 14, 2014 at 10:04 PM
    Dusty T.
    Portland, OR
    You can try pulling a VIN # for a 2005 Tundra, V8, 4WD and run that through the dealership. They should be able to provide a part number for a 231mm caliper. Not sure whether you will end up with a 13WL or 13WG one though. Napa has their Eclipse rebuilt calipers, which is what I went with- the 13WL. I think they're pretty well made, and had the stock size Napa caliper on for 10K before doing this upgrade. No quality issues whatsoever and much less expensive than from the dealer...
  10. Aug 14, 2014 at 10:09 PM
    Dusty T.
    Portland, OR
    So finally got out for a test drive! Haven't noticed a huge difference- though took it fairly easy on the brakes. It does seem to stop much more smoothly and uniformly with far less effort on the pedal. I will say it does take a bit more travel before they grab, and holding pressing the pedal hard for an extended period of time will push it to the floor. I noticed this prior to the upgrade and the master cylinder does not appear to be leaking. All the fittings are dry, too. For those of you who went with the 231mm calipers, same results? I may bleed it again next week to verify. Pictures to come- fit and finish looks factory!
  11. Aug 15, 2014 at 4:30 AM
    68dave
    Dave
    Are you saying that if you hold down the pedal it goes to the floor? It should never go to the floor. You must have air in the system if the pedal drops to the floor. Re-bleed the system.
  12. Aug 15, 2014 at 4:37 AM
    68dave
    Dave
    If the pedal went to the floor prior to the upgrade the m/c could be faulty internally not allowing the system to hold pressure. I wouldn't wait a week to fix this issue, if you had to slam on your brakes in a emergency the pedal could go to the floor effecting your stopping distance.
  13. Aug 15, 2014 at 6:30 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    :eek:
    ^ This. Pedal to the floor = bad
    Pending that, if the brakes feel a bit squishy, this is typical with stock brake lines (I forgot, did you keep your stocks?). Steal braded lines will stiffen the pedal feel for a better brake feel.
  14. Aug 15, 2014 at 6:51 AM
    Dusty T.
    Portland, OR
    It was late when I wrote that. The pedal does not go straight to the floor, though the travel is a little longer than previous. In order to get it to the floor, I need to pump it while holding it down, causing it to work its way to the floor. Come to think of it, every vehicle I've had has done this. I read that a little more pedal travel was to be expected with these brakes due to the MC bore and larger capacity in the calipers.
    Steel braided lines were installed, and bled the lines well beyond the point of getting no air out of them. Tested the brakes in neutral on a steep hill last night with a couple slow-speed stops, and they definitely work with less pedal effort, and do not pull.
  15. Aug 15, 2014 at 7:01 AM
    #35
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ill have to double check but I don't think my brakes go to the floor. The extra caliper size should not affect pedal travel. I second the "re-bleed" suggestion. You should always bleed starting from the back brakes, even if you only changed out the front (there are three fittings in the back. I say this because i had to do it twice because I forgot the third fitting).
    What color is your fluid? Mine was almost block so I flushed my fluid when I did this and recomend you do to if you decide to re-bleed the system. Bleed until you get clean fluid while someone monitors and fills your res keep it full.
    With the new calipers, your brake fluid will go below the "low line" before your pads are worn out, requiring extra fluid unless you want to replace the pads early. If you add fluid, remember this before putting on new pads or you will overflow your reservoir when compressing your caliper pistons.
  16. Aug 15, 2014 at 8:09 AM
    #36
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I've been running the napa calipers since 2008 and have had zero problems.
    I have excess pedal travel as well, i figured it was just from the bigger calipers, hasnt really been an issue. What will be interesting is when i get my rear 80 axle in with rear discs and stock MC.
  17. Aug 15, 2014 at 4:23 PM
    #37
    Dusty T.
    Portland, OR
    All very good advice.
    I did all 5 bleed points from the farthest to the closest (including the proportioning valve) as I also replaced the rear flex line.
    Fluid is crystal clear, and never went below the add line.
    No ABS or VSC, so that's ruled out.
    Other possibilities:
    -Stuck piston in one of the calipers
    -Rear brakes need adjusting
    -Air trapped in calipers, re-bleed
    -13/16" master cylinder is undersized
    -Master cylinder is worn out
    -That's the way it is and I'll get used to it :)
    Overall they work well and I don't mind a little extra travel. I would just like the pedal to be a little stiffer and not very slowly fade when I press on it hard.
  18. Aug 15, 2014 at 7:57 PM
    #38
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Hmm... My pedal felt stiffer and much better after my install :notsure:
    Might have been the new fluid I added though... (the old fluid was probably the original)???
    If everything is working within specs and you are stopping fine, you might just need to get used to the new feel I guess :D
  19. Aug 15, 2014 at 8:02 PM
    #39
    VAYoder4167
    Frank
    Lynchburg, VA
    Ok thanks and get the brakes from the toyota dealer? I believe I will be upgrading to 16's in the near future then so I can do this upgrade.
  20. Aug 16, 2014 at 11:35 AM
    #40
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I did the brake upgrade and it cost me $90 for rotors and calipers from a 2003 tundra. Bought at the local pick and pull junkyard. Went to a tire shop to resurface the rotors for $40. The calipers looked good and did not leak. My friend sandblasted them and tossed some red paint on them. Ended up using my existing brake line. Just drilled the bolt head with out a 3/8 bit. Swapped the parts over replaced the brake fluid and was done.
    Brakes and pedal feel are great. Hard braking would feel better with new steel lines. I even ended up using the old brake pads on the Tundra calipers just gave them a sanding. Along with some hard braking after installed. One the best and cheapest upgrades to do.
