Bathroom remodel!
Discussion in 'Garage / Workshop' started by Zombie Runner, Aug 3, 2011.
  1. Aug 18, 2011 at 7:03 AM
    #61
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    the thing you screwed the mounting bracket to.
  2. Aug 18, 2011 at 8:02 AM
    #62
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I screwd the mounting bracket to the sheetrock using anchors...there is only a small hole in the wall with the two wires coming out of it.
  3. Aug 18, 2011 at 8:06 AM
    #63
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No box ?
  4. Aug 18, 2011 at 8:11 AM
    #64
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I doubt it. all I could see was the wires coming out, a stud, and there was what looked like a small metal bar back in there.
    this house was built in 1956 and done cheaply.
  5. Aug 18, 2011 at 8:14 AM
    #65
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Black wire = hot
    white wire = neutral
    bare = ground
    none of which should touch each other.
  6. Aug 18, 2011 at 8:17 AM
    #66
    OZ-T
    Peter North
    British Columbia
    With no box , what do you ground the grounding pigtail to ?
  7. Aug 18, 2011 at 8:20 AM
    #67
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    With that old a house, you probably have a box and cloth covered wire (is it just two black wires coming out of the box?). It's also possible you have knob and tube as well.
    You might want to consider rewiring the bathroom if that's the case.
  8. Aug 18, 2011 at 8:22 AM
    #68
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    In the old days, you didn't.
  9. Aug 18, 2011 at 8:30 AM
    #69
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    its a white and a black wire coming out from the wall. No clue what a knob and tube is :notsure:
  10. Aug 18, 2011 at 8:31 AM
    #70
    OZ-T
    Peter North
    British Columbia
    I meant now
  11. Aug 18, 2011 at 8:44 AM
    #71
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    I don't think you do anything, just cap it off. Either way this shouldn't be the issue you are having of the middle light not coming on. Something between the bulb and the wall isn't connecting quite right on that middle one.
  12. Aug 18, 2011 at 8:50 AM
    #72
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I bet your right. My porch light had that ground wire that I could not connect either. Im gonna try and take a look at it tonight. Its just frustrating that I took the time and effort to hook it up and it doesnt work right!
  13. Aug 18, 2011 at 9:09 AM
    #73
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There is nothing to ground the fixture too because in the knob and tube days, they didn't do grounding so unless you fix that, there's no point in grounding the fixture.
    Knob and tube explained. The short answer is that wires were fed between stud bays using ceramic tubes. The knobs are also ceramic and used to hold the wire off the stud to move it up a stud bay or roof rafter. It's often used with the cloth wrapped wire.
    With the age of the house, I bet there's a fix of wiring systems and if you plug in one of those testers, I bet you'll find that hot/neutral isn't consistent either.
  14. Aug 18, 2011 at 9:11 AM
    #74
    OZ-T
    Peter North
    British Columbia
    Ya , sorry , I know what knob and tube is , I wasn't sure that it had been established that is what he has .
  15. Aug 18, 2011 at 9:17 AM
    #75
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Not for you. OP asked what it was.
  16. Aug 18, 2011 at 9:19 AM
    #76
    OZ-T
    Peter North
    British Columbia
    Cool
    :thumbsup:
  17. Aug 18, 2011 at 10:03 AM
    #77
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yup. My electrical experience goes about as far as replacing light switches, plugs, and fixtures...thats it.
  18. Aug 18, 2011 at 10:15 AM
    #78
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Pretty unlikely that its K and T in a 50's built. K and T was used until about 1930 around here.
    It is also a good bet that anything prior to early 60's (62-ish in my neck of the woods) is not run with a ground wire.
  19. Aug 18, 2011 at 11:16 AM
    #79
    Saskquatch11
    a qualified Journeyman Electrician, such as myself, would have to install a box and ground the box, meaning I would have to pull a new homerun, rewire the entire circuit, and maybe even install a ground plate if necessary.
  20. Aug 18, 2011 at 11:18 AM
    #80
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    bah. we only have one bathroom and I dont have the time or money to do all that extra stuff. We are only gonna be in this house for another 4 years or so then we will be upgrading to something built in atleast 1990
