Basic Tire Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CloseYetFar, Jan 20, 2023.
  1. Jan 20, 2023 at 12:22 PM
    CloseYetFar
    CloseYetFar [OP] Member
    New Jersey
    2010 TRD Sport SR5
    Hi,
    Is anyone running BFGoodrich KO2 LT265/70R17/C mfg# 66255 on their 2nd Gen TRD Tacoma?
    Right now I have the KO LT265/65R17/E tires, but I think the C rating may be better for this truck. I really don't tow anything, I just use the bed for stuff. I know the 70 aspect ratio is a little taller. I want to make sure there will be no rubbing. It looks like there is enough wheel hub room. I have the factory TRD Sport lift.
    So basically, I want to go from 65 aspect ratio to 70 and E rating to C rating. I don't think I really need 10 plys and 80psi max. I generally run about 38 psi. Maybe the C rated tires will be a little lighter too. What do you think?
  2. Jan 20, 2023 at 12:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You’re good to go. :thumbsup:
  3. Jan 21, 2023 at 12:16 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I’ve had those before and had no rubbing with 2.5 inch lift setting on 5100 Bilsteins. However, I dont have front mud flaps, so, don't know if tires may rub on those.
