Bank two sensor one air/fuel ratio sensor no CEL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTacoma6, Nov 19, 2019.
  1. Nov 19, 2019 at 9:13 AM
    VTacoma6
    VTacoma6 [OP] Well-Known Member
    Vince
    Florida
    2015 Toyota Tacoma Trd Sport 4x4
    16 inch Matte Bronze FN Countersteer Type X wheels 0 offset With Goodyear Duratracs 265/75R16
    I have been tracking my gas mileage for over two months and have consistently been getting 17 city and 14 highway. took it to a Sparks computerized car care to hook up to a diagnostic computer. They said that bank two sensor 1 (air/fuel ratio sensor ) is not firing properly causing the truck to use more gas consumption. Weird thing is that I have no check engine light on, even the mechanic said it was weird. Has anyone else experienced this? From what I read the sensors can partially work “get lazy” and still not throw a check engine light on. Any insight is appreciated! Thanks
  2. Nov 19, 2019 at 9:16 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    they said your sensor should be firing? do you have an app like "torque" where you can read your own codes and see what is goin on? you can monitor your fuel trims with that and if they are out of wack that would be an indicator something was up, they typically wont throw a code unless your long term fuel trim is +-10%
  3. Nov 19, 2019 at 9:23 AM
    VTacoma6
    Vince
    Florida
    I forget the exact wording they use but somewhere along the lines of that sensor not performing 100%. So a sensor could be preforming at +-10% and not throw a code? I do not have that app but could look into it. Should I not be so sure that this is the issue?
  4. Nov 19, 2019 at 9:35 AM
    yota243
    E.J.
    north Alabama
    so your fuel trim is how much the computer is adding or subtracting to maintain set afrs (14.7 ish for the most part in closed loop) in a perfect world that would be 0 but that never happens because of any number of factors from temp change in the intake air to humidity the amount of fuel that is burn vs unburned that is sent out the exhaust ect, so in the real world i think about +-3% is the goal. however the computer will compensate past those parameters to keep everything running safely and anything inside about 10% is not enough out of the norm to warrant a code more often than not. I would recommend at least downloading torque if you have an android and looking at some of the stuff in there to get a better idea of what is going on with your truck. It could be the sensor, or you may have an injector that is stuck, or your evap canister may be bad could be pulling in a little extra fuel when the system check tank vacuum... have you changed anything on your truck recently?
    VTacoma6[QUOTED][OP] likes this.
  5. Nov 19, 2019 at 9:38 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    welcome to realization of typical tacoma gas milage..
  6. Nov 19, 2019 at 9:40 AM
    VTacoma6
    Vince
    Florida
    Not exactly. 14 highway and 17 city is flipped indicating something is wrong . Accepting those number as Efficient engine running would be coming to that realization.
  7. Nov 19, 2019 at 9:44 AM
    wheeliest
    Json
    TMPE AZ
    i apologize my sarcasm is incredibly dry.
    Torspd and VTacoma6[QUOTED][OP] like this.
  8. Nov 19, 2019 at 9:45 AM
    VTacoma6
    Vince
    Florida
    Thanks for the information. I have an iPhone. Not sure if that is Compatible. I had a k&n filter but took it out and went back to oem, I cleaned my throttle body and removed my gun/recovery case from my topper. None have improved my milage numbers. That’s where I gave up and paid 100$ to plug it into a computer . When they came back with this sensor not working properly I thought I had found the issue but just thought it was weird that everyone said I should’ve had a check engine light. I want to say that they checked everything else in the fuel system And it all showed to be working properly besides the bank two sensor 1.
    yota243[QUOTED] likes this.
  9. Nov 19, 2019 at 9:48 AM
    VTacoma6
    Vince
    Florida
    Lol you’re good just trying to figure out an issue outside of the “I have a truck and want 25 mpg” questions. I’ve came across backwards numbers and wanna figure out the issue.
