Bark collar help
Discussion in 'Off-Topic Discussion' started by Pickeledpigsfeet, Apr 27, 2021.
  1. Apr 27, 2021 at 11:41 AM
    Pickeledpigsfeet
    Pickeledpigsfeet [OP] Well-Known Member
    Foothills, CA
    pretty diverse crowd here, so figured I would check.
    Last year I ended up with a Great Pyrenese pup that had a deformed jaw so no one wanted her. She is now a 120lb polar bear. She is just so damn obstinate. She is great on leash. She will follow commands, unless she thinks her domain is under attack. She will bark even after we intervene,voice and physical(never hit). She lives with well trained dogs that do not bark.
    She is the most stubborn dog I have ever owned and that includes a couple beagles. She has been to a couple of pro trainers, now its time to try a collar. People in my neighborhood have recently had dogs poisoned for barking(I do have cameras but that wont bring my dogs back). Anyone had good luck with a bark collar brand and large breeds?
    I dont need/want to turn her into a hunting dog, but I need to be able to leave her alone and not worry that she barked all day.
    pics, cause why not?
    Gunshot-6A likes this.
  2. Apr 27, 2021 at 12:10 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Cute pup.
    We had a Chocolate lab for 10 years, she was calm, trained, and amazing, after a few year without a dog in the family we got another puppy last spring. She is a chocolate lab, but that's where the similarities with our old dog end.. lol.
    We did puppy school and house training, but ended up doing extra training with a local SAR and service dog trainer - she said our Maggie is very stubborn, and independent, but can be trained. It's been 14 months and she does well most days, she's still a hyper pup though.
    So we use a Garmin Delta Sport xc https://www.cabelas.ca/product/80092/garmin-delta-sport-xc-dog-training-bundle
    It has bark limiter but we don't use it. I don't like the idea of it buzzing her when you are not there. I wouldn't leave her home with it on.
    We buzz if she is distracted and not paying attention. It brings her right back. settings go from 1 to 18. I've worn it all the way to 18 on my arm. Our trainer said if you get up to 8 figure something else out.
    Most days putting the collar on her makes her pay attention, it's probably been two weeks since we actually buzzed her.
    Keep with it. You're doing good.
    Pickeledpigsfeet[OP] likes this.
  3. Apr 27, 2021 at 12:14 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I love my Garmin Pro 550. If you want something a little cheaper, try the Garmin Sport pro. Same collar, different controller. The bark funtion is awesome. Starts with a vibe, and then climbs through shock levels slowly. Used it on large dogs with great success.
  4. Apr 27, 2021 at 12:19 PM
    Pickeledpigsfeet
    Foothills, CA
    great point, I am only planning on using it while I am home. That may change, but at this time I am uncomfortable with having it active with no humans around to help in a emergency.
    vicali[QUOTED] likes this.
  5. Apr 27, 2021 at 12:22 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I had a full breed Doberman and used two separate bark collars that helped stop his barking. One was an automatic once that you’d set and leave on him and the other was remote controlled to use for training purposes. Coupled with a voice command the remote collar worked extremely well and eventually we phased it out and he just responded to the voice command. We kept it as part of his lead so he was never scared of it and always saw it as a good thing to wear his collar since he knew we’d be working outside.
    That being said I was never a fan of leaving a bark collar on with the dog unattended. There’s always a chance for failure with any electronic device and with the pup rolling around outside the chance of failure gets exponential.
  6. Apr 27, 2021 at 12:23 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    The other thing is it has to be tight, we used it for a month and it didn't seem to be working, we were always going up to 6,7,8.. our trainer checked and said it was way too loose - one finger under is plenty- pins have to be on her skin.. Also she only wears it for up to 4hrs in a row- then gets a break. Watch her neck for hot spots or sores and then it stays off.
    Charge on the collar lasts for 4 or so days, controller charge lasts forever.
  7. Apr 27, 2021 at 12:33 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    You can also introduce the bark collar with no pins, and leave it off for a week or two and just let the dog wear it. Let the pup get used to wearing a new collar without the added vibe/shock. You dont want the pup to get scared of the collar when you bring it out because it associated the collar with correction. Once the pup is used to wearing the new collar, add the pins. Then turn it on. Slow introduction, and slow addition of the correction. You're not trying to fry the pup into obedience, but rather guide it to the correct answer.
    vicali and Pickeledpigsfeet[OP] like this.
  8. Apr 27, 2021 at 12:48 PM
    gbinkley
    gbinkley Well-Known Member
    Garrett
    DFW, Tx
    13' Tacoma Double Cab
  9. Apr 27, 2021 at 1:57 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Most bark collars build. It's what I like about Garmins. Meaning they allow a certain number of barks to pass un-effected. Say 3. Then on the 4th it will vibrate. Bark 5 gets a level 1 stim. Bark 6 gets a level 2. Without you having to do any input, it trains the dog that barking for extended periods of time is not ok. After the dog stops, it resets back to zero. Another nice funtion of the Garmin is after you take the collar off and press the button, it will tell you how many times it corrected the dog via number of flashes of the light. So you can tell if it is working, or if the number is high, that your dog is just beasting it through the stim and it's time to find another solution.
  10. Apr 27, 2021 at 2:57 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    I’m going to make an unpopular suggestion. Before putting a shock collar on a dog wear one for a couple of days. Then ask yourself if it’s still a great idea.
    like choke collars especially those with prongs they should be outlawed.
  11. Apr 27, 2021 at 3:07 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    There's nothing wrong with a quality E-collar OR a well made prong collar (such as a Herm Sprenger). A prong collar simply dissuades pulling on leash and does very well for my dog. His E-collar also lets me take him places he would otherwise get left home due to safety concerns such as snakes or moose where he gets a little too excited to remember his recall.
    The BUT of that statement has everything has to do with the owner, and where I agree with your sentiment. A prong collar just takes a small wrist movement to tighten up a smidge and remind the dog its not OK to pull, etc. If I catch someone working that collar like setting a hook on a sailfish, they're gonna have a problem.
    And yes, I have used Draco's E-collar on myself before I ever thought of putting it on him. Low settings feels like a static shock on a doorknob. It's uncomfortable but far from malicious. The stronger levels def get your attention, but is a far better option than my dog being stomped to death by a moose.
    t.hornstra and vicali like this.
  12. Apr 27, 2021 at 3:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It’s a working dog, get it out more.
    Yo'ta and Gunshot-6A like this.
  13. Apr 27, 2021 at 3:14 PM
    Gunshot-6A
    Conner
    Everett, WA
    Second this. Not sure what exercise regimen she's getting, but for that breed, it's likely not enough.
    (not a judgement on OP, just a statement for a working dog)
    JKO1998[QUOTED] likes this.
  14. Apr 27, 2021 at 3:15 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I agree with part of your post. You should definitely know what it does when you push the button. I hit myself with my 550 Pro as high as it would go before ever putting on my dog. It put me on the ground no joke. Through endless work and dedication, my dog never goes above a 3 low. The 550 has 1-8 low, 1-8 medium, and 1-8 high for stim. It's all about letting the dog know when hes over stepping. The stim is just a reminder that you are in control. Same as spurs for a horse. You tap him, not stab him when you want to make a correction.
    So yes, I've hit myself with my shock collar as painful as it will go. I also know what a 2-3 low feels like, because that's what I use on my pup. And I still think it's a great tool.
  15. Apr 27, 2021 at 3:17 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    I use the Garmin sport and it’s worked well
    Also. Gotta ask. Where in NorCal are you that people are poisoning dogs? I’ve left mine outside for quick trips to run errands.
  16. Apr 27, 2021 at 3:24 PM
    Gunshot-6A
    Conner
    Everett, WA
    Draco's the same way. He's been more behaved even with it off his neck after training, but he def knows when he has his "good boy collar" on. I don't even have the remote turned on 99% of the time.
    Mine has vibe for recall and stim for correcting behavior, and several trainers have told me its good to vibe him every once in a while while recalling him as a refresher. Not sure that advice works for barking though.
  17. Apr 27, 2021 at 3:25 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Yep, wore ours around zapping myself from lowest to highest for two days before I put it on our pup, wouldn't have got one except under the guidance of our trainer. I hate to think of owners picking it up and frying dogs..
    Also why I won't use the bark/auto escalate settings - and why our trainer showed it to us as a never use- Dog barks, it zaps, dog squawks, gets zapped again, etc etc.
    Also better than our dog going back to the breeders at 6 month old- seriously we had family meeting sitting around the table with pupper barking her head off in the background and us saying either we train her and put in the work, or this isn't going to work.
    super helpful mate.
  18. Apr 27, 2021 at 3:25 PM
    Gunshot-6A
    Conner
    Everett, WA
    Oh and also, obligatory OMGZ FLUFFY PUPPY!
    vicali likes this.
  19. Apr 27, 2021 at 3:33 PM
    JKO1998
    Utah
    Works for our working dogs :notsure:
    Leave them in a kennel for a couple weeks and the story changes
  20. Apr 27, 2021 at 3:59 PM
    Yo'ta
    Yo'ta Well-Known Member
    ^^^ - I think your point is to get the dog Outside and Working and under command in different environments and stimuli so the dog is constantly learning to listen. I do not think you point was just to get the dog "outside".
    JL
