BASHING SPACERS FOR MILD LIFTS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Dec 2, 2010.
  1. Dec 22, 2010 at 5:02 PM
    #401
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    So you got an AAL set, and blocks?
  2. Dec 22, 2010 at 5:05 PM
    #402
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2? :confused:
  3. Dec 22, 2010 at 6:15 PM
    #403
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
  4. Dec 22, 2010 at 6:29 PM
    #404
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Won't the leaf and spacer maintain the front rake?
  5. Dec 22, 2010 at 6:33 PM
    #405
    98tacoma27
    Ben
    Not Beech Creek
    You only need one, preferably the AAL.
  6. Dec 22, 2010 at 7:11 PM
    #406
    DCW
    DCW Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    Truxxx puts out a 3in spacer kit that is on top of the strut so it is not preloading the spring. And by the way toyota will cover all suspension parts if somthing breaks if you have them install the kit.
  7. Dec 22, 2010 at 7:17 PM
    #407
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This has been discussed. The top plate spacer lengthens the shock/spring assembly, stressing the ball joints, and can possibly lead to breakage of the shocks.
  8. Dec 22, 2010 at 7:27 PM
    #408
    DCW
    David
    Reno, Nevada
    Ok, where did you get that info I would like to read about it. cant find any sites that will speak the truth about the stress because all the sites say their product is the best and tell you what you want to hear. All the pros and no cons thanks for the help in advance.
  9. Dec 22, 2010 at 7:28 PM
    #409
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the info can be found on this site. Some even in this thread.
  10. Dec 22, 2010 at 7:40 PM
    #410
    DCW
    David
    Reno, Nevada
    I had an fj with Icon coil overs they were great a buddy of mine had a spacer lift on his taco 09 and he went everywhere i did and he liked the stock ride. I guess its what you like thats why they make toyota, ford, chevy,dodge you can have choices.
  11. Dec 22, 2010 at 7:44 PM
    #411
    Taco-NB
    New Brunswick
  12. Dec 22, 2010 at 7:49 PM
    #412
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  13. Dec 22, 2010 at 7:52 PM
    #413
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  14. Dec 24, 2010 at 12:50 AM
    #414
    numbah57
    kahai
    Maui, Hawaii
    Make this thread the million post thread. Talk shit bout spacers all the way to the millionth post.
  15. Dec 24, 2010 at 5:29 AM
    #415
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    :laugh:
  16. Dec 24, 2010 at 6:33 AM
    #416
    Hawaiitaco
    Hawaiitaco Well-Known Member
    Hawaii
    TRD OFF ROAD
    Blue Sea Fuse Box, led bed lights and ground lights
  17. May 4, 2011 at 2:48 AM
    #417
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    Chris,
    I understand the top plate spacer lengthens the shock/spring assembly compared to factory, But any lift (spacer, Coil over,etc)except body lift has to increase in length compared to factory to achive lift.
    So i pretty sure that the strut failure/snaping that have been pictured are not due the normal riding conditions but due to bottoming out the struts because the bumpstops no longer are effective because the contact point of the bumpstop is not within the struts travel. No strut is designed to bottom out.
    Installing extended bumpstops should fix this?
  18. May 4, 2011 at 5:28 AM
    #418
    TexasTacoma37
    What Chris is referring to is that top plate spacers actually lengthen the entire spring/shock assembly, allowing for more droop than the IFS was designed to handle. That's what stresses the ball joints.
    Other types of lifts (preload spacers, stiffer coils, etc) do not do this. All they do is make you lose 3" of down travel on the shock, but the overall extension at full droop is the same as stock.
  19. May 4, 2011 at 8:08 AM
    #419
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, They achieve lift by adding preload to the spring. The pre load spacers fit into the OEM length shock/spring assembly.
  20. May 4, 2011 at 8:26 AM
    #420
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Ready Lift FTW..seems all this talk about spacers is for 4x4..my taco is a 2wd and the ready lift kit gave me an awesome lift. The ride is factory. I like most people will never go hardcore off roading so couldn't justify spending 800 some dollars on coil overs. I'm happy with my readylift. Also no vibrations like with other lifts.
