Basics.......Oil Change....First timer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phoneguy44, Apr 1, 2010.
  1. Apr 1, 2010 at 8:59 AM
    phoneguy44
    phoneguy44 [OP] Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Did some research.....:eek: wow, have you seen how many posts pull up on a search for oil change ?
    Couple questions and I'm gone. Switching to Mobil1 Synthetic -
    1. How many quarts do I need ? (5 1/2 ??)
    2. Recommended oil weight ? (5w-30 ??)
    2006 V6 4x4
    Thanks guys!
  2. Apr 1, 2010 at 9:01 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. Apr 1, 2010 at 9:03 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
  4. Apr 1, 2010 at 9:30 AM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    That be great if I had one.
    Thanks for the link to the oil change Snapper, answered my questions.
    She's beggin for an oil change......just look at her !
  5. Apr 1, 2010 at 9:32 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Yep- it says so right on your oil cap...
  6. Apr 1, 2010 at 10:44 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    don't pull the transmission drain plug. remember, the engine oil resides in the oil pan which is located below the engine block and not below the transmission. if you can't identify the engine from under the truck, then don't do it.
  7. Apr 1, 2010 at 10:51 AM
    grivera
    Hanover, MD
    x2!
  8. Apr 1, 2010 at 10:53 AM
    Duck760
    Duck760 The Duck
    I used 5w - 50 i didnt even know they made it haha... but thats the best for both extreams
