BartMaster1234's (Almost) Supercharged 2.7l 1998 PreRunner 4x4 Conversion [Build Thread]
Discussion in '1st Gen. Builds (1995-2004)' started by BartMaster1234, Jun 14, 2017.
  1. Jan 23, 2018 at 9:55 AM
    #161
    tony2018
    tony2018 Well-Known Member
    I did, tapes are marked on the passenger side drum/brake shield and the pinion.
    1 full tire/axle rotation = 1 7/8's full shaft/pinion rotation.
  2. Jan 23, 2018 at 10:01 AM
    #162
    tony2018
    So I went back and instead of rotating the axle/tire I rotated the shaft a couple times. I then marked the starting positions and now I get
    1 full axle/tire rotation = 2 1/8 pinion/shaft rotation.
  3. Jan 23, 2018 at 10:03 AM
    #163
    tony2018
    Let me make a video. Wonder if we can upload videos here..
  4. Jan 23, 2018 at 10:58 AM
    #164
    tony2018
  5. Jan 23, 2018 at 11:05 AM
    #165
    BartMaster1234
    BartMaster1234 [OP] Well-Known Member
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I prefer the method where you rotate the shaft/tire 10 times and divide. When I rotated the tire 10 times, the driveshaft spun 21.5 times. 21.5 x 2 is 43 or 4.30.
    tony2018 likes this.
  6. Jan 23, 2018 at 11:10 AM
    #166
    tony2018
    Did you chuck one side and spun the other?
  7. Jan 23, 2018 at 11:16 AM
    #167
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes. Keep the other tire on the ground.
    tony2018[QUOTED] likes this.
  8. Jan 23, 2018 at 11:17 AM
    #168
    tony2018
    Getting pissed.
    Eating ice cream and watching soaps
  9. Jan 23, 2018 at 11:32 AM
    #169
    tony2018
    Ok, little bit of relief...now gotta go back to work.
    BartMaster1234[OP] likes this.
  10. Jan 24, 2018 at 4:39 AM
    #170
    Hadmatt54
    Hadmatt54 Member
    2003 Prerunner Quad Cab
    4wd conversion
    If your replacement diff is open, then the tire stays on the ground and because of your spider gears your revolutions get multiplied by 2. If it is in a locked state, then both tires have to move and the 10 turn method will give your exact ratio. Your spider gears don't come into play.
  11. Feb 1, 2018 at 3:51 PM
    #171
    tony2018
    so whats up? verdict on the tranny after a couple miles?
  12. Feb 1, 2018 at 4:20 PM
    #172
    BartMaster1234
    Tyler
    Flux Capacitor
    I have to type a full update soon - but the flexplate broke two times. The torque converter I used from the wreck was warped and it kept cracking the flex plate. I picked it up yesterday and it drives fine with the new torque converter.
  13. Feb 1, 2018 at 4:41 PM
    #173
    tony2018
    Yeah I read, if all is good just be glad it runs. Sucks that the torque converter was bad, who knows what else could be?
  14. Feb 14, 2018 at 3:33 PM
    #174
    BartMaster1234
    Tyler
    Flux Capacitor
    jgill21 likes this.
  15. Mar 18, 2018 at 9:33 PM
    #175
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    When's that 4x4 swap write-up coming? :boink:
  16. Mar 18, 2018 at 9:39 PM
    #176
    BartMaster1234
    Tyler
    Flux Capacitor
    I've been working on it slowly on and off for the past couple months. It's going to be absolutely overkill - take a look at the "How to Make a Fuseblock" thread on the Technical subforum to see exactly how overkill I'm going to be on this write up.
    I have spreadsheets and charts and everything. LOL.
    SilverGhost likes this.
  17. Mar 18, 2018 at 9:49 PM
    #177
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Sweet! Looking forward to it. If there's one thing I appreciate on here, it's detailed write-ups.
  18. Mar 20, 2018 at 5:04 PM
    #178
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Finish this dang write-up so I can swap and wheel!:D Lol I looked at your other writeup..... Don't think I could possibly get confused on this swap :thumbsup:
  19. Mar 20, 2018 at 9:33 PM
    #179
    BartMaster1234
    Tyler
    Flux Capacitor
    Which writeup?
  20. Apr 5, 2018 at 1:38 AM
    #180
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    4x4
