Bat+Deadhorse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StrikeSwiftly, Dec 27, 2013.
  1. Dec 27, 2013 at 2:43 PM
    StrikeSwiftly
    StrikeSwiftly [OP] Well-Known Member
    Nebo, NC
    None yet :D.
    Hi,
    Man I know im beating a dead horse here but. I need a little input.
    I currently have a factory SR5 4x4 4door taco.
    Which would give me more of a leveled appearance.
    A 3in spacer in front and a 2 inch block in rear?
    A 3in spacer in front with 1 inch block in rear?
    For some reason I would think the 2in block would put it up a little higher in the rear?
    Thanks. Applying tan blocker for the flames heading this way.
  2. Dec 27, 2013 at 2:51 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    3" in front and 2" in back will level you out.
  3. Dec 27, 2013 at 2:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Measure the existing hub to fender front and back , this should tell you how to proceed to be level
  4. Dec 27, 2013 at 2:54 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    :facepalm:
  5. Dec 27, 2013 at 3:04 PM
    Chakraj
    Chakraj Well-Known Member
    CA
    2013 DCSB TRD SPORT v6 auto 4x4
    Badgers, I don't need no stinking Badgers.
    OK 3 in front and 1 in back will be perfectly level when the vehicle is stopped on flat ground. But when you drive it will look Bro Lean.
    3 in front and 2 in back will look a little back high when stopped, but look flat when driving.
  6. Dec 27, 2013 at 3:54 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I'd have to disagree with this cause I installed a 3" lift up front and 2" in the rear and mine was perfectly level on ground level.
  7. Dec 27, 2013 at 4:11 PM
    StrikeSwiftly
    Nebo, NC
    None yet :D.
    I did think of the shock lift. I have decided for now just to do a simple spacer setup. I have a bad habit of trading vehicle off rather quickly. I was going to have a local shop do a Rough Country 3 in lift but I am not a fan of the welded spacer. Just going the cheap way out.
    Just for looks only, I don't go off road. I think im going to hit the 3+2 because I can't stand the bro lean. I don't mind being alil higher in rear at worst.
    Thanks guys!
  8. Dec 27, 2013 at 4:46 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    In your sig pic, unless its the shadows, it looks like your front is higher than the rear.
  9. Dec 27, 2013 at 4:49 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Haha yeah in that pic I was actually on the gas so thats why my rear end was a little lower then the front.
  10. Dec 27, 2013 at 4:55 PM
    OZ-T
    Peter North
    British Columbia
    I don't buy it that the rear squats 1" any time the truck is moving
  11. Dec 27, 2013 at 5:48 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Suggestion: Wood block lift in the rear and washers in the front on extended strut hat studs.
    If you do trade off vehicles quickly I would do the lift correctly with shocks and springs since the future buyer will not want to purchase a truck that has poor rode manners.
  12. Dec 27, 2013 at 7:32 PM
    UGAFAN
    UGAFAN Well-Known Member
    George
    Atlanta, GA
    2021 TRD Off-Road
    TRD lift and 33’s.
    Wood blocks and washers? You can't be serious...
  13. Dec 27, 2013 at 8:02 PM
    Agent Smith
    Sarcasm font must have been off….
  14. Dec 28, 2013 at 6:17 PM
    StrikeSwiftly
    Nebo, NC
    None yet :D.
    Great news I just did the wood block and washer setup, looks great and traded even for a '14 Raptor!.
    lol, sadly I think there are far more "poor quality" lifts on the road at any given time. Either way best wishes!
