Base VS Prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1911, Feb 4, 2013.
  1. Feb 4, 2013 at 2:10 PM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    What are the mechanical differences between the 2 styles in the Regular Cabs? Does the prerunner have bigger brakes or more payload capacity? Anything Else?
  2. Feb 4, 2013 at 2:34 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    As of the 2013 Tacoma models, prerunners only come in extended cabs. Reg cabs are available in 2wd and 4wd only.
  3. Feb 4, 2013 at 2:44 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Prerunners only come in 2wd. They have the 4*4 suspension and tires.
  4. Jan 27, 2016 at 5:50 PM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    Resurrecting this thread
    Is a 4x4 considered a base model?
    Been searching for exhaust and when choosing I'm given the options of base or pre runner. 4x4 doesn't seem like base to me but pre runner means 2x4 set up like a 4x4
  5. Jan 27, 2016 at 8:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Prerunner will have the exact same exhaust as the 4x4 with the same engine.
  6. Jan 27, 2016 at 8:35 PM
    Pigpen
    Dan
    Northwest Montana
    My base model is a 4x4...
  7. Jan 27, 2016 at 8:41 PM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    Base is the stripped down 4x4.
    Sr5
    Sport
    OffRoad
    Limited
    Are the levels of the trucks.
    pats73 likes this.
  8. Mar 11, 2016 at 12:53 PM
    supra90140
    telford pa
    so when given the option and you have 4x4 one should use base and not pre runner when searching for parts?
  9. Mar 11, 2016 at 9:33 PM
    jokker1978
    southeast texas
    Part house is base or prerunner
  10. Mar 12, 2016 at 4:11 AM
    Rattlejay65
    Rattlejay65 Well-Known Member
    J.R.
    2015 Tacoma TRD Off Road
    I use the base. Mine is a 4x4 with off road package, 6 lug, but it says base model. I kind of wonder if they are talking about the difference between 5 lug and 6 lug. I have seen them marked as such, and as pre-runner vs 4x4 on certain things. But almost all parts I've seen do differentiate between 5 and 6 lugs.
    pats73 likes this.
