Basic size question b4 I make "Hoss" purchase
Discussion in 'Wheels & Tires' started by Blkturbo!, Apr 16, 2011.
  1. Apr 16, 2011 at 9:16 AM
    Blkturbo!
    Blkturbo! [OP] Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    Okay Ive finally decided on some wheels and I know that I want 18in...gonna just go with the KMC Hoss wheels since BMF doesnt make my favorite wheel in a Tacoma friendly size yet.
    On KMCwheels.com I have 3 offset options for the Hoss 18x9 ---> +18 +30 and -12
    Isn't it the -12 offset that i need for a 3in lift on 18x9?
    And these should stick out of the fender well slightly (1-2in)?
    On a side note, 4wheelparts guy told me that for what im doing, i should be looking for a 5in BS rather than a 4.5in BS. He said either will work but the 5in will fit better.
    I always thought closer to 4.5BS is what we wanted...?
    EDIT: By the way, Im mounting 285/65/18 TRAIL grapplers....Nitto vs tire calculator says the TRAIL grapplers run a little big. Nittos says 11.93in wide and 32.8 overall diameter.....and 8.5in average rim width.
    http://www.nittotire.com/index.html
    Thanks,
    sean
  2. Apr 16, 2011 at 1:01 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You are right, you will want thr -12 offset, which is 4.5" backspacing on a 9" wide rim.
    As far as the 4.5" vs. 5" BS, it is a good rule of thumb to assume that anything 4wheel parts tells you, about anything, is incorrect.....
  3. Apr 16, 2011 at 1:31 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    the -12mm is what you want. The 5" BS would keep the tire/wheel into the fenders by an additional 1/2", but with tires over 285 wide then there are issues with rubbing the UCA and frame at full steering lock. 5" BS wheels are technically a better fit for widths less than the 285; over the 285 then you want the 4.5" BS so basically your at the cutoff for going either way IMO.
  4. Apr 16, 2011 at 5:25 PM
    Blkturbo!
    Sean
    Henderson, NV
    Okay so is -12 equivalent to 4.5in BS on a 9in wheel?
    And for what I'm doing with a 9in wheel and 285/65 tire, I will just ignore the 5in BS thought all together.
    Thanks!
  5. Apr 16, 2011 at 5:27 PM
    RelentlessFab
    Eric
    yes, 9" width w/ 4.5" BS= -12mm offset
  6. Apr 16, 2011 at 5:30 PM
    UticaClub
    UticaClub Well-Known Member
    Utica, NY
    2010 TRD Sport
    TRD CAI, TRD Exhaust, Yakima Rack, Satoshi Mod, Grillcraft Insert, FJ40 Emblem, Hella 500 Driving Lamps, KMC HD Hoss 17x9 rims, BF Goodrich AT KO 265/70/17
    Nice choice on the rims.
  7. Apr 17, 2011 at 6:54 AM
    Blkturbo!
    Sean
    Henderson, NV
    :D
    Okay thanks for the responses everyone. Just like to triple check shit before i leap!
  8. Jan 11, 2012 at 6:59 PM
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
    pretty much same set up but with 17x9 -12mm on 285/70 duratracs? would i need spacers and if so what size? Thanks
  9. Jan 11, 2012 at 10:17 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    i have 18x9 xd hoss wheels, -12 (4.5 backspace) fit real nice
  10. Jan 12, 2012 at 5:51 AM
    KPT
    09 Prerunner
    Nope
  11. Jan 12, 2012 at 6:24 AM
    XD40SC
    XD40SC Well-Known Member
    Davis
    South Carolina
    10' PreRunner SR5 Black Sand Pearl
    HOSS in black is dope
  12. Jan 12, 2012 at 7:04 PM
    smtaco73
    South Louisiana
    Thanks alot, now im searching for cheapest price online. Any suggestions?
  13. Jan 12, 2012 at 7:09 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    x2
  14. Jan 12, 2012 at 8:02 PM
    Frostbyte
    Northern Utah
    I love the all black xd hoss wheels too
