Bashing headers
Discussion in 'Performance and Tuning' started by windsor, Jan 23, 2016.
  1. Jan 23, 2016 at 9:04 PM
    windsor
    windsor [OP] Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  2. Jan 24, 2016 at 5:06 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Saw this. It was very interesting, but i guarantee you its not the same for all applications. Some will have an effect.
    AustinPizzini likes this.
  3. Jan 24, 2016 at 5:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Basically, it works. The reason it works is obvious. The header's primaries were too large a diamerter for each cylinder. Crushing increased scavenging to point, before they were beat to much.
    A laminar flow test or CFM test would prove that they were being under utilized. It has already been brought up by plenty of engineers in dicussion with them. They even agreed.
    Simple before and after pinches readings of primary temperature changes, would have also been helpful in showing loss of flow due to resrtictions. With a laser temp gun or similar device.
    The average "Joe" might find this quite useful in the fitment needs.
    Lucario Runner and WOODEX M.E. like this.
