Base Model rims black?
Discussion in 'Wheels & Tires' started by ClemsonTacoma, Jul 7, 2009.
  1. Jul 7, 2009 at 5:10 AM
    ClemsonTacoma
    ClemsonTacoma [OP] Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    anybody d[​IMG]one these rims black?
  2. Jul 7, 2009 at 5:23 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I did !!!!!! I left the silver rings because of not wantinr to paint over the weights.
  3. Jul 7, 2009 at 6:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    The sliver lip looks good on your truck.
  4. Jul 7, 2009 at 6:44 AM
    Rtrn2taco
    Philadelphia
    Thanks, debating on wether to leave it or not when it comes time for tires.
  5. Jul 7, 2009 at 6:50 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I prefer Flat black for the stockies. Gloss paint draws the eye to the rims which the basic design doesn't really warrant.
  6. Jul 7, 2009 at 6:58 AM
    Brunes
    Brunes abides.
    Rotorhead
    I get my rims "static balanced"-Wheel weights on the inside only. I don't mind if they marr the paint on the inside of the rim.
    You can also look at products like Equal- which is put inside the tire and balances it using centripetal force.
  7. Jul 7, 2009 at 6:59 AM
    excalis
    excalis Well-Known Member
    TRD Off Road 4x4
    What type of paint was used for the wheels? What kind of prep work was done before the paint went on? Did you leave the wheels on the vehicle when the paint was sprayed?
    Just noob questions, I want to try this on my truck and save me some cash for now until I order the ones from Rebel Racing.
    Thanks for your time!
  8. Jul 7, 2009 at 7:00 AM
    Brunes
    Brunes abides.
    Rotorhead
    There are tons of threads around about how to.
    I took them off the truck, cleaned them good, sanded with wet 800 grit, primer (X2), paint (x3), cured in the house overnight and remounted.
  9. Jul 7, 2009 at 7:02 AM
    excalis
    TRD Off Road 4x4
    I appreciate the reply, I will look through the other threads. Been doing that for cruise control, etc but thought I would ask this question here.
    Thanks!
  10. Jul 7, 2009 at 7:04 AM
    drew02a
    San Antonio, TX
    I thought about all that stuff too. before I did mine a couple weeks ago. Here's what I did.
    Washed the rims really well
    Wiped down with a solvent (brake parts cleaner)
    Taped around the edge of the tires so I wouldn't get too much paint on them
    Sprayed first coat (Rustoleum Flat Black Enamel for Industrial Applications)
    Let cure 24hrs
    Second Coat
    Let cure 24hrs
    Removed tape and sprayed any spots that were covered by it
    Third coat
    Let cure 24hrs
    You probably don't need to wait so long between coats. I did because my truck isn't drivable at the moment and I had plenty of time to finish.
  11. Jul 7, 2009 at 7:11 AM
    Rtrn2taco
    Philadelphia
    I did my wheels when almost new so I had to deal with minimal knicks and scratches. I used 400 grit sand paper to prep and prep-all to clean the surface when done.
    Started with two coats of primer, sanding out any runs or defects when finished and cleaned again with prep-all. I removed the tires from the truck ( I thought it would be easier lying flat on ground) and taped off the silver outside lip. I didn't find it neccasary to tape the tire as the paint comes right off when finished. 2 light coats of the Duplicolor satin black wheel paint waiting 30min or so between and one final wet coat.
    Duplicolor has a how to vid on there website if you feel the need to check it out. The finish has held up perfectly over the 16 months since I did it. Easy to do, Good Luck !!!
  12. Jul 7, 2009 at 7:15 AM
    stevigee
    stevigee It's a MOD, MOD World
    Stevigee
    Amarillo Texas
    2010 TRAIL TEAMS FJ CRUISER
    TRADED FOR 2010 FJ CRUISER TRAIL TEAM Kenwood KDC x792 deck and SW1 pwr sub,cruise,intermittent wipers,hidden hitch, tint, debadge,Nitto Grapplers 265/75-16,Black Powder Coated Toyota Steelies, black steel Toyota wheel center caps, Vent Visors, front guard, leather seat covers, black front badge, shortie antenna, tow hook, seat maglite mod, shock & leaf spring TSB, Extang Trifecta tonneau cover, custom black Fabwright rock sliders 1 3/4" DOM tubing w/ kickout, skid plate, Pop-A-Lock, Bilsten 5100 shocks, BLHM, Azela black tail lights, LEER topper w/rack, tent
    Mine are powdercoated.
  13. Jul 7, 2009 at 7:21 AM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    thanks guys, i have been debating this for a while, and i haven't really seen any stock rims blacked out...i like the look of flat black but it seems like its not even.
  14. Jul 7, 2009 at 7:23 AM
    drew02a
    San Antonio, TX
    LOL, I dripped some gear oil on that one and haven't had a chance to clean it off all the way. :)
  15. Jul 7, 2009 at 8:59 AM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    oh, that looks good then minus that
  16. Jul 7, 2009 at 9:09 AM
    excalis
    TRD Off Road 4x4
    I usually run my truck through the local drive-thru car wash, think the paint will hold up to that?
