BATS!! in the cabin filter??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smirky, Dec 31, 2011.
  1. Dec 31, 2011 at 9:45 AM
    Smirky
    Smirky [OP] Active Member
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    One warm day as I was leaving work I started my Taco an immediately caught a face full of death smell...w/t helllll. I drove home with the windows down and when I got home popped the hood and started my search for what I thought would be a dead rat in my engine compartment .. you see several months earlier I had a check engine light come on and noticed the truck running really rough so took to my local Toy store and they informed me that a rat had chewed up one of my main electrical harnesses in the V cavity of the engine??? $1200 later I incorporated a very proactive "search and destroy" all things critter-like near the truck including mothballs in the crevices of the engine compartment and even sprayed critter ridder in strategic areas on the vehicle itself including wheel wells and engine compartment. Needless to say my truck smelled horrible but didn't want another wire chewing trespasser near my truck again. Well a couple months later I got he face full of death smell and thought damn! a freakin rat got in and died in the engine compartment but after a fruitless search to find the source of the death I realized I only smelled it when the fan was on in the cabin sooooooo popped the glove box off and slowly pulled the cabin air filter out to find with the assorted acorns and droppings two unrecognizable carcasses decaying directly on the filter itself :eek: I studied the bodies but couldn't figure out what they were, my best guess was a couple of dried up toads maybe? It bothered me because I couldn't figure out how a toad would climb up in there I mean I don't think they can even climb :confused: Ok conclusion I now make it a habit to check the cabin filter every couple of weeks and what I found was a less decayed critter on the filter one of those times and it turns out it's a BAT! all curled up and dead. So how the hell these things are getting in there is a mystery to me. Anyone have any ideas how to critter-proof the cabin filter?? I didn't take a picture of the bats but did take one of the last filter change and you can clearly see acorns pieces, droppings from what I'm pretty sure are bats and bits of black foam from around the filter chewed. It's just getting weird :cool:
  2. Dec 31, 2011 at 9:49 AM
    acdronin
    acdronin Well-Known Member
    Where in the hell are you driving/flying?????
  3. Dec 31, 2011 at 9:57 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    put a metal mesh grille under the cowl, over the opening for the air conditioner, I think some one posted a DIY a while back.
  4. Dec 31, 2011 at 12:01 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    Where in the nine hells do you live?!
    We have bats here (the real small ones that come out at dusk and are 'freakin invisible in the daytime) but I have NEVER heard of them crawling into a car before. Weird. Do me a favor - if you get any more take a picture of it before it's too decomposed, I'd like to know what kind it is.
  5. Dec 31, 2011 at 1:33 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    Well it's not Transylvania I'm actually in Orlando. I thought of putting mesh in if I could figure out where. That whole vented section at the base of the windshield just doesn't seem to be open enough for them to get through. Does the A/C draw from anywhere else?
  6. Dec 31, 2011 at 1:34 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    If I get anymore of them I will get a good picture for you
  7. Dec 31, 2011 at 1:40 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    wow now that's one i never heard about before...bats in the cabin filter!
  8. Dec 31, 2011 at 1:48 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    there is a big open hole in the passenger side wheel well that is about the size of a softball that goes straight into the intake
  9. Dec 31, 2011 at 2:14 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I do Wildlife Control for a living, and might be able to help, at least with identifying the critters responsible for the problem. You already know there are small rodents of some type bringing those acorns in, and their droppings are going to be nearly identical to a small bats, The difference is, if you want to try it, is a bat dropping is made up of skeletal material from the insects it eats, and will totally pulverize if you squeeze it,like dust. A rodent dropping will be much harder,and you will not be able to crush it as easy. I have heard of mice and small rodents doing this, and eating wiring,but have never seen a bat inside an air filter ever. Good luck with it.
  10. Dec 31, 2011 at 2:27 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
  11. Dec 31, 2011 at 2:37 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    TRD suspension lift, WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    Bats don't eat acorns, and don't chew destructively, so I'm thinking you have mice. A photo would prove me wrong, of course...
  12. Dec 31, 2011 at 3:21 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    Are you talking about on the firewall where the electrical harness goes through?
  13. Dec 31, 2011 at 3:23 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    I know I know there seems to more to this than meets the eye
  14. Dec 31, 2011 at 3:25 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    I actually have a really good microscope so maybe I'll do some CSI on the poop :) I'll let you know, thanks
  15. Dec 31, 2011 at 3:35 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
  16. Dec 31, 2011 at 3:56 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    Just think if you didnt have a filter. It would be like a blender in there :puke:
  17. Dec 31, 2011 at 5:37 PM
    Skunkman
    Syracuse - Tug Hill
    I think first thing tomorrow I am going to put my cabin air filter back in. Took it out over the summer to replace it, and the new one is still sitting in the tool box.......Looks like some nasty funk to be inhaling.
  18. Dec 31, 2011 at 5:45 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Can't tell you how many remains of mice etc. I have removed, heater fans are another nice home for them. Once a month I take the air filter out of the cars and vacuum out the trash. That's pretty common in the North country. Often wonder what would happen if I sucked up one of the damn things one morning when I started it.
  19. Dec 31, 2011 at 5:47 PM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    think I'll do the steel mesh over the intake hole this weekend to keep the little fellas out
