Base 4cylinder lift, flares, wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacome2012, Aug 21, 2019.
  1. Aug 21, 2019 at 10:03 AM
    tacome2012
    tacome2012 [OP] Member
    2012 Tacoma 4cyl Base Access Cab
    Hi there I'm new to the forum and could use a little direction. I am looking at purchasing a 4cylinder, base, 2wd, Access Cab Tacoma for my son. Our budget does not stretch to a PreRunner or 4wd so would like to see if Tacos are like legos!
    Our goal is to make this look a bit tougher and more like a pre-runner on a budget. I see there are pretty good deals on local craigslist for Gen 3 TRD wheels/tires, and we can buy stock style flares and TRD style grills on EBay or paint grille surround factory red. Should we do a lift for these mods or can we upgrade to factory PreRunner shocks/springs or is it best to go aftermarket? Appreciate any feedback/suggestions! I am reading/searching here but most of what I am finding is upgrading PreRunners/4x4's.
    Current
    Look we are going for (not as lifted though)
    Thanks,
    Andrew
    drewskie likes this.
  2. Aug 21, 2019 at 10:23 AM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    The suspensions between the base and the prerunner or 4WD are different. You can get lift kits for the base, but with the money you will be spending, you might as well get a prerunner at least. You won't be able to use the TRD wheels. Those are 6 lug and the base use 5 lug wheels.
    Thuguon2.7 and drewskie like this.
  3. Aug 21, 2019 at 10:24 AM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    Others with more expertise are sure to chime in here, but I believe the base tacoma uses a 5-lug wheel. So the wheels you're looking at from the 3rd gens (from a pre-runner or 4x4) use 6-lug and therefore aren't compatible. You can however switch grilles, flares, bumpers, mirrors, headlights, taillights, etc.
    cruxofthebisquit and whatstcp like this.
  4. Aug 21, 2019 at 10:30 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Perhaps the largest problem you face is the fact that the truck you have has 5 lug wheels and an altogether different suspension setup than the 4x4/ prerunner with 6 lugs.
    Lift spindles and a SOA (spring over axle) kit are what you should start looking into.
    IMO it will certainly be easier (possibly even cheaper) to just get a prerunner.
    Thuguon2.7 and tacom08 like this.
  5. Aug 21, 2019 at 11:25 AM
    tacome2012
    Exactly the kind of feedback I was looking for. Thank you.
  6. Aug 21, 2019 at 11:30 AM
    Mike714
    Cypress, CA
    You're welcome! What's your budget and where are you located?
  7. Aug 21, 2019 at 11:36 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    @tacome2012 I've had a 4 banger in the past pretty much all the body/interior parts are interchangeable but as many mentioned the wheels and suspension wont swap over.
    If you're still interested in a 5lug and want a lift I've got a spacer and aal for sale. I never really took the truck off road (graded forest roads) the spacer and aal worked for my needs let me know.
    https://www.tacomaworld.com/threads/taco505-fs-thread.614041/#post-20913685
  8. Aug 21, 2019 at 11:41 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I think it would look cool with car wheels and tires, keep it 2WD sport truck style. That doesn't seem the direction you want to go. I think a 6lug prerunner would also look good.
  9. Aug 21, 2019 at 11:48 AM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    As far as wheels go those of us with 5 lug Tacomas don't get all the neat off road styles.
    Wheels from Toyota Highlanders and RAV4s are usually a straight swap.
    I've got a set from a RAV4 on my 2015 5 lug (and yes, I know the tires look small but I'm trying to wear them out before replacing)
    Also, there is a section of the forum dedicated to 5 lug Tacomas
    REDdawn6 and batacoma like this.
  10. Aug 21, 2019 at 12:06 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I like my 5 lugger...
    grrck, BassAckwards and LocoLocal like this.
  11. Aug 21, 2019 at 12:13 PM
    CaliforniaTacoTuesday
    CaliforniaTacoTuesday Well-Known Member
    You do what makes you happy little 5 lugger! Just be yourself and people will love you for who you are.
  12. Aug 21, 2019 at 12:15 PM
    Skyway
    Ande'
    St.Pete
  13. Aug 21, 2019 at 12:33 PM
    That thing is beautiful.
    drewskie and BassAckwards like this.
  14. Aug 21, 2019 at 12:47 PM
    tacome2012
    Awesome guys thank you. About $1500 budget to modify for now. Taco is $8K with 77K on the clock. Everything prerunner or 4wd with under 100k mi. in the SF Bay Area, CA is $15-20k. Crazy.
    drewskie and whatstcp like this.
  15. Aug 21, 2019 at 12:54 PM
    Skyway
    Ande'
    St.Pete
    Those are chrome wheelskins on the wheels.
    Remove those and improve the look.
    235's for tires add 1" lift.
    window tint, AVS weather visors, any small repairs to the motor, maintenance.
    Stay in TW for very long and you'll have that $1500- spent.
    Search in the 5 lug forum.
    There's lots of info.
    Larzzzz and taco.the.track like this.
  16. Aug 21, 2019 at 12:56 PM
    Skyway
    Ande'
    St.Pete
  17. Aug 21, 2019 at 12:56 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    I looked at a 5 lug before buying my Prerunner. If I’m not mistaken, the largest tire size without a lift is 235/75-15. Of course if you go with a lift you can go bigger. Like several have said, check out the 5 lug thread and see what some of those folks have done.
    Skyway likes this.
  18. Aug 21, 2019 at 1:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    Love my 5 lug. I have no need for bigger, badder or 4wd. Or a pre runner poseur 4wd. It does all I need and a bit more. Kayaks, bicycles, freight, no problem. Car like handling and ride. Add intermitant wipers and fogs for safety. 235.75.15 on oe wheels work just fine, no alterations needed. And you get a real 1" of ground clearance.
    cruxofthebisquit, Skyway and whatstcp like this.
  19. Aug 21, 2019 at 1:33 PM
    Skyway
    Ande'
    St.Pete
    I would like Cruise Control.
  20. Aug 21, 2019 at 1:46 PM
    tacome2012
    This is a very active site/forum! Thanks you all for the links to 5 lug world so I can dig in and read up to formulate a plan. In the end we may elect to go older/higher mileage to fit in our budget and start off 6 lugs. Will post up final direction when we get there.
