BartMaster1234's (Almost) Supercharged 2.7l 1998 PreRunner 4x4 Conversion [Build Thread]
Discussion in '1st Gen. Builds (1995-2004)' started by BartMaster1234, Jun 14, 2017.
  1. May 22, 2019 at 4:32 PM
    #281
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    It is. I enjoy the novelty and rarity of it.
  2. May 22, 2019 at 4:34 PM
    #282
    BartMaster1234
    BartMaster1234 [OP] Well-Known Member
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I don’t, it makes it more expensive. Haha.
    rogerman[QUOTED] likes this.
  3. May 22, 2019 at 4:35 PM
    #283
    rogerman
    Roger
    HNL 808, SPN 670
    Great white buffalo
  4. May 22, 2019 at 4:41 PM
    #284
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    :headbang:
    Love the build, great looking truck man!
  5. May 22, 2019 at 4:44 PM
    #285
    BartMaster1234
    Tyler
    Flux Capacitor
    Thanks bud!
    BassAckwards[QUOTED] likes this.
  6. May 22, 2019 at 10:51 PM
    #286
    BartMaster1234
    Tyler
    Flux Capacitor
    I'm copying this from the Northern CA BS thread, maybe someone can help me out with this issue I'm having.
    Can anyone diagnose a no-start issue for me?
    Story goes I installed a supercharger on my truck, 1998 PreRunner 4x4 2.7l I4 3RZ-FE. First time I cranked it, fuel was spurting out of Injector 4. I pulled the fuel rail the next day and replaced the O-Rings. Bingo, no more fuel leak.
    However the truck would not turn over. It would slowly crank, but never start. It sounds like a dying starter or a dead battery.
    So here's what I did: I tested the battery, 11.6 volts. Should be fine. Then I tried jumping it with my Mercedes-Benz E320, same result. Slow crank, no difference.
    Then I unhooked the battery from the Tacoma completely and ran jumper cables directly from the Mercedes to the battery harness on the Tacoma. I held the E320 at 2,000 RPM. 13.8v at the Tacoma battery harness (sans battery)
    Surprise! Same issue, slow crank.
    I suspect bad starter, so I pull it out and take it to AutoZone. It passed with flying colors. However, I question the validity of AutoZone's test. I haven't tested it against the Toyota FSM yet, but I plan to.
    I checked the resistance between the positive battery cable and the positive stud on the starter. Varies between 0.4 and 0.6 Ohms. Normal. I tried grounding the starter directly to a good ground point (LCA bolt) via jumper cable, no difference.
    I touched two grounds: Firewall x Engine Block, and Intake Manifold x Injector Harness. They're both grounded fine it appears, I filed down the paint on the manifold ground. I ripped off the engine coolant sensor by accident, but I repaired it. That's about it electrical wise besides unplugging sensors on the block and manifold plus EGR.
    Here's a video of it cranking. Any ideas?
    https://streamable.com/t4ckw
  7. May 22, 2019 at 11:17 PM
    #287
    rogerman
    Roger
    HNL 808, SPN 670
    Crank position sensor?
  8. May 22, 2019 at 11:22 PM
    #288
    BartMaster1234
    Tyler
    Flux Capacitor
    Now that’s not that tiny two wire sensor under the intake manifold is it? I think I’m thinking of the knock sensor.
    I messed with that connector for a while and there’s a possibility I could’ve damaged it.
  9. May 22, 2019 at 11:25 PM
    #289
    rogerman
    Roger
    HNL 808, SPN 670
    Is it throwing any codes?
  10. May 22, 2019 at 11:26 PM
    #290
    BartMaster1234
    Tyler
    Flux Capacitor
    I unhook the battery so often it hasn’t had a chance to register for codes.
  11. May 22, 2019 at 11:27 PM
    #291
    rogerman
    Roger
    HNL 808, SPN 670
    Ah that is right. Have you verified spark during cranking?
  12. May 22, 2019 at 11:31 PM
    #292
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Why are we talking about codes and sensors, it isn't cranking fast enough to start. It's one of three things, starter, battery, cabling...
    rogerman likes this.
  13. May 22, 2019 at 11:31 PM
    #293
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    yea its in the starter or wiring.
    a voltage drop test needs to be done.
    rogerman and Speedytech7 like this.
  14. May 22, 2019 at 11:32 PM
    #294
    Empty_Lord
    Dan
    i can almost bet its dropping 2 or 3 volts when cranking for some reason (can indeed be starter)
  15. May 22, 2019 at 11:33 PM
    #295
    rogerman
    Roger
    HNL 808, SPN 670
    These guys know more than me. Listen to them lol
  16. May 22, 2019 at 11:41 PM
    #296
    Empty_Lord
    Dan
    it only helps that we've seen the video, if you saw it youd know whats up lol
  17. May 22, 2019 at 11:45 PM
    #297
    rogerman
    Roger
    HNL 808, SPN 670
    You are totally right
    Edit: watched vid when I got home. Still don’t know. Disregard my suggestions. TW and drinking is not good lol.
  18. May 23, 2019 at 11:23 AM
    #298
    Empty_Lord
    Dan
    TW and drinking is how you end up broke
  19. May 23, 2019 at 11:45 AM
    #299
    BassAckwards
    Im wondering if this is fuel pump related. Im guessing you replaced yours when it was supercharged?
  20. May 23, 2019 at 11:45 AM
    #300
    BassAckwards
    If you give the tank a hard wack, does it start right up?
