Basic lift questions
Discussion in 'New Members' started by whiskersfox, Oct 14, 2014.
  1. Oct 14, 2014 at 10:12 AM
    whiskersfox
    whiskersfox [OP] Active Member
    Aaron
    La Habra, CA
    '07 PreRunner TRD OffRoad 4Door Short Bed
    Icon coilover, total chaos UCA, OME rear spring, Icon shocks, custom rear lights for bed, all pro rear bumper, all pro IFS skid
    Hello TW. I am new here and this is my first post. I just purchased a 2007 2WD 4 door, short bed, prerunner, TRD offroad. I am looking into doing a lift for it. I am on a budget, however, I am a firm believer in a TRUE lift (one that adds travel as well). I have determined that the only way to do that is coilovers. I am looking at the 3" Toytec BOSS suspension kit with the progressive AAL pack. Does anyone have any thoughts on it?
    This is the link for the kit I am looking at: http://toyteclifts.3dcartstores.com/Boss-Suspension-System-for-05-Tacoma_p_15.html
    Also, I will be purchasing new UCAs (Total Chaos which I am also open to information about) but am curious what other small things are needed/ recommended when doing a lift like this such as brake lines, etc. I have seen a few things but hoping someone can sum it up for me.
    THANKS TW!!!
    -Aaron
  2. Oct 14, 2014 at 10:16 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    First off welcome to TW Aaron!
    Two things I would add are extended brake lines and the carrier bearing drop kit. Depending on what shape the shock leaf packs are in, I would consider getting a new leaf pack. Other than that, you're off to a good start :thumbsup:
  3. Oct 14, 2014 at 10:23 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    ^ pretty much what he said.
    Welcome to TW!
  4. Oct 14, 2014 at 10:27 AM
    whiskersfox
    Aaron
    La Habra, CA
    I was considering a new leaf pack as I heard the stock leafs have some issues sometimes. What do you know about OME Dakar Leaf Packs? These are offered with the suspension kit I am looking at as an alternative to the AALs. Also, keep in mind I am going for about 1.5" in the rear.
    -Thanks!
    -Aaron
  5. Oct 14, 2014 at 10:28 AM
    geekhouse23
    I run dakars. What do you wanna know? lol
  6. Oct 14, 2014 at 10:29 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Good lift kit go with 1.50 AAL better then Blocks with the OEM Dakars might need CB drop Kit if carry weight go with Dakars Love mine
  7. Oct 14, 2014 at 11:51 AM
    whiskersfox
    Aaron
    La Habra, CA
    Well in generally how do you like the ride? And how much did it lift your rear?
  8. Oct 14, 2014 at 11:58 AM
    geekhouse23
  9. Oct 14, 2014 at 12:13 PM
    whiskersfox
    Aaron
    La Habra, CA
    Thats a little too tall for what I was thinking. I was hoping to get around 1.5-2.0 inches.
  10. Oct 14, 2014 at 12:22 PM
    geekhouse23
    If the stock leafs have had issues, might be a good idea to just replace them now. If you add a progressive AAL or an AAL to shot leafs, you will ultimately have to replace the pack completely. Save some money and do it right from the start..otherwise risk having to buy technically 2 rear lift kits..
  11. Oct 14, 2014 at 10:05 PM
    whiskersfox
    Aaron
    La Habra, CA
    I agree completely, just trying to find a good quality leaf pack that provides the size lift I am looking for. Any info would be greatly appreciated!!!
  12. Oct 14, 2014 at 10:14 PM
    zboy
    Oahu808
    12 TRD OR
    Leaf Spring Set – Wheeler’s 2005+ Tacoma 4X4 and PreRunner 5 Leaf HD
  13. Oct 16, 2014 at 10:53 AM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    WHEELERS for the win
