Custom Baofeng UV-5R/BF-F8, UV-82, UV-9S, UV-9R ram ball mount
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by supralee, Nov 14, 2020.
  1. Nov 14, 2020 at 12:11 PM
    supralee
    supralee [OP] Well-Known Member
    Lee
    Boulder, CO
    2018 Sandshark Tacoma DCSB 6MT TRD OR
    Hello,
    I design and manufacture custom ram ball mounts for the popular Baofeng UV-5R/BF-F8, UV-82, UV-9S, and UV-9R two-way radios.
    These mounts incorporate a 1/4-20 threaded insert and allows installation of a ram ball adapter. The ram ball adapter is not included and must be purchased separately.
    https://www.amazon.com/Mount-1-Inch-4-Inch-Threaded-Cameras/dp/B0059X0YIQ/ref=sr_1_3?dchild=1&keywords=1"+ram+ball&qid=1606001841&sr=8-3
    The UV-5R/BF-F8 mount will accommodate either the OEM 1800mah battery and OEM extended 3800mah battery. I have a separate variant that will fit the OEM 2100mah battery but will not work with the 1800mah or 3800mah battery.
    If you're interested in purchasing a mount, please specify which model radio, which model speaker-mic and which logo:
    Radio Options:
    UV-5R/BF-F8
    UV-82
    UV-9S
    UV-9R - Blank Only
    Speaker-mic Options:
    BF-S112
    QHM22D
    No Speaker-mic mount
    Logo:
    TRD logo
    TEQ logo
    Lexus Logo
    Blank
    I sell the ram ball mount for $40 Shipped CONUS.
    Thanks for your interest!
  2. Nov 14, 2020 at 12:40 PM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    looks 3D printed. What's the material used for the print?
    supralee[OP] likes this.
  3. Nov 14, 2020 at 12:43 PM
    supralee
    Lee
    Boulder, CO
    Hello @MasonSTL I use ASA material, it's more UV resistant than ABS, and mechanical properties are more favorable.
  4. Nov 14, 2020 at 12:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Meant to edit my post; I think these are pretty cool coming from someone that uses a Baofeng when I wheel with others.
    However, if you're making and selling these, I'm sure that goes against forum rules as you'll need to become a vendor.
    Just a heads up.
  5. Nov 14, 2020 at 12:56 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I think that only applies to sellers selling lighting products.
    https://www.tacomaworld.com/threads/buy-sell-trade-rules.392501/
  6. Nov 14, 2020 at 1:14 PM
    Vendiola7
    Vendiola7 Active Member
    Torrance, CA
    Do you have a pic of the mount without a radio in it?
  7. Nov 14, 2020 at 1:18 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    [​IMG] [​IMG]
    supralee[OP], msgs350 and Kwikvette like this.
  8. Nov 14, 2020 at 4:30 PM
    supralee
    Lee
    Boulder, CO
    @tomwil Thanks for all the help :) haha
  9. Nov 14, 2020 at 5:02 PM
    JDUB-Fabrication
    JDUB-Fabrication Well-Known Member
    Newburgh NY
    2010 Lexus GX460
    You should make one that mounts to a ram ball.. sure people, including me would be interested.
  10. Nov 14, 2020 at 5:24 PM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    This is pretty neat. Pics of how it mounts to the vent? Interested in one!
  11. Nov 14, 2020 at 5:25 PM
    supralee
    Lee
    Boulder, CO
    That's a great suggestion! I will try and design a mount that attaches to a ram ball. Which ram ball mount do you use?
    whatstcp, medicfung and Kopasz like this.
  12. Nov 14, 2020 at 5:32 PM
    supralee
    Lee
    Boulder, CO
    Thanks! It's a simple two tab design that snaps into the A/C Vent Ring.
  13. Nov 14, 2020 at 5:33 PM
    Kopasz
    Kopasz Well-Known Member
    Adam
    PDX
    ‘17 TRD/OR MT
    For a ram mount, would it be possible to make screw holes in the back so the end user could mount whatever ram ball size they need? I have cobbled together ram ball mounts on non-ram holders for various things using JB Weld, but it always looks like crap.
    supralee[OP] and thebaker like this.
  14. Nov 14, 2020 at 5:38 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    I would definitely be in if this mount was made ram ball compatible.
  15. Nov 14, 2020 at 5:39 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
  16. Nov 14, 2020 at 5:41 PM
    supralee
    Lee
    Boulder, CO
  17. Nov 14, 2020 at 5:43 PM
    supralee
    Lee
    Boulder, CO
    That's a great idea! With @tacoma_ca recommendation, I could get get a nut on the mount for the installation of different size ram balls. I had assumed that all ram balls were the same size.
  18. Nov 14, 2020 at 6:49 PM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    Count me in if it gets the ram mount upgrade
    Chukwithak, Kopasz and supralee[OP] like this.
  19. Nov 14, 2020 at 7:17 PM
    tacoma_ca
    The 1" ball is the size usually used for mounts like this. The Quadlock 1" ball adapter is a similar example.
    You can also get a 1/4-20 female threaded 1" RAM ball then have a 1/4-20 through-bolt in your device, which may be of interest for your structural design.
    https://www.amazon.com/Quad-Lock-Ball-Adapter-Mount/dp/B07F8H7VZS
    Kopasz and supralee[QUOTED][OP] like this.
  20. Nov 14, 2020 at 7:22 PM
    medicfung
    richie
    Why not just fab the 1” ball off the back into the design? One less piece to attach. You could fab 1” and 2”designs and sell whatever is in demand
