Banjo Fitting Seal- Tundra Brake Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dusty T., Jun 24, 2014.
  1. Apr 16, 2015 at 2:29 PM
    #61
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    Yeah, i figured just a small weld would suffice, however id prefer to just do it how you did. Thanks again for the awesome write up. Cant wait to do mine. Fwiw, ive been double pumping my mc for a while ( bled the shit out of it too several times to no avail). so today i had a little time and said to hell with it, ill adjust the rears. Ive never so much as had the drums off in the 11 years ive owned my truck. God damn what a difference that made! I think a sticky should be made to tell people if they think their master is failing to check and adjust their rear brakes accordingly first. Hell of a difference
  2. Apr 16, 2015 at 4:52 PM
    #62
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    What is the 199/231 mm a measurement of?
  3. Apr 16, 2015 at 5:43 PM
    #63
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    It's the length of the available pad. Here is the best right up on the differences I have found.
  4. Apr 16, 2015 at 6:01 PM
    #64
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Wow. Nice writeup.
  5. May 6, 2015 at 12:35 PM
    #65
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    So how do you order pads and rotors for the 13WL upgrade?
    I'd like to order from EBC but I'm not sure how to select the pad shape and how to make sure I get the right size rotors. I was just planning to ask for rotors and pads for the 2005 Tundra. I know the diameter and width will be slightly larger than stock. Also I seem to recall that the rotor diameter can vary slightly if you have the TPS system which I don't of course.
    TIA
  6. May 6, 2015 at 2:56 PM
    #66
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah, just order pads/rotors/whatever for a 2005 Tundra, and they'll fit the 13WL or WG calipers. I'm not sure about the different rotors, IIRC they should all be 12.6" diameter.
    I just ordered EBC Green Stuff pads from Pep Boys, they have 30% off right now, and free shipping over $100. Jump on it.
  7. May 25, 2022 at 11:32 AM
    #67
    JDeRose
    JDeRose New Member
    2002 Tacoma Pre-Runner 2.7L Standard Cab
    ThunderOne, I'm about to head down this same path... Any tips on drilling the Banjo fitting? Thanks, JD
  8. May 25, 2022 at 11:43 AM
    #68
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    When I was doing my Tundra brake upgrade, I ditched the banjo bolt and bought an extended tundra brake line from Solo Motorsports. Screws right in. Give them a call.
